welcome to xs.org ;)
thank you :)Quote:
Originally Posted by LoKi2k
Indeed welcome. I'm thinking P5WDH as well but also heavily considering the NF5 board that Asus will bring to the table.
I reckon it'll definately be an improvement over Intel NF4 but IMO it won't threaten the i975x though. So prove me wrong Nv :DQuote:
Originally Posted by Anemone
new bios 0502
ftp://dlsvr01.asus.com/pub/ASUS/mb/s...e/P5WDH502.zip
very good
it qualifies of fsb the higher or various voltages?
The bios 0502 = Bios 0065 ;)Quote:
Originally Posted by Schlingel
So, how does it look? Can I install Scythe Ninja to this board or not?
Looks like a promising board:) I'm subscribed!
I'm interested in this board but i have some questions:
1. Does it have the v-drop prob and by what margin?
2. Does it have the restart/shutdown prob above a certain fsb?
3. In a normal ATX case with 7 pci slots, does the first vga sits on slot number 1 or 2 (counting from up)?
the restart problem seems to be solved. from what they sayQuote:
Originally Posted by JoeBar
Thanks. :)
So 2 more to go...
I'm not sure about that but I read in a German forum that Vcore drops only about 0.02-0.03V under load, so it's not too shabby ;)Quote:
News bios from Asus : 0504 with FSB max 500MHz ! :D
http://www.overclex.net/data/images/...4/bios0504.jpg
score!:banana: lets see some CPU-Z screens of it actually running, at above 420Quote:
Originally Posted by CornerJack
Please post your max SPI 1M stable FSB with this Bios :DQuote:
445MHz :( but monday, I have a E6700 :DQuote:
Originally Posted by M3kk
but where is found this bios 0504?Quote:
If you want, send me a mail and I send to you ;)Quote:
Originally Posted by fr4nc3sco
probably the 445 fbs it is the limit of the chipset with that voltage you must try to make the vmod and to use 1,725v or advancedQuote:
tnx for bios
Can somebody please confirm whether or not Asus P5W DH Deluxe is compatible with Pentium D 805? I might buy this board and a P-D 805 until Conroe comes...
Pentium D 805 are so damn cheap now its hard to resist them.
-k0nsl
445Mhz wiith 1.65Vchip ???Quote:
I sadly noted that it only has 4 SATA coming off the ICH7R or so Asus specs say. Oh well seems to be a great board in all other respects
yes it should do,try there support.www.asus.comQuote:
Originally Posted by k0nsl
Of course it will work. It supports the whole Pentium D and Celeron line. Boards are most likely backwards compatible, as there would be no reason to drop the support for current CPUs. You can also download the manual from asus now and double check that.Quote:
EDIT: I will also use a D805 on it, till Conroe arrives. But I won't have my hardware before the end of next week.
