Great work FCG, I have used MM5 for years and love it. As soon as I get another video card I will try this out.
The discovery of the problem with the CPU usage may be a BIG help in resolving the problem with both cores showing the same temps. I will explore this.
Since everyone wants to change the labels to their own choice I will remove the auto-setting of this. Just set it yourself to whatever you want! :)
-FCG
Sweet, don't forget to send it my way mate :)
Getting real close to a final release version. One more item to track down and then it will be released with support for all Core architecture CPUs (Yonah, Merom, Conroe, Allendale, Woodcrest, Kentsfield, Clovertown).
-FCG
Have you found a workaround for the cpu usage bug yet?
Thats what I'm working on. I'm talking with Alex (maker of MBM5) to see if there's a possible answer...Quote:
Ah, cool
Originally Posted by freecableguy
would it be alright if you asked him to check out the p5b dlx config.....you know im not too sure about the +5v rail ... or it would be really cool if he can make a real config for it, its fine like this it would be just cool if it came from him :) ..... although i know that probably wont happen since he quit with it :(
hehe try to get him to support it again, lets make a pettition :)
Free Cable Guy,
Per your instructions, I emailed you for the files, but have gotten nothing back.
Is there a delay or what?
I think he got enough testers, so just hold on for the final product to be released!! :)Quote:
Originally Posted by roller11
That's the email I got...:p:
Anyone running a 680i with MBM? If so what MB choosen to start from?
Well, i have the Plugin working ~ 5 days now and i have not seen any bug/problem since the last update! Great work! I think if the bug with the usage is fixed u can release the final! :toast:
Use Speedfan to check out which IC is reading the voltages etc. on ur board, then search for the IC and look if any older mainboard use the same IC! That is the only idea i have at the moment. :)Quote:
Originally Posted by xgman
Seconded :toast:Quote:
Originally Posted by funkflix
well and letting us type how we want the text to show :)Quote:
.....but ya this is awsome....here is almost 3 full days of pc being on, 1sec monitoring interval, notice the number of readouts, just casual use, switching between 2 different windows users, and hours of Oblivion and all is well :) great job FCG
Great stuff..........now when do the 'Minions' get it? :rolleyes:
mm nice work!
Here are my results. Working perfectly!:cool:
Gigabyte ds3 / Corsair Twin2X DDR2 800 / Core 2 Duo 6300 @ 3150mhz (450mhz FSB).
Alex and I have located what we believe is the bug in the current version of MBM5 and are now working on finding a way to work around it. Exactly why the problem is occuring is quite unknown which makes the solution all that more elusive. We will have something out soon though. I hope to offer the download for MBM5 Update 3 along with the plugin so that everyone can monitor their core temperatures as well as CPU usage.
-FCG
awsome man, thanks for the update....hehe did u ask him if there is any way he might reinitiate mbm again
Thx for the update FCG :toast:
Good work! :)
Bit Offtopic, but maybe someone can tell me, which option i must change, that MBM5 show me MHz for my GX2 clocks, not °C?
Originally Posted by MBM5.ini
this is handled by the plugin, nothing you can change. contact the GX2 plugin developer to report the problem and ask for a possible new revision release.Quote:
FCG found another bug.....when i have 2 windows accounts loged in, the other account shows 0c for both cores all other temps and voltages are fine ofcourse, although it showing 0c always does not affect the logs
Great work! I'll use it for sure. :)
bump, now available for DL
