im talking to someone whom most of his future WRs will come from g80 ;)Quote:
come on hipro :D
you know what whe want to see ;) :D
tommorow nda is up right?
Should be a fun day for you hipro, hope you still have ln2. :)
Last Ati benches at 1 minute to midnight ... love it.....
Excellent pifast time as well sub 18s for hexus version... :toast:
Regards
Andy
Thanks guys.....:) .....I'll finish this round with the X1900's or X1950's and I'll move on......;)
Testing the Master Card for cold bug.....This Master is VERY OLD - one of the first ones I suppose (Gorillakos will tell us).....
So far so good......Unmoded can handle down to -50*C ATI tool reported.....Not bad....Let's move one now....:D
Under test with k|ngp|n's Tek-9 LN2/DI Container....It fit's PERFECT on ATI cards....:D :toast:
http://www.thelab.gr/images/Hipro5/C..._Container.jpg
Naked Tek-9 looks bas ass! I love it, send these babies out in style hipro :yepp:
This card is one year old...and it was benching twice a day since april 3dmark2006 cause it was a demo on a system in a store..:DQuote:
Originally Posted by hipro5
The case had 80C all day(12hours was playing)....
So we have since april(april-may-june-july-august-september-october) 2 banches a day x 210days = 420 3dmarks2006 and thousands hours burning in the case....
it is The card with the bet burn in ever..:D
Finally after many cards..one without coldbug...:toast: :toast:
id really like to see pifast @ 4:5 @ 4-4-4-12...
......and I really like to see pifast at 1:1 @ 5350MHz and 446MHz rams with Cas 3-2-2-1.....:( :DQuote:
Originally Posted by esdee
hmmmmm.....411MHz x 13 multi.......I'll test it too......:)
you know what im thinking... almost in every case ive tested pi 4:5 was always faster with a bit relaxed timmings than 1:1. Too bad i had some problems with the asus board
AMAZING :up:Quote:
You finally showed us a way we can use 3.5" diskettes lying around :D :D :p
Can't wait for numbres :banana:
Perkam
Wow, no insulation, what about condensation? Or am I missing something because I have never benched sub-zero?
It's not phase change its ln2.Quote:
Originally Posted by wtkprol
Perkam
I doubt condensation will occur with LN2, its so cold water will freeze on contact with it. The cards might get a bit wet after the benchmark runs when the system is powered down, but if theres no power going thru the cards and theyre dried off well before the next run, all should be fine.
Ask kingpin how he dos it :D , he runned more LN2 then most off us hereQuote:
Originally Posted by Atomicpineapple
Looking good hipro :D
When you're at ln2/dry ice temps with low humidity everything frosts over instead of water forming. Frost is not conductive.
Looks sick Hipro! Is that a Dragon CPU pot or one of gorillakos's?
Ahhh, I see now. Thanks guys, I guess I need more experience with DI/LN2.
I didn't insulate it coz it was just for a "quick run" so as to find out the cold bug temp of the VGA......Just some minutes......Quote:
Of course afterwards you have to pull out the VGA and remove the container very fast coz your VGA will be filled with water when the container starts to raise it's temp again.....;)
It's a "Gorilla CPU pot".......:DQuote:
Originally Posted by afireinside
k|ngp|in's VGA pots are SO beautiful and "delicate" I could say, that I fall in love with then in the first sight.......:D :toast:
Some UPDATES....:)
OFFICIAL 2k5 World Record.......(I say official coz FutureMark hasn't approved yet the NVIDIA's drivers or else my friend k|ngp|n would be above me)....:D :toast:
http://www.thelab.gr/images/Hipro5/C...0MHz_1_png.png
http://www.thelab.gr/images/Hipro5/C...0MHz_2_png.png
OFFICIAL World Record at 11/16/2006 - COMPARE 2k5 URL...Click me...
VGA's have "frequency bug" and they don't go above those frequencies (864/1143)......NOT on rams and NOT on cores too or else the score whould have been OVER 30000 marks+...... I bet that these VGA's could do almost 1100MHz on core and over 1350MHz+ on rams....... I can bench at 864MHz core with ONLY -15*C ...... So I have almost ANOTHER -80*C spare on each card and I don't have what to do with them..... :(
I'll see what can I do about it......IF ATI don't give us a "bugless bios" so as to flash them, I think that I'll unsolder their reference XTAL Oscilator which is 27MHz and replace it with another one of 30MHz or more so as to keep the multiplier of the cards as is and climb on higher frequencies......;)
Insane results with ATi cards, would be great got all your knowledge Hipro5 :toast:
Wow that is insane. 28k 05!
Do it hipro :D it will be a nice mod :DQuote:
Congrats on that 05 run!
Really nice Hipro5! :toast:Quote:
I have a solution to your core freq limit. You have PM :)
Thanks guys.......and I've got the PM Marcus, thanks M8....;) :)
