Well, sketchup model would take too much time.
http://i.imgur.com/Wgzb9.gif
I don't think you could use monsoon res, because it allows for parallel setup from the reservoir, so that would be too much. With monsoon your entire loop would be parallel, water from pump would go in 3 directions - rad, gpu block and cpu, all parallel.
With koolance res, you have serial connections. As you can see on scheme, but unlike monsoon res, koolance has two chambers set into serial, so water goes from one half of the reservoir to the rad, then comes back to other half, and from there goes to waterblocks (then splits into gpu and cpu since they are parallel), and comes back to first chamber of the reservoir. Can be used with 1 pump, just the idea is, reservoir is set into serial configuration (sa rad is in serial with blocks, just blocks are in parallel to each other). With monsoon res, and everything parallel flow could drop too bad on highest restriction part of the loop I guess. D5 is strong pump however, so I can't tell for sure, maybe it would work fine.
Also my scheme is not very accurate, as you can see in pic above, reservoir sits in lowest 5,25'' bay, so the loop would look even cleaner than on my picture.
