Well the sticks I got weren't good, they would crash with 1000Mhz 4-4-4-4 4:5 @ 2.4vdimm. I'll be selling the new ones cuz I scored some D9GKX (OCZ Platinum Extreme). So far I think the 10th Anny were better (yes I kept a pair).
So close, I set my sticks to 1000 4-4-4-12 at 2.0v and got it to boot into windows but then it crashed :( 2.1v seems to be the magic number. Now onto 1200!
Strap change occurs at 424>425MHz FSB (1696>1700)Quote:
Originally Posted by Dumo
i'll test my 680i tonight if a get a chance
Jeeze nicepun your bummed because they wouldn't do 1000Mhz at 4-4-4-4 on 2.4v, isn't that pretty impressive to run at that speed with those timings? Were you using 1T or 2T? Here I was bummed because my kit wouldn't do 900Mhz at 4-4-4-12 1T on 2.35v!
DDR2-1000 4-4-4 @ 2.25v or less should be possible with most good D9.Quote:
Originally Posted by Roger_D25
We're talking on 2T right? If not my D9's are just not up to snuff, lol!
I'm talking on 975/965...so yes, 2T. Although on 680i, with 2T...most good sets should be able to easily surpass DDR2-1200 4-3-3 w/ 2.3v, because the timings don't mean as much to the memory controller, according to results I've seen.Quote:
Thank you very much EnJoY, that info is greatly apprecaited! I continue to learn something different about this mobo/RAM combo everyday! The learning curve for me has been steep, being a Intel convert, lol!
Anyone else pair this up with a DS3? Results? I can't run 1200 4-4-4 even with 2.5v
Scratch that, can't even do 1200 5-5-5 w/ 2.5v. What's the highest ram would do on a DS3?
Well, since my XMS2 5400ULs do 1000Mhz @ 4-3-2-4 4:5 w/ 2.4vdimm I guess I set my standards a bit high....:slapass:Quote:
DS3's dislike micron d9's...you won't see 1200mhz on a DS3, no matter what the voltages.Quote:
Originally Posted by HeadOn
are you sure about that? my S3 loves my DDR667 D9's. or is there that much difference between the DS3 and S3? I got the DDR667's over 1000mhz. i'm sure i could get my DDR1000 D9's over 1200mhz on that board. i can try it tonight.Quote:
Originally Posted by EnJoY
I don't know what to say about your board, all I know is what I hear. There are endless topics about how DS3's hate D9.
I'm not saying you're wrong, because I personally don't know. I was just wondering if there were any tests done comparing RAM with that board? Or maybe comparisons between the S3 and DS3?Quote:
I'll run my Ballistix 8000 in my S3 tonight and come back with some results.
I ordered this ballistix ram 12/8/06 from newegg. It arrived today 12/12 and it is D9GMH.
I ordered the Ballistix tracers on 12/8 from newegg and received them 12/12 also! :) Thanks for confirming its D9GMH, i really didn't want to take off the heatspreaders =)Quote:
Originally Posted by LiquidEric
Has anyone tried this on a 975x board, specifically the P5WDH? If so, how were the clocks?
1170mhz 2.2v 5-5-5-15
1070mhz 2.35(max p5wdh real unmodded) 4-4-4-4
Mine are running 1111mhz 2.1v 24/7 FAH 5-5-5-15 on XBX.
[QFT] what happened to your RMA? hope you got it back by now [/QFT]
:toast:
Ok mate thanks a lot, that's very re-assuring. I'm getting a pair of these in the near future, I'll post up how they score.
Hoping it get it back by friday.Quote:
Originally Posted by GrimReaper
My pair runs at 2.2v 1000MHz 4-4-4-12 and 2.2v 1067MHz 5-5-5-15 rock stable. :)
Edit: runs on Asus P5WDG2 WS Pro 0506 BIOS.
http://home.comcast.net/~riptide007/tracers.jpeg
all i need now is my e6600
AL1005's huh? do they have the same IC's as the AA1005's?
From what I understand they are exaclty the same modules except for heatspreader and use D9GMH IC's! Great looking sticks by the way, almost got them myself!
