| 2x1GB DDR2 Category:
TeamGroup| andre X_X | Xtreem TXDD2048M667HC3DC | DDR2-667, 3-3-3-8, 2.2v | Micron D9GMH | CPU-Z Validate! & SuperPi 32M Stable! @ DDR2-1230, 5-5-5-12, 2.77v
http://img158.imageshack.us/img158/3...277vuk1.th.jpg
DB Updated.
californian7856: I need two instances of super pi 32m or orthos.
I'm gonna have to reclaim my #1 spot in the coming week :P
by nextweek i'll received my cellshock :D
@andre X_X : Show your Cellshock with High Perfomance....I ll wating
I need to toss my Cellshock's back in for some high clocks. =) In fact, that's what I'll do today I think. :)
DDR1300 w/ only 2.4v 5-4-3-10-2T! :D
I just updated the db, and I now am in the top spot! :toast:
My cpu-z validation will have to wait. For some reason it's not letting me submit it.
4x1gb on AM2 :woot:
Crucial / TeamGroup | Ozzimark | Ballistix PC6400 / OPB ED II 9600 | DDR2-800, 4-4-4-12, 2.2v / DDR2-1200, 5-5-5-15, 2.35-2.45v | Micron D9GMH | CPU-Z Validated! & SuperPi 32M Stable! @ DDR2-1164, 5-5-4-7, 2.45v
http://www.eclipseoc.com/image/memory/4gb-582.4-32m.png
Crucial | Jmax_oc | Ballistix PC8000 / EPP | DDR2-1200, 5-5-5-15, 2.2v | Micron D9GMH | CPU-Z Validated! & SuperPi 32M Stable! @ DDR2-1335, 5-5-4-5, 2.45v
http://jmax.oc.free.fr/Mes%20Meilleu...390%204005.JPG
DB Updated.
- Intel C2D E6400@3200MHz~1.2750V load 1.216V
- A-DATA Vitesta Extrem Edition 800+ Micron D9
- 2*1GB DC Kit
- Stock speed: 800MHz 4-4-4-12 2.00V
- OCd: 1000MHz 5-5-5-15 2.25V
http://xs314.xs.to/xs314/07174/superpi.png
dodjer420, that is ASUS PC Probe 2
Laragirl, sorry for the late response but in order for your result to qualify for the database, you must meet all requirement as per the rules in my first post. You've only ran a single instance of super pi 32m, but you have a dual core processor and therefore must run two instances to qualify.
Nobody for the 2x2GB yet? Here's one then ;-)
Stock: 533MHz 5-4-4-12 2.3v
Overclocked: 600MHz 5-5-5-18 2.5v
Mushkin 4GB XP2-8500 @ 600MHz stable. It might go higher, but I considered 600MHz to be lucky enough.
http://deathspawner.net/etcetera/pic...2.5V_thumb.png
System was:
E6600 @ 2.70GHz, eVGA 680i (P27), Mushkin 2x2GB PC2-8500, ASUS 8800GTX
Corsair Nautilus Water Cooling, OCZ GamersXtreme 700W, Corsair Airflow Fan (Ram)
Stability was tested by first running a 3D Mark 06 system run, followed by an hour of Prime95 on each core, Super Pi 32M and finally MemTest for Windows over the course of about 8 hours.
http://valid.x86-secret.com/show_oc?id=197725
I have a 4 GB of thet early Aenon DDR2-533 memory (two individual sticks 2 GB each).
At 1.9 volts set (in BadAxe1, so who knows what I actually get) it does:
- runs 4-4-4-12 at 312 * 2 = 624 MHz
- runs 3-3-3-12 at 367 * 1.5 = 550 MHz
Doesn't like 2.1 Volts, doesn't like 5-5-5-14.
The box doesn't run Windows, so no fancy screenshots :)
e6600 @3.7 ghz @9 multi @ 411fsb 1024 mhz
Guys, please read the rules before trying to submit your results.
One instance of either prime or 32m for each core on your CPU. A cpu-z verified validation from the latest version of cpu-z available. Full specs of the modules, and full stats before and after the overclock. If you do not follow these rules, I cannot post your result.
Here's my CPU-z for an earlier post then.
I'll edit my entry with the other information. What if we don't know what chips are used?
I got 2 of these kits for 4x1GB
F2-6400CL4D-2GBPK
Not overclocked but 5-4-3-5 at 800Mhz, havent went for lower. I cant do the first number a 4 because my mobo hangs on boot.
Cellshock PC 8000 cl 4 2.2V @ 5-3-3-9 2T /5-4-4-9 2T 12XXMHZ 2.4V:)
ahh finally made it workin' fine!:clap:
A-DATA PC8500 Vitesta Extreme Edition 1066+
running now in 1:1 divider with CPU (500MHz FSB) at 1000MHz cl4-4-4-12 ~ 2.25V:up:
http://valid.x86-secret.com/show_oc?id=200238
OCZ's Titanium DDR2-800 didn't make it on the Intel 1T list? It's working pretty damn well on a friend's machine :)
ASUS P5N-E SLI (650i)
C2D E6420
OCZ 2 x 1GB DDR2-800 Titanium EPP (OCZ2T8002GK).
- lk
