btw, i stopped prime95 after 90minutes because i wanted to go to bed :D
i tested it again this morning and its prime stable for at least 4 hours (with the window open :D) with closed window it needs 0.25v more
Model: 3200+
Core: .09
Date: 0437
Stepping: CBBFD
Code: WPCW
Mhz: 2550
Gain: 550 Mhz
Vcore: 1.63
FSBxMulti:255x10 (1:1, 2.5-4-3-10, 1T)
Cooling: XP-90+Tornado
Stable: Super Pi 32m, Prime blend 12 Hrs., Stanford F@H, 3D Marks, Pacific Fighters
update:
Model: 3200+
Core: 0.09
Date: 0449
Stepping: CBBHD
Code: GPMW
Mhz: 2600
Gain: 600mhz
Vcore: 1.525v
FSBxMulti: 10x250 mem=1/2 ldt 3x 750mhz HTT
Cooling: stock heatsink with 60mm 35cfm papst fan
Stable: 6 hours prime95+2k5
..... :eek: what?Quote:
Originally Posted by Brandybuck
i cant believe that... lol, can you make a new thread and post more results and screenshots there? :eek:
ok :toast:Quote:
Originally Posted by saaya
I've a Dfi nf4 ultra-d until yesterday :D , ı'll test with 3000+ :D for you :toast:
CPU: A64 3200+
Core: 0.13
Date: 0420
Stepping : CBAUC
Code: TPMW
Mhz: 2500mhz
Gain: 300Mhz
Vcore: 1.475 <--- lower then default
FSBxMulti:250x10 (or 278x9 with 10/9 mem divider)
Cooling: custom modded boxed heatsink powered by a papst 80mm/36cfm fan
Stable: OCCT stable, Superpi 32M stable , doomIII stable , 3dmark03 stable
Model: AMD 3000+
Core: Winchester
Date: 0447
Stepping: CBBHD
Code: TPCW
Mhz: 2.7GHz
Gain: 900MHz
Vcore: 1.55v (set to 1.55v x 1.04 = ~1.6v in BIOS)
FSBxMulti: 9x300MHz with 9/10 divider, RAM running @ 270MHz @ 2-2-2-5 (with 3.5v vdimm)
Cooling: STOCK AMD 3000+ HSF
Stable: YES, PRIME95 for +24hrs & SPI32
Link: see attached screenies :D (big ones!)
Model: 3200+
Core: Winchester
Date: 0501
Stepping: CBBID
Code: DPDW
Mhz: 2.52
Gain: 520
Vcore: 1.6
FSB: 9x280
Cooling: Zalman 7000B ALCU
Stable: Runs everything I throw at it.
Model: 3200+
Core: Winchester
Date: 0447
Stepping: CBBHD
Code: UPCW
Mhz: 2750
Gain: 750
Vcore: 1.68
FSB: 10x275
Cooling: XP-90 + Papst 92mm.
Stable: SuperPI 32M, 3D, etc.
Btw, these TP*W also seem to do really well! :)
I think the steppings to look out for at the moment are?
SP*W
UP*W
TP*W
Where * can be any letter. :toast:
my gpmw is also a very good clocker... :)
and lol@your oc naelq ;)
http://www.xtremesystems.org/forums/...id=26123&stc=1
Owa! left it @ default! :p:
i'll check it for you bud ;)
Model: 3500+ Winchester
Core: 0.09
Date: 0449
Stepping:CBBHD
Code: MPMW
Mhz: 2835 MHz
Gain: 635 Mhz
Vcore: 1.63v
FSBxMulti: 257 x 11 1:1
Stable:3dmark
Cooling:water
http://service.futuremark.com/compare?2k1=8442971
Model: 3000+
Core: 0.09
Date: 0503
Stepping: CBBID
Code: EPJW
Mhz: 2430
Gain: 630 Mhz
Vcore: 1.64
FSBxMulti:270x9 (5:4, 2.5-3-3-6, 1T)
Cooling: XP-90+TT smartcase Fan 2
Stable: Prime95, SP2004., Stanford F@H, 3D Marks,
Link : http://www.xtremesystems.org/forums/...chmentid=26159
Model: 3000+ Winchester
Core: 0.09
Date: 0444
Stepping:CBBHD
Code: XPDW
Stable:3dmark03, 05, SuperPi 32M, Prime95 Blend 24h+ on all configs
Cooling: Air / Zalman 7000Cu
Mem: 2 * 1G Ballistix PC4000
CPU temp: per MBM5 on K8N Neo2 Plat
I have a few stable configs at various Vcore (noted here the Vcore min reported by CPU-Z while windows idle) :
Mhz: 2250 MHz
Gain: 450 Mhz
Vcore: 1.44v
FSBxMulti: 250x9 memclk 200 (CPU/9 => 250) 3-3-3-9 1T
Ambiant 20.5C, max CPU 46C
Mhz: 2450 MHz
Gain: 650 Mhz
Vcore: 1.505v
FSBxMulti: 272x9 memclk 150 (CPU/11 => 204) 2.5-2-2-7 1T
Ambiant 20C, max CPU 52C
Mhz: 2502 MHz
Gain: 700 Mhz
Vcore: 1.565v
FSBxMulti: 278x9 memclk 150 (CPU/11 => 208) 2.5-2-2-7 1T
Ambiant 21.5C, max CPU 54C
Mhz: 2520 MHz
Gain: 720 Mhz
Vcore: 1.58v
FSBxMulti: 280x9 memclk 150 (CPU/11 => 210) 2.5-2-2-7 1T
Ambiant 20C, max CPU 54C
Mhz: 2547 MHz
Gain: 747 Mhz
Vcore: 1.63v (*)
FSBxMulti: 283x9 memclk 150 (CPU/11 => 212) 2.5-2-2-7 1T
Ambiant 21C, max CPU 56C
(*) 3h prime failure @ 285*9 at this Vcore, didn't try 284*9
This is the highest this one will go stable. Higher Vcore freeze it while loading Windows.
The highest "stable everything except Prime" setting is 289*9 (2601MHz) @ VCore: 1.61v memclk 150 (CPU/11 => 217) 2.5-2-2-7 1T
(checked Super_Pi 32M result file against a reference file computed at lower "Prime-stable" settings : no differences)
I also noticed this particular Winnie doesn't like high FSB past 2250 (at least, it needs a lot more VCore at mem 240-250 than at mem 200-215).
Plotting the Freq / Vcore from above shows a nice hockey stick. I would love to know how cooling/CPU temp would impact the curve.
Still debating w/ myself if I should settle for this or go XP-120 or water and may-be get a few MHz more ... or could it be a lot more ?
Model: 3000+
Core: .09
Date: 0448
Stepping: CBBHD
Code: SPMW
Mhz: 3065
Gain: 1265MHz
Vcore: 1.60v
FSBxMulti: 9x340.5 memclk freq =166 ; ldt 3x = 1021MHz HTT (2-2-2-5 1T)
Cooling: Vapochill PE modded
Stable: 9 hours prime95
Model: 3000+
Core: .09
Date: 0447
Stepping: CBBHD
Code: RPDW
Mhz: 2955
Gain: 1155MHz
Vcore: 1.65v
FSBxMulti: 9x328 memclk freq =166 ; ldt 3x = 984MHz HTT (2-2-2-5 1T)
Stable: 7 hours prime95
Model: 3000+
Core: .09
Date: 0450
Stepping: CBBHD
Code: UPMW
Mhz: 2727
Gain: 927MHz
Vcore: 1.63v
FSBxMulti: 9x303 memclk freq =183 ; ldt 3x = 909MHz HTT (2-2-2-5 1T)
Cooling: 3400+ Heatsink
Stable: 8 hours prime95 + Superpi
Model: 3200+
Core: .09
Date: 0501
Stepping: CBBID
Code: FP??
Mhz: 2600
Gain: 600mhz
Vcore: 1.55 in bios
FSBxMulti: 8x325mhz, rams @ 216mhz 2-3-2-6, HTTx3
Cooling: watercooling
Stable: 24/7 F@H, 6-7hours Prime95, 3dmark01 loop 6-7hours.
Link: http://silentproject.com/stable.jpg
Core: 0.09
Date: 0450
Stepping: CBBHD
Code: VPFW
Mhz: 2530Mhz
Gain: 730 Mhz Gain
Vcore: 1.425v in bios ( shows 1.392 in windows )
FSBxMulti: 280HTTx9 (Divider at 180Mhz)
Cooling: air Zalman 7000B-AlCu
Stable: Prime95 for 6 hours, All benches completed (3dmarks01, 03, 05)
good to see you rolling TEDY :toast:
Model:3000+
Core: 0.09
Date: 0444
Stepping: cbbhd
Code: mpm
Mhz: 2.6
Gain: 800mhz
Vcore: 1.6 at time of picture, now at 1.55
FSBxMulti: 325x8 and mem devider is at 166
Cooling: xp90 with panaflo ultra and fan controller
Stable: prime95,super pi 32M
Link:http://img152.exs.cx/img152/2419/amd...able5ip.th.jpg
Core: 0.09
Date: 0450
Stepping: CBBHD
Code: VPFW
Mhz: 2700Mhz
Gain: 900 Mhz Gain
Vcore: 1.525v in bios ( shows 1.47-1.488 in windows )
FSBxMulti: 300 HTT x 9 (Divider at 166Mhz)
Stable: Prime95 for 3 hours, Super pi + 3dmarks 01/03/05
:D
Model: 3200+ Winchester
Core: 0.09
Date: 0447
Stepping: CBBHD
Code: SPAW
Mhz: 2450Mhz
Gain: 450 Mhz Gain
Vcore: 1.55v
FSBxMulti: 245 x 10 @ Ram is 1:1 7-3-3-2.5
Cooling: TT Silent Boost
Stable: Prime stable over 12 hours, memtest stable over 8 hours
not much done on 050x...i have 3000+ 0504/DPDW...from what i gathered...not really good as others :( ...hope mine can do wonders (how i'd wish!)...anyway, i'm still waiting for my xp120 to test the system. will post the result.
Core: 0.09
Date: 0444
Stepping: CBBHD
Code: VPEW
Mhz: 2900Mhz
Gain: 1100 Mhz Gain
Vcore: 1.525v
FSBxMulti: 9 x 323, memory running 1:1 with 2.5-4-3-7 timings (2x 512mb G.Skill)
Cooling: Boxed cooling
Stable: Not very stable, needs 1.6v to be stable, but there's barely any cooling paste on it so that means overheating, been trying to get some as5 ... Perfectly stable though at 9 x 311 with 1.5v
http://img223.exs.cx/img223/9692/2900mhz5tu.jpg
UPDATED! Please Read my First Post for new Links!
Model: (3200
Core: (0.09
Date: (not sure
Stepping: (not sure
Code: (not sure
Mhz: (4000mhz
Gain: (2000mhz
Vcore: (1.55vcore (the a8n-sli overvolts to 1.58)
FSBxMulti: (400X10
Divider: (If thats the ram speed then 200
Cooling: (stock
Stable: (no bios only
Link: http://www.tech-forums.net/showthrea...8&pagenumber=1
