So, what software shows the vMCH in Windows then?!?! Asus PC Probe II won't show it...any ideas?
I mean i was able to boot into XP @ 3.8Ghz and ran some benchies then it crashed and i haven't been able to boot back into XP at that freqQuote:
Originally Posted by The Nemesis
the settings for that one were auto and its not prime stable.
Also I've noticed if you disable usb to only 4 hubs it boots quicker
What is that core voltage 1.65v? On air, sod that.Quote:
Originally Posted by MustardTheoRy
Wow I just got my 6700 running last night... 3.8 with only 1.55V... not sure if it is stable yet but superpi IM is QUICK :D
http://valid.x86-secret.com/show_oc?id=113763
actually im running 1.62v in windows to be prime stable @3.6GhzQuote:
Originally Posted by fornowagain
I put 1.7volts on the cpu to boot into 3.8 on air..heh heh
:eek: wow it's very high ! need only 1.48 v to be prime stable @3.5 ghzQuote:
is it 1.7 in bios ?
nice, sounds probably better than mine..Quote:
[OT] and w00t, 2000 posts ftw! :D [/OT]
I just updated to 1101 and found out that i couldnt boot with the exact same settings as i could with 0804, so i decided to flash back, but the Asusupdate program wont let me flash back.
I checked the "BIOS downgradable" box in settings, but when i try it just says "use newest program from Asus webiste" or something very close to that, the only problem is that im using the newest version allready.
Anyone have a good advice as to how i can flash to 0804 from 1101?
