good to have you man!!! welcome to the team!!!
finally i joined...
ok it's just an olde xp 3200+ for the beginning and nothing compared to other rigs, but it's the best i have ATM and i will add other devices soon...
my grandpa died a slow and painful death as the result of prostate and bowel cancer & my dad is a hardcore-chain-smoker since 45 years, so i decided to do at least something
Welcome to the team. Great that you joined. Every bit helps the effort. :thumbsup:Quote:
Originally Posted by flexo_fk
Are you running on Boinc or UD client?
Thank you for the welcome, meshmesh :)Quote:
Originally Posted by meshmesh
currently i'm running the boinc client ver. 5.8.11, is that ok?
and i heard something about crunch3r's optimized files, what's that about?
Yep the new boinc client is fine. As for the Crunch3r opti's they are unnecesary on wcg and actually cause you to get less points. So just running the standard boinc client is best.Quote:
Thanks for joining :toast:
thanks melymel2789 :) so i will leave the system as it is..
i don't want to sound noobish, but is there a way to fasten up the pending validation?
because results from device #2 (laptop) were sent to wcg at the 02/13/07 18:22 and they are still not valid...
and results from device #1(main rig) sent to wcg at 02/14/07 13:01 are already valid :confused: is this normal? or does wcg the device #2 not accept? - it's not listed under 'Device Statistics' but i can see it under 'Device Manager'...
It can sometimes take 3-5 days and to get an accurate idea of what your machines are putting out can take over a week to see with any accuracy.Quote:
Patience is the word here.This is all about the quorum system.
They can send to 3 guys, 2 send back in a day, #3 works on it for 3 days on and off with a PC that runs 2 hours a day and then say that person formats or goes away..After the week when the Work unit expires, they send to guy #4 and you wait till he sends back..
It works out in the end but I hear you, at first you wonder where the hell are my points.:D
If it makes you feel better, I have an 8 core dual clover here with over 50 WU pending validation. It just does them so fast that the machine gets ahead of everyone else.
thanks movieman for explaining the matter, now i see how the cat jumps
the quorum system is the culprit (or the slower guys) :p:
:rocker: rock 'em dude!! sweet, really sweet system u have.. i'm far far away from that wcg processing power :(Quote:
Originally Posted by Movieman
next step for me is to get an olde xp1800+ up and running..
Ya'll are puttin' a whuppin' on everybody in WCG! Good work and congrats.
I'm Folding For WCG :D
First time for everything I s'pose :D
Allright...
Got my E6600 rig folding, along with a E6400 rig - for XtremeSystems ofcourse ;).
Unfortunately they don't crunch that hard at stock speed. Problem is that both MB's suck, so OC is not an option. Hope to upgrade my E6600 motherboard/ram soon - so I can get to use the full potential:)
Hey, any little bit counts, right? Welcome to the team.
I joined up today as well
folding on a P4 2.6 w/ HT
soon to be building a c2d e6420 when they are released as well - will add it when not gaming etc
Hey, there's now runing a P4 @3GHz HT for ya pplz!
Sometimes i'll clock it to 3,5Ghz up, or to 3,78Ghz, who knows.... but @OC does anyone have to pay the energy used by this CPU for me, otherwise my parents 're going to let me pay it.... (and i don't have ANY money - getting from them? stupid things ya thinkin' bout!)
how can i install boinc on my AMD Athlon(tm) 64 Processor 3200+, freebsd 64bit os ?
1. Go here and get the latest client file.
2. go to the WCG website and sign up and join xtremesystems of course.
3. Install the tar ball and input your information.
4. Should do it. If not post back and some one much smarter then me can hop in.
Thanks for your interest in WCG and Team XS :toast:
i've already installed boinc client.
but i always keep on getting this message...
did i do something wrong ?? what needs to be done ??Quote:
2007-03-29 10:09:23 [http://www.worldcommunitygrid.org/] Sending scheduler request: Project initialization
2007-03-29 10:09:23 [http://www.worldcommunitygrid.org/] Requesting 1 seconds of new work
2007-03-29 10:09:26 [---] Project communication failed: attempting access to reference site
2007-03-29 10:09:26 [http://www.worldcommunitygrid.org/] Scheduler request failed: problem with the SSL CA cert (path? access rights?)
2007-03-29 10:09:26 [http://www.worldcommunitygrid.org/] Deferring communication for 1 min 0 sec
2007-03-29 10:09:26 [http://www.worldcommunitygrid.org/] Reason: scheduler request failed
2007-03-29 10:09:32 [---] Access to reference site succeeded - project servers may be temporarily down.
couldn't download the program, keep getting the "Error on Page" message.
Edit: NVM, I got it. Anybody have trouble downloading at the registration page, just go to Home then download from there.
Did you get this worked out?
You need a ca-bundle.crt. Look here.
When BOINC builds, it's supposed to find curl's ca-bundle.crt. Sometimes it doesn't.
I don't know why, but exactly one of my BSD boxes does this. Of course, it also won't download all the files it needs to run the projects.
wow, thanks for the help..
connection established, but can't download any work..
here's the output...
Code:2007-04-10 15:29:21 [---] Starting BOINC client version 5.8.15 for amd64-portbld-freebsd
2007-04-10 15:29:21 [---] log flags: task, file_xfer, sched_ops
2007-04-10 15:29:21 [---] Libraries: libcurl/7.16.1 OpenSSL/0.9.7e zlib/1.2.2
2007-04-10 15:29:21 [---] Data directory: /usr/home/StyM/wcg
2007-04-10 15:29:21 [---] Processor: 1 amd64 AMD Athlon(tm) 64 Processor 3200+ [] [sse sse2 sse3 3dnow 3dnowext mmx]
2007-04-10 15:29:21 [---] Memory: 1013.19 MB physical, 0 bytes virtual
2007-04-10 15:29:21 [---] Disk: 32.16 GB total, 8.95 GB free
2007-04-10 15:29:21 [---] No general preferences found - using BOINC defaults
2007-04-10 15:29:21 [---] This computer is not attached to any projects
2007-04-10 15:29:21 [---] Visit http://boinc.berkeley.edu for instructions
2007-04-10 15:29:29 [http://www.worldcommunitygrid.org/] Master file download succeeded
2007-04-10 15:29:29 [http://www.worldcommunitygrid.org/] Sending scheduler request: Project initialization
2007-04-10 15:29:29 [http://www.worldcommunitygrid.org/] Requesting 1 seconds of new work
2007-04-10 15:29:34 [World Community Grid] Scheduler RPC succeeded [server version 509]
2007-04-10 15:29:34 [World Community Grid] Message from server: platform 'amd64-portbld-freebsd' not found
2007-04-10 15:29:34 [World Community Grid] Deferring communication for 1 days 0 hr 0 min 0 sec
2007-04-10 15:29:34 [World Community Grid] Reason: requested by project
2007-04-10 15:29:34 [World Community Grid] Successfully attached to World Community Grid
2007-04-10 15:29:34 [---] Running CPU benchmarks
2007-04-10 15:29:34 [---] Suspending computation - running CPU benchmarks
2007-04-10 15:29:36 [World Community Grid] [file_xfer] Started download of file stat_v01.png
2007-04-10 15:29:36 [World Community Grid] [file_xfer] Started download of file default_00_v01.gif
2007-04-10 15:29:39 [World Community Grid] [file_xfer] Finished download of file stat_v01.png
2007-04-10 15:29:39 [World Community Grid] [file_xfer] Throughput 1521 bytes/sec2007-04-10 15:29:39 [World Community Grid] [file_xfer] Started download of file faah_00_v01.gif
2007-04-10 15:29:40 [World Community Grid] [file_xfer] Finished download of file default_00_v01.gif
2007-04-10 15:29:40 [World Community Grid] [file_xfer] Throughput 1546 bytes/sec2007-04-10 15:29:40 [World Community Grid] [file_xfer] Started download of file faah_01_v02.gif
2007-04-10 15:29:41 [World Community Grid] [file_xfer] Finished download of file faah_00_v01.gif
2007-04-10 15:29:41 [World Community Grid] [file_xfer] Throughput 4465 bytes/sec2007-04-10 15:29:41 [World Community Grid] [file_xfer] Finished download of file faah_01_v02.gif
2007-04-10 15:29:41 [World Community Grid] [file_xfer] Throughput 19312 bytes/sec
2007-04-10 15:29:41 [World Community Grid] [file_xfer] Started download of file faah_02_v02.gif
2007-04-10 15:29:41 [World Community Grid] [file_xfer] Started download of file faah_03_v02.gif
2007-04-10 15:29:47 [World Community Grid] [file_xfer] Finished download of file faah_02_v02.gif
2007-04-10 15:29:47 [World Community Grid] [file_xfer] Throughput 5102 bytes/sec2007-04-10 15:29:47 [World Community Grid] [file_xfer] Finished download of file faah_03_v02.gif
2007-04-10 15:29:47 [World Community Grid] [file_xfer] Throughput 4992 bytes/sec2007-04-10 15:29:47 [World Community Grid] [file_xfer] Started download of file faah_04_v02.gif
2007-04-10 15:29:47 [World Community Grid] [file_xfer] Started download of file hdc_00_v01.gif
2007-04-10 15:29:53 [World Community Grid] [file_xfer] Finished download of file faah_04_v02.gif
2007-04-10 15:29:53 [World Community Grid] [file_xfer] Throughput 4712 bytes/sec2007-04-10 15:29:53 [World Community Grid] [file_xfer] Finished download of file hdc_00_v01.gif
2007-04-10 15:29:53 [World Community Grid] [file_xfer] Throughput 943 bytes/sec
2007-04-10 15:29:53 [World Community Grid] [file_xfer] Started download of file hdc_01_v01.gif
2007-04-10 15:29:53 [World Community Grid] [file_xfer] Started download of file hdc_02_v01.gif
2007-04-10 15:29:59 [World Community Grid] [file_xfer] Finished download of file hdc_01_v01.gif
2007-04-10 15:29:59 [World Community Grid] [file_xfer] Throughput 3130 bytes/sec2007-04-10 15:29:59 [World Community Grid] [file_xfer] Finished download of file hdc_02_v01.gif
2007-04-10 15:29:59 [World Community Grid] [file_xfer] Throughput 6002 bytes/sec2007-04-10 15:29:59 [World Community Grid] [file_xfer] Started download of file hdc_03_v01.png
2007-04-10 15:29:59 [World Community Grid] [file_xfer] Started download of file hdc_04_v01.gif
2007-04-10 15:30:05 [World Community Grid] [file_xfer] Finished download of file hdc_03_v01.png
2007-04-10 15:30:05 [World Community Grid] [file_xfer] Throughput 16038 bytes/sec
2007-04-10 15:30:05 [World Community Grid] [file_xfer] Finished download of file hdc_04_v01.gif
2007-04-10 15:30:05 [World Community Grid] [file_xfer] Throughput 4982 bytes/sec2007-04-10 15:30:05 [World Community Grid] [file_xfer] Started download of file hdc_05_v01.gif
2007-04-10 15:30:05 [World Community Grid] [file_xfer] Started download of file hdc_06_v01.gif
2007-04-10 15:30:11 [World Community Grid] [file_xfer] Finished download of file hdc_05_v01.gif
2007-04-10 15:30:11 [World Community Grid] [file_xfer] Throughput 2935 bytes/sec2007-04-10 15:30:11 [World Community Grid] [file_xfer] Finished download of file hdc_06_v01.gif
2007-04-10 15:30:11 [World Community Grid] [file_xfer] Throughput 5973 bytes/sec2007-04-10 15:30:11 [World Community Grid] [file_xfer] Started download of file hdc_07_v01.png
2007-04-10 15:30:11 [World Community Grid] [file_xfer] Started download of file hpf2_00_v01.gif
2007-04-10 15:30:17 [World Community Grid] [file_xfer] Finished download of file hdc_07_v01.png
2007-04-10 15:30:17 [World Community Grid] [file_xfer] Throughput 5637 bytes/sec2007-04-10 15:30:17 [World Community Grid] [file_xfer] Finished download of file hpf2_00_v01.gif
2007-04-10 15:30:17 [World Community Grid] [file_xfer] Throughput 943 bytes/sec
2007-04-10 15:30:17 [World Community Grid] [file_xfer] Started download of file hpf2_01_v01.gif
2007-04-10 15:30:17 [World Community Grid] [file_xfer] Started download of file hpf2_02_v01.png
2007-04-10 15:30:23 [World Community Grid] [file_xfer] Finished download of file hpf2_01_v01.gif
2007-04-10 15:30:23 [World Community Grid] [file_xfer] Throughput 1407 bytes/sec2007-04-10 15:30:23 [World Community Grid] [file_xfer] Finished download of file hpf2_02_v01.png
2007-04-10 15:30:23 [World Community Grid] [file_xfer] Throughput 11915 bytes/sec
2007-04-10 15:30:23 [World Community Grid] [file_xfer] Started download of file hpf2_03_v01.png
2007-04-10 15:30:23 [World Community Grid] [file_xfer] Started download of file hpf2_04_v01.png
2007-04-10 15:30:29 [World Community Grid] [file_xfer] Finished download of file hpf2_03_v01.png
2007-04-10 15:30:29 [World Community Grid] [file_xfer] Throughput 11098 bytes/sec
2007-04-10 15:30:29 [World Community Grid] [file_xfer] Finished download of file hpf2_04_v01.png
2007-04-10 15:30:29 [World Community Grid] [file_xfer] Throughput 11025 bytes/sec
2007-04-10 15:30:29 [World Community Grid] [file_xfer] Started download of file hpf2_05_v01.png
2007-04-10 15:30:29 [World Community Grid] [file_xfer] Started download of file hpf2_06_v01.png
2007-04-10 15:30:35 [---] Benchmark results:
2007-04-10 15:30:35 [---] Number of CPUs: 1
2007-04-10 15:30:35 [---] 1892 floating point MIPS (Whetstone) per CPU
2007-04-10 15:30:35 [---] 5654 integer MIPS (Dhrystone) per CPU
2007-04-10 15:30:35 [World Community Grid] [file_xfer] Finished download of file hpf2_05_v01.png
2007-04-10 15:30:35 [World Community Grid] [file_xfer] Throughput 10318 bytes/sec
2007-04-10 15:30:35 [World Community Grid] [file_xfer] Finished download of file hpf2_06_v01.png
2007-04-10 15:30:35 [World Community Grid] [file_xfer] Throughput 10079 bytes/sec
2007-04-10 15:30:35 [World Community Grid] [file_xfer] Started download of file hpf2_07_v01.png
2007-04-10 15:30:35 [World Community Grid] [file_xfer] Started download of file hpf2_08_v01.png
2007-04-10 15:30:35 [---] Resuming computation
2007-04-10 15:30:42 [World Community Grid] [file_xfer] Finished download of file hpf2_08_v01.png
2007-04-10 15:30:42 [World Community Grid] [file_xfer] Throughput 5724 bytes/sec2007-04-10 15:30:42 [World Community Grid] [file_xfer] Started download of file fcg1_00_v01.gif
2007-04-10 15:30:43 [World Community Grid] [file_xfer] Finished download of file hpf2_07_v01.png
2007-04-10 15:30:43 [World Community Grid] [file_xfer] Throughput 7923 bytes/sec2007-04-10 15:30:43 [World Community Grid] [file_xfer] Started download of file fcg1_01_v01.gif
2007-04-10 15:30:44 [World Community Grid] [file_xfer] Finished download of file fcg1_00_v01.gif
2007-04-10 15:30:44 [World Community Grid] [file_xfer] Throughput 3857 bytes/sec2007-04-10 15:30:44 [World Community Grid] [file_xfer] Finished download of file fcg1_01_v01.gif
2007-04-10 15:30:44 [World Community Grid] [file_xfer] Throughput 7552 bytes/sec2007-04-10 15:30:44 [World Community Grid] [file_xfer] Started download of file fcg1_02_v01.gif
2007-04-10 15:30:44 [World Community Grid] [file_xfer] Started download of file fcg1_03_v01.gif
2007-04-10 15:30:47 [World Community Grid] [file_xfer] Finished download of file fcg1_02_v01.gif
2007-04-10 15:30:47 [World Community Grid] [file_xfer] Throughput 14357 bytes/sec
2007-04-10 15:30:47 [World Community Grid] [file_xfer] Finished download of file fcg1_03_v01.gif
2007-04-10 15:30:47 [World Community Grid] [file_xfer] Throughput 20365 bytes/sec
2007-04-10 15:30:47 [World Community Grid] [file_xfer] Started download of file fcg1_04_v01.gif
2007-04-10 15:30:47 [World Community Grid] [file_xfer] Started download of file fcg1_05_v01.gif
2007-04-10 15:30:53 [World Community Grid] [file_xfer] Finished download of file fcg1_04_v01.gif
2007-04-10 15:30:53 [World Community Grid] [file_xfer] Throughput 4791 bytes/sec2007-04-10 15:30:53 [World Community Grid] [file_xfer] Finished download of file fcg1_05_v01.gif
2007-04-10 15:30:53 [World Community Grid] [file_xfer] Throughput 4326 bytes/sec2007-04-10 15:30:53 [World Community Grid] [file_xfer] Started download of file fcg1_06_v01.gif
2007-04-10 15:30:53 [World Community Grid] [file_xfer] Started download of file fcg1_07_v01.gif
2007-04-10 15:30:59 [World Community Grid] [file_xfer] Finished download of file fcg1_06_v01.gif
2007-04-10 15:30:59 [World Community Grid] [file_xfer] Throughput 2217 bytes/sec2007-04-10 15:30:59 [World Community Grid] [file_xfer] Finished download of file fcg1_07_v01.gif
2007-04-10 15:30:59 [World Community Grid] [file_xfer] Throughput 6299 bytes/sec
