The reason why 965 chipset dont support sli is because the PCI-E Lanes are two different bandwidths (x4 and x16) nothing to do with software just hardware.
There is no difference between 945 955 and 965 all of them have PCI-E 16x + 4x and on all it is possible to run SLi :DQuote:
Originally Posted by maverik-sg1
It will be more slowly than 8x + 8x but will work :D
http://www.xtremesystems.org/forums/...ad.php?t=83950
yes it work on mine no problemsQuote:
Originally Posted by jsy982002
and other run fine to
have not seen anyone run 965 chip cards in sli or cf have you ?Quote:
Originally Posted by Big_Sam
all the plases i have lookt for info say no sli og cf on 965
thanks so much for the drivers i been looking for these for a few days .
Well, i dont know, if i am right or wrong, but my Gigabyte Ga-G1975X forces Crossfire to 8x8...maybe also Sli?Quote:
Sry if i am wrong...
Regards Dennis
What is the difference between Gigabyte or Asus, Abit or something else ???Quote:
Originally Posted by bl1zZ
All devices on 975 chipset are made equally and have 8x + 8x all other restrictions are only in drivers.
gigabyte has open muti in bios asus dosen't . from what i have seen ecept xe
Can someone send me the modded drivers? svtsnake@comcast.net
Thanks!
p5b have open multi down with new biosQuote:
Originally Posted by heydo6
thanks work great
Can someone please send me the modded drivers?
shadoxity @ thisspace.net
Asus p5w-dh and 2x7600gt's :D
Cheers
Excited to receive my E6600 and P5W DH tomorrow, off work on Wed / Thurs so I had CPU RAM MB overnighted @ 75$ shipping :-( Was debating for 3 days straight on biting and getting X6800 with P5N32-SLI to get true SLI support however found too many 3.4-3.7ghz X6800 owners and I just can't justify that much money when E6600 is performing almost the same speed.
Replacing my X2 4400+ @ 2.68 was not going to upgrade but 2 friends using Core 2 Duo @ 3ghz and they don't have to set affinity and game plays flawless without patches, CPU drivers etc etc that AMD needed and still had problems.
Anyone find any issues running this 85.96 driver? Anyone know if someone will hack a newer 91.31 series driver for use and if Nvidia and Intel are somehow partnered why disable the SLI support if the hardware works fine?
Running 2x7900GTX boards can someone please send me the drivers PM me if you have time.
Thank you
Pentium777: nvidia and intel have nothing to do with eachother...
Its the fact that to run SLI and to run Crossfire it is practically the same hardware setup...
The part that says yes you can do SLI or no you cant to SLI is completly software related,
So when someone edits the software drivers so it skips that check then you can use SLi on a normally software disabled crossfire board (hope that made sense!)
Someone please send me the drivers, and i can host them on my home server!!! (25kb upload but better than nothin!)
Makes perfect sense, I did not know the PCIE slots and Crossfire / SLI was basically the same hardware chipset figured that the board's chipset needed to have some type of hardware support.Quote:
Originally Posted by Shadoxity
Not much of a choice for overclockers of this excellent Conroe chip right now, P5N32-SLI SE DLX would be in my system if it wasn't a bad overclocker, so since there isn't even a NV590 board that supports conroe out I'm left with only one choice the P5W DH so I can get the best performance out of my E6600.
Hope someone can give that modded driver by tomorrow or I'll be running on single 7900 GTX @ 2560x1600 :-(
Thanks in advance
Um aren't the modified drivers listed right here in this thread? Thats where I got mine. Read through and check.
woops... didnt read all of it
whats out for the enermax 620 liberty my blow upQuote:
Originally Posted by rpg711
then i called my hardware pusher and he tel my ca 50 %
of all of that model he sold dit that.
now i have a cheep be quiet 530 and it run my system fine :)
realy??!!?! own a liberty as well 620Watts also. so its a bad PSU?!?!Quote:
no, enermax liberty 620watt is a great psu... better than all but the best of the bestQuote:
i can only say what my dealer sad to me.Quote:
he have always ben glad for enermax and i got it
and had it for 1 month and then booom
maby enermax har a bad day and mad some bad psu“s
normaly enermax is top line.
I dont know if anyone still has these drivers, but I cant seem to find them anywhere on the net. Can someone send them to me?
zdogjones@yahoo.com
Yeah, it's impossible to find these drivers by googling for them....trust me, I've looked for several hours. If anyone has these drivers, please pm me. I'm trying to run two EVGA 7900 GT KOs on an Intel d975xbx motherboard and it's a nightmare knowing that one of them is just sitting there doing nothing. Thanks in advance.
Jonathan
hate to be a bother but if someone would please send me the drivers i would be greatly thankful.
tawalker98@yahoo.com
