Have you looked at event viewer for errorcodes? I had same thing caused by uTorrent. If you have there on that list event ID 4226 then you need patch for that, newest is v2.23d.Quote:
can i run a P4 520 on the P5W DH Deluxe after the mods (any)
yes, i understand that there are mods shown out there. but this weekend (after the move) i will be putting up step-by-step instructions on completing the vdimm and vMCH mods.Quote:
Originally Posted by managerman
kris
is it me or the board don't like anything except 1:1 ?
is there anyone else having the problem of max FSB drops after mods
zulusman has a similar problem, i wouldnt know much about this.Quote:
Originally Posted by 450tantrum
I've been running on 4:5 almost 100% of the time I've had this board (couple of weeks now)Quote:
Originally Posted by Supertim0r
i haven't had any problems so far.
@FCG, please give us those step-by-steps! I've never vmodded anything and I'll definitely need those instructions. Thank you sooooooo much FCG!!!
bios ?Quote:
Originally Posted by m0da
started out with 0502 > 0078 > 0701Quote:
all worked fine
wich one is the best ?
i've the 0078 and 0088 I want to try
well for my pentium 550 i think 0078 was the best. but i dunno which bios is the best for conroe.
@450tantrum
I got problem with fsb drop. But had it before and after mods...
So it`s not a mod problem i think.
Dunno what it is, really....
It would be nice to see a vdroop mod guide too.;)Quote:
Originally Posted by freecableguy
It would be good to get above 2.4v Vdimm
FCG will be posting up step-by-steps of vDimm and vMCH mods soon. these'll get you well above 2.4v.Quote:
Originally Posted by gotheb1ues
great sounds good. can't waitQuote:
Hi guys,
I'm trying to perform the hotflash in an Abit AW8 mobo, and when i run flash.bat, i'm getting the following error:
bios has no flash information..
And then it just exits out of the flash program.
Should i try it with the Award flash program, or maybe even try using winflash?
EDIT: I've also tried with with AWDFLASH now and it just gets stuck with "Please wait!!!" flashing on the screen.
Nice thread thanks guys.
Hey guys, this is my story> I bought a P5W DH Deluxe and an X6800. Both arrived last tuesday, i set my compouter together and clicked the button and the motherboard wouldnt post. I called ASUS and had them send me a new BIOS Chip because i found out the one shipped to me was a 0502. THe new one came, (with no sticker on it) so I'm not positive which ver. it is but they told me it was the most current not in beta. it came yesterday, i plugged it in and NO LUCK. The **** will hit the fan trust me. I freaked and went berzerk. So I RMA'ed the whole board back to ZZF and a new one (same model/type) should arrive to me tomorrow. If it has the 0502 chip in it ill take it out and put the newly shipped one into it. But you can imagine how nervous I am. What if it doesnt work again!!! Ill shoot something. That means it is my CPU!!! It will be impossible to find a replacement, unless you think Intel would replace it for me. Trouble is that A) I dont have another CPU to test on the board. 2) I dont have another board to flash the chip in. and D) There is no place that will be able to run a diagnostic for me with the Conroe! What should I do if the new board does not fix the problem?
A, 2, and D... ha
okay. id suggest just finding another 775 chip somewhere and using the asus ez-backup from the bios (the simplest way imo) and flashing the chip (again).
this is something really important, just get your hands on another 775.
i doubt it's your cpu.
if you really cant do that, there was a hotflash method or something like that on the first page of this thread by FCG. he knows what he's doing, just follow that and hope for the best.
I had similar problems when I first setup my 6800 and DH. I had to ram the first board even after fashing to 7901 with a celeron because of general socket failure, but I also found that when setting up the new bios I had to unplug the PS, take the battery out, leave the clear jumper on for a while and then re-connect up everything and then post. Did you get anything when you started up the new bios? Any fans, lights? If so, it is altogether possible you had a short (like i did) or even that the sink wasn't making good enough contact even though it may have appeared to. Do the above procedure even after replaceing the bios. If the new board has the same trouble, then Intel will replace the cpu if it's retail, but it may take them a while since it still isn't oficially released and when I thought mine was dead at first I called them and they said it could be some weeks. your retail supplier would probably get them back in stock before Intel RMA would. By the way, the chances are pretty goo they send you a 701 bios board. Asus sent resellers out new 701 bioses if they didn't ship with 701's already.Quote:
Originally Posted by Chunkylover21
Guys there is a new beta bios as i can see here but it's currently down.Have anyone flashed 0901?
I will try as soon as its available
Originally Posted by deadlock7
updated CCU microcode
- Crash of the BIOS with SATA CDROM repaired
- does not correct appearing announcement of the FSB: RAM of divisor in the AI booster
- Over clocking profile feature
My max fsb droped to 0 last days...dunno why.
Had somme strange coloers on the mb - silver->brown.
Need to mode-off mb and rma it... first just had to check if its cpu or mb.
So cu soon
Nicely done :clap:
However I have a question about the mods. Will it be necessary to do the mods if I'm only gonna go with high end air cooling as Tuniq. From what I've heard it wont be safe to touch those high voltages unless you plan to use more extreme cooling.
