its about 1c better than the tuniq tower.Quote:
And what makes you so sure about that?Quote:
Originally Posted by Speederlander
http://www.3dnews.ru/cooling/titan_a...tec/index4.htmQuote:
Originally Posted by Rattle
The tests is Russian,this means,it is 100% REAL,it is neutral,not like in THG :fact: And includes benchs on both AMD and INTEL setup :woot: So:Режим простоя means IDLE,режим максималной нагрузки means MAXIMUM LOAD.It beats the Noctua Nh-U12F,which is about the same as Tuniq Tower and TR-Ultra.Just look at the results at the LGA775 test:fact: :fact: :fact: :fact: :fact: :fact: :banana: :banana: :banana: :banana: :banana: :clap: :clap: :clap: :clap: :clap:
This is the HSF I will by for the Annual OC tournament (I have chosen to stick with air cooling-LN2,GAS or WC makes the competition so easy,it is way not interesting).
Originally Posted by Fixt00l
I would avoid the big typhoon vx anyway. I hate the push pin hold down system after what it did to my ICFX3200 mobo. Bent the :banana::banana::banana::banana: out of my motherboard before i machined up a solid aluminum backplate for it with 6-32 studs epoxied in place and dug out some thumb screws and spring to make a real hold down for it. I didnt even need the 86cfm fan since i never used it but threw on a SS fm121 on it lol. Its holding my E6600 under 58c orthos priority 9 loaded 1.43vcore.
The original big typhoon is the same sink with a weaker fan and a bolt through back plate, the original being $10 cheaper than the VX you can afford to throw a better fan on it than comes with the VX and have a secure mount. I dont know what thermatake was thinking have'n a 800g cooler with the type of mounting pressure it had use'n those :banana::banana::banana::banana:y plastic pushpins:nono:
where and when could we buy some ?
I'm not that impressed. I don't see any advantage over a good tower other than the cooling of the motherboard. The fan mounting will be ackward. Not to mention what fans to use.
