Thanks guys...its my first v mod ever :)
heres another pic of the mod showing the VR :)
http://briefcase.pathfinder.gr/downl...0/DSC00544.JPG
Looks mad, im gonan do this. Is there any risk of the grabber falling off?
Yes, there is. Just be careful when moving your case.
Just wondering about something here. I to just used my first grabber style VCore mod on my Gigabyte K8N Pro (TIP - stick grabber down on mobo with seal string) Does it make a difference if you ground it using a fan header and an actual point on the mobo like a screw hole ? I seemed to get better results using a spare fan header than the CPU fan header ?
wait, how is the second source cheaper?? I dont get it! :confused:
Guys, anyone knows where i can buy SMD Grabbers in UK?
Originally Posted by finwe
http://www.greenweld.co.uk/acatalog/...tronic_56.html
Will these little devils attach properly to all of the contact points required to do the vmod for core, memory, overvolt and vddq on an ATI X800 for example? In other words are these grabbers only good for certain vmods, or will they clip just about anywhere for graphic cards as well?
I know many people have used them on video cards. I guess it just depends on the chip and how spaced out the legs are.Quote:
Originally Posted by SunTzu69
