Any place to buy that board?
pretty video card Kingpin...very pretty!!!
Congratz
Congratulations Vince!
Impressive like everitime:toast:
When you fire it up and it recongnizes that you have NV cards, it activates linkboost which boost pci-e automatically and lock to 125mhz. YOu are now able to overclock the card from stock to 940-450 without sweating the pci-ex frequencies....It's very nice so we can now see the true power of the cards in SLI.Quote:
Originally Posted by GoriLLakoS
Ram timings are screaming now for 3d(screaming for am2 that is :). Here are those 1t results with the C3DIMMS.
DDR410mhz stable for 3dmark05' 2.35v 3-3-3-5-1T:
http://pic20.picturetrail.com/VOL256.../149509949.jpg
Testing 1T @3600mhz/-35c 18k with def gtx clocks, not too bad:
http://pic20.picturetrail.com/VOL256.../149509947.jpg
This is a perfect situation where 1t comes in handy to give nice boost when forced to run low HT/mem speed because of cold bug.
Nice ram. I was getting exactly 18040 with CPU at 18x202, ram at 404 with 4-4-3-5 timings. Looks like tighter timings is a boost.
Then again it could be I just suck at 3D:D
OPP
Great benching!! AM2 compliments the a64 platform nicely.
You'll love it OPP...give you all the options you need for working the cold bugged chips. This chip is a BEYOTCH. Be sure to run the C3 in the blue slots when going for LL :DQuote:
Originally Posted by OPPAINTER
nice result! 51K. looks so great!
very nice, god job like always...hehe
This Corsair 6400C3 is great stuff my friend:DQuote:
Originally Posted by k|ngp|n
I got it yesterday and improved my scores by a large margin.
That's it for my 7900 cards. I need new ones with good memory before I bench again.
OPP
BJ will be a tough hunt, Samsung stopped producing them but if you're lucky you might find some.
I've seen BC doing almost as well as BJ lately.
Nice updates for AM2 considering still pretty slow cpu speed. Cards are really screaming now:
New 03 WR:
http://pic20.picturetrail.com/VOL256.../150951317.jpg
Almost 13k 06 with only 3570mhz on FX62 @-40c:
http://pic20.picturetrail.com/VOL256.../150951315.jpg
Nearly 20k 05' / 3570mhz:
http://service.futuremark.com/compare?3dm05=2042833
Should have new 06 WR' with the cpu stable over 3640mhz soon with about -50c load temps...here is some 05 testing cpu max mhz with 3-3-3-5-2t on the CORSAIR 6400 C3:
http://pic20.picturetrail.com/VOL256.../150952291.jpg
BTW-- Ntune 5.0 rocks for changin setting in windows on this setup like mem timings/volts/pcie-mhz/htt/and on and on. Pretty nice software.
So NTune IS safe to use now?
BTW very nice scores :D.
what volts are you using on the 7900gtxs?
Are you going full force with the ln2 on them or are you keeping them at a certain temp?
thanks
*edit*
noticed you were at stock mem, thats insane. What bios are you using? stock xfx?
Not full force yet vapb, 03' was run around -95c. 06' and 05' about -85c. If the load isnt enough for the temps, the cards will lock at a certain point. It will be babysteps on clocking them from this point on. I would love to see the set doing close to 1100/1100 in SLI 1.8v+core below -100c for 05' and 06', maybe a little lower for 03' on final runs. Because 06' and especially 05' are so cpu bound with this gpu power, I am seeing big gains from small bumps in cpu mhz in all tests, including mostly gpu favored ones. 200mhz more in cpu power = HUGE gains in 06' sm2.0 and sm3.0 tests as well as gt2 and gt3 in 05'Quote:
Originally Posted by vapb400
It was safe for me...works like a charm on AM2. YOu have control of just about every setting in bios through the windows console.Quote:
Originally Posted by shimq1
really performs better in your hands as I expected - really great runs you're showing us here :toast:
God that is incredible :)Quote:
still using stock xfx bios?
Kingpin showing the am2 way.
Awesome scores....
Oh! my GOD!
GPU 1038Mhz ~~ good jod !
haha nice vince , im thinking ure holding back on the gfx's :p .
how mutch vgpu and vdd do u give those babys ?
bud i like the 03 score , how didt u work out the coldbug on the fx ? first coldbug @ -20°c . and now -40°c :p
Realy nice:)
maybe he bought a new chip :p:, hopefully he shares it :D
I still can't get over those insane gpu clocks
Go Vinny:toast:
Good to see you started in on some 05, 06 action.
OPP
:D I joined the AM2 party a little late bro. I bet same for Sham.Quote:
Chip is coming around though. Your is doing good on the PC-ICE single stage?
