Trying to get a Orthos stable OC
I am having a heck of a time trying to get a stable moderate OC that can pass the blended Orthos stress test. I have read many of these threads, so forgive if I missed something. But here goes. The best I can get is about 2 hours (which I guess is not considdered stable correct?) The settings are:
FSB(375- would like 400)**DRAM(750)**PCIE(100)**PCI(33.3)**Spread Spectrum(disabled)**DRAM Voltage(2.1)**CPU Voltage(1.4)**FSB Voltage(1.3)**NB Voltage(1.45)**SB Voltage(Auto)**ICH Chipset(Auto). Under CPU Config, I have everything set to "disabled" besides Vanderpool Tech.(set to enabled). Under the NB Chipset, I have: Memory remap(disabled)**Config. DRAM Timing by speed(disabled) and the following timings (top to bottom) 5*5*5*12*6*42*10*10*10*10 Static Read Control(disabled) Latest BIOS 0711 (I think thats the #)
I have tried so may combinations that my head is spining. I ran small FFT's and that was ok, large FFT's didnt run long before it failed. I removed each stick of ram, and it still failed. I am VERY new to this (first time), so are my settings ok?? what am I missing, or what else can I try? Is my PSU ok, should I try new memory (ugh $$$ but willing if it is the problem). Again, sorry if this has already been discussed, or the wrong place, but ANY help would greatly be appreciated.:confused:
Hit A Brick Wall At 350 Fsb
Ok someone please save me from suicide here. My E6600 will simply not clock over 351Mhz even if I drop the multiplier. I have trawled through this forum and I have done what everyone has suggested with regards to disabling CPU options, changed voltages (dropped and increased) but I can't get anywhere.
I can post at 355 Mhz but it won't stabilise (Prime finds error after a few seconds). If I try to go higher than this it won't post at all. My memory should be easily able to handle more (Geil Ultra PC6400 2x1Gb 4-4-4-12 and I have tried slowing the memory down with slackest latencies). I have the latest 711 BIOS on the P5B Deluxe.
Judging by so many other peoples' success at getting over 400Mhz I'm sure this thing should be able to handle more. There shouldn't be a problem with PSU (Hiper Type-R Modular 580W) and my graphics card is XFX 7900GT.
If anyone has any idea how to break this barrier I would be sincerely indebted to them and in complete awe of their overwhelming overclocking skills.
