?btw, with Turbo V Light I have sometimes issues, cant chage the values, must to set back, apply and again set higher value. SOmetimes this cycle is for 3x or 4x. Sometimes OS frozed. Any tips or older versions are better?
M7I+Pentium and Samsung
http://i.imgur.com/NqjMm0o.jpg
http://i.imgur.com/JEgQSCl.jpg
http://i.imgur.com/q4RJXWg.jpg
Colder and moar volts on Impact Power II
http://www.overclock.net/content/type/61/id/2095522/
http://www.overclock.net/content/type/61/id/2095519/
http://i.imgur.com/iXKr4V5.jpg
woah, CPU cache voltage over 2V?!
Gene of Impcat for LN2?:) Any advice? I want not focusing at LN2 memory, only CPU with LN2....
Both boards capable to take it up
So Gene, I need something bigger for better feeling of me :D
Just finished reviewing the M7 Formula,impressive board for sure:
http://bit.ly/1rIXA8C
Someone has an XP UEFI for Z97-Deluxe and Z97-A? :)
Maximus VII formula doing fine 2933 c9 with right mems :)
http://abload.de/img/snaphsot0002iek56.png
M7I, pentium cold and bbse air
From a bunch of pentiums only 3 can do imc with rtls and only 1 can do tight trdwrs. Board and rams go as high as imc can scale
http://i.imgur.com/6aJZDpz.jpg
http://i.imgur.com/8t5jBqy.jpg
PSC 1400 air on M7G:
http://abload.de/img/snaphsot0003als9x5nsua.png http://abload.de/img/snaphsot0004z1sulwfs1z.png
Had to use G3258 for these runs. Same settings with 4770K will need about 0.02V more, but voltage hole at 1400 drops like an anvil from 1.90 onwards on this particular set.
Maximus VII Impact+Corsair samsung,tightest tertiary and lowest volts so far:
http://abload.de/img/samsungimpactkjoxo.jpg
Maybe I should try Samsung since I don't have much luck with PSC and BBSE, I have some 2666C10 Platinums that have gone neglected for some time.
I think, this risk was with cold at RAM? Im so jittery use more than 1.8 V at AIR to DDR3.
Samsung can take the volts.
too many air mem results! someone freeze it already lol :P
Hi,has anyone done any cold PSC on the M7I? Just wonder what its like
M7H and only air testing with Gelid Tranquillo r1
https://farm4.staticflickr.com/3908/...66bc6197_z.jpg
Seems not bad chip :). In last OCCT was very, very hot, I used 3000 rpm fan. But its better than I hoped (my tip was around 4650-4700 MHz).
https://farm4.staticflickr.com/3884/...7c771229_z.jpg
https://farm4.staticflickr.com/3883/...5938422d_z.jpg
https://farm6.staticflickr.com/5582/...e7f901b0_z.jpg
final OC stable 4800 MHz:
https://farm6.staticflickr.com/5571/...51451282_z.jpg
How perform it in CPU part in game? Of course I use lower resolution which is still a bit limited by CPU and very high physics + high details.
First at stock, look at average and lowest FPS
https://farm6.staticflickr.com/5579/...ae9e9a31_z.jpg
After OC to 4800 MHz, not bad, right?:)
https://farm4.staticflickr.com/3884/...37964921_z.jpg
Maximus VII Impact memory madness,samsung DDR3-2933 8-12-12
http://abload.de/img/29338-12-12mkoe7.png
Any news about Asus Z97 Extreme ? ( I see only Z97 Formula ).
