Just 2MHz :D
Just 2MHz :D
Sabuy Sabuy I've seen you try to claim benches on Intel boards as your own so obviously your self-proclaimed 'records' are nothing but fakes. Do it on an Intel board with much more solid proof and maybe it can be passed by as legitimate.
Well that was 250fsb in bios,wich should be 500mhz cl3
yeah :D But FSB set in bios is never accurate :P
Nothing?:P
Well I sell these kit,so I will buy cellshock 9200,so 500,600,650 and 700 club here I come :D
crazy
I want to join this club also :)
Team 9600C5 on Gigabyte P35-DQ6 @ 2.65V
http://i168.photobucket.com/albums/u...5500c3265v.png
Validation: http://valid.x86-secret.com/show_oc.php?id=228788
On 2.7V Vdimm
http://valid.x86-secret.com/show_oc.php?id=228789
Does this count
http://www.xtremesystems.org/forums/...1&d=1187021473
woot i love these sticks they tighten up very nice. just did the vdimm mod for my biostar tp35d2-a7 p35 board. great results figured i would try to get in the club. no memset changes in windows straight from bios.:)
timings- 3-3-3-9-16-14-3-3 at 2.75 volts didnt try higher dont know if i really want to lol. well here it is hope you guys like it.
http://valid.x86-secret.com/show_oc.php?id=235630
is this thread dead or sumthin. hasnt been updated in awhile.
Brand : Buffalo
Model : Firestix FSX1066D2C-K1G, D9GKX
Real Voltage : 2.75V (+0.7 in bios)
Timings : 3-4-4-9 (Sub Timings : Autos)
Cooling : Air (Room Temp 26C)
Frequency : 500.02MHz
Sort of Bench : Valid CPU-Z, & can't test SuperPI :sofa:
Screen : CPU-Z
Gigabyte P35C-DS3R Rev 1.1, Bios F3b
E6320 L648G420
Quadro NVS 280 PCI
Zippy Emacs 600W G1
OK...let the games begin :scope:
3 Steps to 500MHz, CAS 3
1) 498MHz, CL3-4-4-9
2) 499MHz, CL3-4-4-9
3) 500.02MHz, CL3-4-4-9
Updated today, 4th step :D
http://valid.x86-secret.com/show_oc?id=237928
someone should take this thread over cuz hes not updating it. give it to someone who cares about this thread.
Hey sorry bro I've been tied up with a lot of stuff. I'll update this one on sunday.
Dear! Gautam : What r you doing ? :D
My result is 502.5MHz, not 500.0MHz ei ei :slapass:
My apologies Gautam, ThankS :kissbutt:
and the DDR2 CAS2 CLUB??
CHECK THIS OUT! --- G.Skill GBPK (Yeap! GBPK you read right)
http://img168.imageshack.us/img168/6...k22ble5ma9.jpg
settings E4300 @ 3.0 Ghz ( 24/7) with G.Skill F2 PC2-6400 GBPK 4-4-4-12 @ DDR2 1000 Mhz 2-3-3-3 WITH 2.3 Vdimm
CPU - Z
http://img369.imageshack.us/img369/7...1000es3.th.jpg
SUPER PI 1M
http://img401.imageshack.us/img401/9...rdadag3.th.jpg
SUPER PI 32M
http://img369.imageshack.us/img369/7...i32mbf8.th.jpg
EVEREST 4.10 TESTS
MEMORY READ
http://img296.imageshack.us/img296/7...oriakx3.th.jpg
MEMORY WRITE
http://img369.imageshack.us/img369/8...9315nz9.th.jpg
MEMORY COPY
http://img401.imageshack.us/img401/3...9457wr3.th.jpg
MEMORY LATENCY
http://img296.imageshack.us/img296/6...6165gx2.th.jpg
CPU QUEEN
http://img401.imageshack.us/img401/1...4342ay2.th.jpg
CPU PHOTOWORXX
http://img401.imageshack.us/img401/3...3619eu2.th.jpg
CPU ZLIB
http://img296.imageshack.us/img296/4...1171iy4.th.jpg
CPU AES
http://img296.imageshack.us/img296/1...0968if2.th.jpg
FPU JULIA
http://img296.imageshack.us/img296/1...1966bw3.th.jpg
http://img117.imageshack.us/img117/6...iosabh1.th.jpg
FPU MANDEL
http://img401.imageshack.us/img401/6698/10wu2.th.jpg
http://img242.imageshack.us/img242/1...apicsm7.th.jpg
FPU SINJULIA
http://img114.imageshack.us/img114/6803/11qf6.th.jpg
http://img468.imageshack.us/img468/9...gereda4.th.jpg
SISOFT SANDRA 2008
http://img470.imageshack.us/img470/5...ndratv2.th.jpg
MEMORY BANDWIDTH
http://img462.imageshack.us/img462/4594/12yw8.th.jpg
MEMORY LATENCY
http://img379.imageshack.us/img379/3369/13vi3.th.jpg
the rams are settings in UNLINKED,and a little increment of vcore on the NB
( northbridge) for stability.
( I use 1102 STRIKER EXTREME 100% stable bios)
some diferent settings and see how afect in the sistem the changes.( no much better performance)
4-4-4-12 DDR 1000 @ 2.3 Vdimm
18.734s
http://img115.imageshack.us/img115/6...2676ow7.th.jpg
4-4-4-8 DDR 1000 @ 2.3 Vdimm
18.656s
http://img459.imageshack.us/img459/4...4169vb0.th.jpg
4-4-4-4 DDR 1000 @ 2.3 Vdimm
18.641s
http://img459.imageshack.us/img459/2...6040fz0.th.jpg
3-3-3-3 DDR 1000 @ 2.3 Vdimm
18.562S
http://img470.imageshack.us/img470/7...6692kh5.th.jpg
2-3-3-3 DDR 1000 @ 2.3 Vdimm
18.500s
http://img459.imageshack.us/img459/6...1140rn6.th.jpg
3.60 Ghz DDR 1000 @ 2.3 Vdimm 2-3-3-3
15.703s
http://img459.imageshack.us/img459/8...2333hx6.th.jpg
3.75 Ghz DDR 1000 @ 2.3 Vdimm 2-3-3-3
15.282s
http://img459.imageshack.us/img459/7...5282et5.th.jpg
this time with themes disables on services.msc
15.140s
http://img510.imageshack.us/img510/4...5140to4.th.jpg
i waiting for g.skill answer( what chip are here),i'm not remove the heat spreaders ( for now)
the SPD was reprogramated in this rams, with thaiphoon burner
HZ DUMPS
validation
http://valid.x86-secret.com/show_oc.php?id=244992
http://img267.imageshack.us/img267/1...1000ws5.th.jpg
Awesome man :)
@hersounds
That's not CAS3, and not CAS2 as well.
Sorry it's a bug, you're running CAS5 or even more.
hersound, i really like the post with the pics of the celebs :D
but could you please stop copy pasting the same post it into several threads? :P
Hersound, there is something odd about your benchmarks, latency of 52-53 ns is incredible for a 2 MB core 2 duo @ 3.00 Ghz, I could never crack 58 ns with memory at 550 Mhz C5 (and tight sub) but fsb at 440 fsb and CPU at 3.08 GHz, however at 880 MHz CAS 4 I can get a 16 min 04 sec superpi 32 m, while you're over 18 minutes (maybe the low FSB?). Your memory bandwidth is great too, so I'm not sure what to make of this. Looks like high clock cas 3 for sure or very high clock c5, but cas 2 isn't possible with DDR2 (at even 800 mhz).
Cpu zlib for comparison, E6300 Conroe 2 M, 2933 MHz - 489 fsb: http://img524.imageshack.us/img524/4286/snap1ms4.th.jpg
memory bandwidth that gave above score:
http://img207.imageshack.us/img207/1659/snap2oj5.th.jpg
