Thanks... It's been a lONG time... I thought I saw something that said high low and medium. Maybe I'm getting confused with the 939 one! :p:Quote:
Originally Posted by Digz
I don't see the name of Core 2 Extreme QX6700 in CPU Suport List of 775Dual-VSTA or ASRock Motherboard - Intel Core 2 Duo/Extreme CPU support List. How did you learn that 775Dual-VSTA supports QX6700?Quote:
hello everyone, i might have got a vcore mod with a trimmer and connected between the sgnd and offset pin on the ic6714. plz do not try it yet cuz i will first. i will have my board in a few days hopefully and will test the mod to see how it works. another mod that might work for vcore is connecting one of the vid pins to sgnd and it would raise vcore but not positive since i havent got to try it. will get back up wit u guys when i get the mods done to let u no how it works.
@renethx
Niether can i now , It looks like the quad core line has been removed.
Originally Posted by renethx
It was in the list as Digz described and has now been removed for some reason.
:rolleyes:
Originally Posted by natedog420
Thanks Natedog and be careful with the mods.
:D
Unless i never noticed it before Core 2 Extreme X6800 Conroe XE has been
added to the top what ever that is. ?
( XE ) Stands for extreme edition as far as I know.Quote:
:2cents:
@Alchemist
I just fitted the board with a D 805 and i must say i'm very impressed for something so cheap.
I can boot the PC at 3.42 on air and browse the internet and convert AVI to dvd without any problems but is there anything you would suggest i use to test for stability ?
Now that you have reached the max overclock with the stock voltage, its now time for the pin volt mod?Quote:
Prime95 or Orthos are mainly used to test pc for stability.
:clap:
Think i'll save the pin volt mod until i refit my watercooling blocks :D
Also i don't like the price of conductive pens.
You should not need water cooling if you keep it below 180 FSB on the
1.45volt MOD.
Why don't you try to flash 775Dual-VSTA with the 4CoreDual-VSTA board bios?
What does the 4CoreDual-VSTA bios got that the 775Dual-VSTA does not have?Quote:
Originally Posted by gogydm
:sofa:
4Core CPU support.:D
Isn't the QX6700(B3) Kentsfield a quad core chip ?
http://www.asrock.com/support/CPU_Su...l=775Dual-VSTA
two thirds of the way down since bios 210.
Yes it is a quad core and your right the dual vsta does supports it
On the Asrock website it stated that the 775Dual-VSTA 2.10 bios supported
4Core CPU’s, then they removed the reference but i think the bios still supports it. :fact:
If I had a 4Core CPU I would try it with the 2.10 Bios or flash it with the
4CoreDual-VSTA bios. :yepp:
Do you know where they sell 4CoreDual-VSTA boards outside China?
The 4CoreDual-VSTA replaces the 775Dual-VSTA as of today.
ASRock proudly released 4CoreDual-VSTA based on VIA® PT880 Ultra, which supports Quad Core CPU!
http://www.asrock.com/index_english.html
http://www.asrock.com/product/4CoreDual-VSTA.htm
:slobber: :slobber: :slobber:
You beat me too it i was just about to post that :)
I noticed that the Bios updates for the Qaud core have the same reason
for there updates as the dual core ?
It may be possible to bios flash the 775Dual-VSTA with the 4CoreDual-VSTA bios, once the support for the 775Dual-VSTA support stops or if you want to run the 4 Core CPU and the 2.10 bios does not work with it.Quote:
Is there a chance that the pencil mods could wear off with time?
Also
Does anyone have any updates to this motherboard with the release of the 2.4 bios? Any vcore adjustments?
My 775-vsta is on its way as I type this, but its too bad my e4300 is not even available yet:(
Bryan d
No Vcore adjustments on 2.4 bios.Quote:
Originally Posted by bryan_d
E4300 is available on my side of the planet.
http://www.shopferret.com.au/buy/cpu...ing-E4300.html
Dang for no vcore,Quote:
But I suppose if the chip can do 3GHz with stock volts like they did with the xbit and anand review, then I should be fine at 2.4-2.7GHz right?
That is pretty sweet that they have the e4300 there already. If only we had them here in... the heart of silicon valley, yah right.
But will the pencil mods wear off by time?
Thanks,
bryan d
How much volts does my memory get when the DRAM Voltage i set to HIGH? My memory is a single module Kingston 667 512MB. I found out that 1T works with DDR2 only when there are 2 modules of memory. My friend bought 2x 512MB Super T 667 and it works on 1T.
I don’t know if the pencil volt mods wear off with time. I have not herd of it happening, guess you may have to google it to find out. SorryQuote:
Pre orders at your side of the planet
http://www.ncix.com/products/index.p...ufacture=Intel
I just read upon people who would perform the pencil mods, check out the resistance, put tape on top, re-check resistance again. This would take out the chance of graphite being blown away from the air circulation in the case.Quote:
I live in the US, so it would be better to buy from my side of the border (I did live in Vancouver and Calgary for the majority of my life though:) ), and Tankguys.com has them for pre-order too. Still deciding if I should wait till they are on the shelves, or just pre-order.
Either way I will be getting one,
Bryan d
