He posted my results.Quote:
Originally Posted by camouflage
You are watching my results :P
Now i'm going to search for vmem reading to do some mods on p5b dlx.
Time to give some vmem to this babies.
:D
:D
:D Hm - sometimes :am: :nuts: , but now I see clear.......Quote:
Originally Posted by Lasac
So push these babies forward.......... :slapass:
Originally Posted by mach82
yep , thats obvious , there is no 6400 in world 3700mhz@1.50v @ 100$ WC -- prime stable
but even not stable 3700@1.50 its one of the best 6400 i ever seen and i ever had ( already had 3)
3352mhz@ Vcore Auto @ SPI 1M :
http://img380.imageshack.us/img380/6...biossv0.th.jpg
and the P5B --- 500 FSB its prime stable ---- 8 Hours Orthos :
http://aycu25.webshots.com/image/646...4598587_th.jpg
and boot from bios at 510 FSB 1:1 ( the numbers in the SIG ;) ) ---( there is no setfsb or any other program to OC in windows the P5B ;) )
http://aycu20.webshots.com/image/645...4475428_th.jpg
not bad for 140$ mobo :banana: :banana:
now to be the perfect SIG I need to buy the Cellshock :D
go for it , we want more !!!! :D
regards
:banana: CELLSHOCK best RAM ever made - l@@k at this low RAM delay in EVEREST with 2x1GB sticks...........:eek: :
http://img245.imageshack.us/img245/1...2m41859er4.jpg
:toast:
:toast: :toast:
every day I love more this RAM :D
regards
Sorry guys for my late post but I was TOO busy the last couple of days and I did nothing at all....From tomorrow I'll test every timming and every voltage so as to help you see what they do in a chart or something like that....:)
Originally Posted by mascaras
Nice chip. :)
My E6400 does superpi 32m @ stock vcore (misread in cpuz, older version :rolleyes:) @ 3283 mhz with boxed cooler. Seems to be a nice chip too. Soon under SS. :toast:
damn... what is the minimum Vdimm you need to give these puppies to make them work?
i've tried 400 1:1 with 4-4-4-12 and 5-5-5-15 and it's not prime stable...
if i increase the voltages to 2.3 Vdimm and mch to 1.8 the tests run for 2 minutes... can you guys help this noob?
i'm running with the abit as well with the 1.2 bios
i have the Pc8000 5-5-5-15 version (cellshock)
Ok,here are some what i like to call "real world" results.I say real world because they were in a proper case,with no added fans,stock mobo,and run at sensible 24/7 voltages in ambients of 22c.I used the 670 and p5wd2-p (955) on the 14 multi (to keep fsb up),because i have a feeling the 975x chipset will hinder the rams in certain scenario's.I ran 3 common sets of timings at 2.1v and 2.3v (2.08/2.28 actual) and ran these for 1m,8m and 32m.I left the secondary ram timings at the settings the bios thought appropriate for the various deviders i ran.Here are the results in mhz.
............................... 1m. .8m. .32m
3-3-3-8.. 4/5 @ 2.08v. 381 .378 .375
3-3-3-8.. 4/5 @ 2.28v. 414 .411. 409
4-4-4-12. 3/5 @ 2.08v. 497 .495 .490
4-4-4-12. 3/5 @ 2.28v. 539 .534 .532
5-5-5-16. 1/2 @ 2.08v. 536 .530 .528
5-5-5-16. 1/2 @ 2.28v. 547 .542 .538
not sure why, but i can't go higher than 385 1:1, no matter what timings i use...
also using 385 with 667 memory divisor doesn't work either...
I first i thought i had a problem like that with my 5400GA, i thought they had elpida chips on them... but now... same thing...
i've tested the cpu in orthos and is runs well. when i use blend or memory, it fails after a few seconds...
Same here!! This board seems to be very finicky with memory . I have tried a few different sets of memory. all fail after a few seconds of blend but can run CPU all night. I had some pc1000 at 6-6-6-18 fail at 390 yet the same sticks run on my dfi at 4-3-4-10 440 all day. I have sent a couple of emails to ABit about it. will post back IF they reply.Quote:
Originally Posted by Patuga
I am having the same problem here. I hope Abit will fix this problem on the next Bios.Quote:
Like i promised here are some results with vmem mod on P5B Dlx:
http://img383.imageshack.us/img383/7846/555cd8.jpg
Looks like i need to do vmch mod because the board can't pass 572fsb. :slapass:
I'm testing other timings/fsb.
I'll keep this updated.
More pics:
http://img150.imageshack.us/img150/6066/487yw6.jpg
P5B FSB limited:
http://img245.imageshack.us/img245/1262/575at7.jpg
Cumps.
Chasing you guys with old school D9, I have a few more sets to play with but this is booting into windows and without Maximizer :D but soon, very soon.
http://valid.x86-secret.com/show_oc?id=128230
Mushkin ES D9 orignal fat body @ 2.65v set in bios.
:eek: 2.65v in bios, 420 3-2-2-4 ....... really really good fat D9s :woot:Quote:
Originally Posted by FUGGER
I will apply a lot more voltage, they have not caughed up any errors yet.
The BX2 goes up to 2.8v
Heh, heh, heh,......So you're actually feeding them with 2.62Vdimm only.....;) :)Quote:
any vdimm mod and vmch for this board?
Anytime soon...;)Quote:
Originally Posted by neoplan
thanks hipro:cool: ,i want to buy this board tomorrow cause is ready in shop near my home,maybe that BIOS until 12 released was not give perfect performance cause no 1333 strap and no pciexpress frequency,but i know this board have good potention.:D ,waiting this mod and BIOS :toast:Quote:
Originally Posted by hipro5
Here´s my results on a non (yet) moded P5B Deluxe (2,45v) :D
SPi 32m 900mhz 3-3-3-8
http://img170.imageshack.us/img170/9...832mpd3.th.jpg
SPi 32m 940mhz 4-3-3-8
http://img201.imageshack.us/img201/2...832mni8.th.jpg
SPi 32m 1100mhz 4-4-3-8
http://img151.imageshack.us/img151/8...832mgf1.th.jpg
SPi 32m 1170mhz 4-4-4-12
http://img151.imageshack.us/img151/3...232mpz3.th.jpg
These memos are really great :woot:
Well, my aw9d-max does the cold booting thing so once in a while since a few day`s with 1.2 bios.
I need 2 pci slots so I will buy the asus p5w-dh since that is the only one my retailer has ( don`t want to order a board online anymore ;) ) .
Any of you guy`s having cold boots sometimes with the abit aw9d-max ? ( the shutdowns of the fans on starting (and restarting while bios saving ) and the HDD power downs with the scary clicking )
Mine has never done that, i have had it hang on failed overclocks and the only way to get it back responding was to power down.Quote:
Originally Posted by Pjoeloe
I haven't read the rest of the topic yet.
Is the Cellshock RAM available in the US?
