Originally Posted by |RickY|
Nice so far Ricky!! :toast:
Are you going too use cap tube on stage 1 and 2 and cpev on 3. stage?
yes overklokk, bad ideia?
:toast:
No i dont hink so :)Quote:
I working on one right now and vil try captube stage 1 and cpev 2. and 3. stage. If thats not good i change too cap tube.
Stage 1 and 2 is upp and running. -45c stage 1 and -99c stage 2 so far...... hoping too get oilsep for stage 3 tomorrow. But i only hawe 1150 for 2.and3. stage :( wil try too get dome argon but i dont know if i can get it.
Argon is hard to get for YOU? :p: Isn't it widely available since it's used as a shielding gas?Quote:
Originally Posted by Overklokk
OT: It's good to see that Cryo-tek's theories are finally starting to have an impact on "top tier" builders such as yourselves. Hopefully, we'll see some awesome numbers coming from your machines :toast:
Argon is not hard too get but i am afraid that i myst by a hole bottle..... thats waste of money if i only need a little of it :)Quote:
Originally Posted by s7e9h3n
Ahhhh...IC...Looks like your cascade's going to have to make a trip with you to your nearest automobile repair shop :DQuote:
hehehe i'm thinking on the same! :D seems to be the only way to get just a litle of argon
Guys you can get tiny amounts of argon gas on ebay, about 300g if I remember correctly :).
hummm i'll check it :D
another thing, can someone find or know info about M089, substitute for r13b1?
http://img257.imageshack.us/img257/8453/oilzb9.jpg
oil @home :)
brettbeck: i found 390g argon bottles on ebay and uk shops :) need to find if my oxigen regulator from oxiturbo fits on that bottles
a regulator is about 30€.
http://www.afterbuy.de/images/23311/...regler14kl.jpg
Hehe, no Łukasz, Ratax has bought them from me :D .Quote:
Originally Posted by LukeXE
Veeerrryyy nice work Ricky :toast: .
I can't stand to see 3rd stage temps :D .
Peter
Yea those are the ones i've seen. But be carefull as some are Argon/CO2 mix. I think your regulator would fit, considering the size of the bottles are similar :).Quote:
Hehe, I gave to sl4ck cpev as small present, so I thinked that RickY used that cPEV :PQuote:
Originally Posted by piotres
Nice work RickY, I want see nice temperatures :rolleyes: If not you gonna make for me two evaporators instead of one :slapass: :banana: :)
heheh
lukexe... we will made it for you... :S :D :)
well, a lot of work today,
2nd stage is ready and leak testing, just need to brase the old evap on this suction and finish soldering 3rd oil sep!
insulating is not finish, dont look @that mess.
http://img77.imageshack.us/img77/6081/1ph3.jpg
http://img77.imageshack.us/img77/7832/2wi0.jpg
http://img263.imageshack.us/img263/5224/3ka9.jpg
trust-me, live it looks not so hugly has it looks on pictures :S
:toast:
Nice :D! But what's that random piece of pipe sticking up from the base lol :p:?
its to hold up the hx
Ahh yeah didn't realise it was making contact.
i have no words...
1st, i get out of r404a on midle of 1st stage filling, i need to use propane/butane mix from soldering bootle :D
well... it works... awsome compressors!!
http://img249.imageshack.us/img249/7005/1ststage4vh.jpg
i start 2nd stage, perfect!!
http://img149.imageshack.us/img149/8540/2ndstagete7.jpg
start 3rd stage with pure ethylene and... perfect!! -143ºc :o :banana::banana::banana::banana:ing hi side pressures.... take a look, i need another gas or mix!
http://img249.imageshack.us/img249/8403/all4ws.jpg
the 3 or 4cm of backside hx insulation isn't enough... and inside hx's there is no insulation for now!
http://img143.imageshack.us/img143/1641/770640986pt.jpg
for 1st test, i'm stupid!
is there any probability of nitrogen work like argon, just to get that hi side pressure up and get better temps?
any other gas or mixes sugestion?
:toast:
wow ricky that is good work
Time to play with nitrogen and some load ;)
Awesome, more issulation on HX and you will reach -150°c ;)
regards
work of art Ricky, i cant wait to see it finished! :)
Crazzy setup. Dont know much about Phase but do understand those negative Numbers :D
Congrats!!
Yo that's awesome ! :D What's the loaded 1st stage HX temp? 35% propane and 65% butane is funny.
I hope you get some R14 + R740 into that 3rd stage soon :)
