This is my solution:
http://img227.imageshack.us/img227/9...00367cq.th.jpg
http://img227.imageshack.us/img227/6...00391at.th.jpg
http://img457.imageshack.us/img457/5...00423mq.th.jpg
The radiator, is on the top. ;)
P.s: sorry for the quality..:slap:
Originally Posted by Chicco85
Italians do it better
:p:
Parole sante!:woot:Quote:
Originally Posted by vkbms
Italian components, Italian owner... :banana:
:D
quotoQuote:
ciao
tino:)
check it out, i put in the final choice optie of my 3, refined my fan wiring and took some pics. here is the gallery
r3vo+pc ºº Thermochill PA 120.3 Loop Upgrade ºº
and a few choice pics:
http://img141.imageshack.us/img141/1...side7kg.th.jpg
http://img519.imageshack.us/img519/9...clsd1ej.th.jpg
http://img301.imageshack.us/img301/3...oser1my.th.jpg
http://img301.imageshack.us/img301/1...trun7lm.th.jpg
And finally: the shot on the kitchen table: showing the hot and cold sides of the rad water temps on the aquaero as well as the temps in bios on startup. CABQE for the win!
http://img519.imageshack.us/img519/9...r3vo0js.th.jpg
:D !
Got my Maze4 GPU block yesterday.
I have it all set up now:
http://img215.imageshack.us/img215/9...5medium7bb.jpg
:cool:
True but Americans do it best......:DQuote:
Well guys that's all true but i think you're running out of the thread matter.:)
Hello all :)
i'm french :D so excuse my english :s
It's my computer :
http://pix.nofrag.com/bd/b2/38fa3534...b123d88a8t.jpg
http://pix.nofrag.com/83/6e/8093e1c0...55aac656ft.jpg
http://pix.nofrag.com/d4/32/5dc8a59d...1e94316abt.jpg
http://pix.nofrag.com/a5/29/c4ff8a89...44f83835ft.jpg
http://pix.nofrag.com/3e/b5/f48bd1f4...b9de4b619t.jpg
http://pix.nofrag.com/be/f1/2c9dd90d...0a4fc2828t.jpg
http://pix.nofrag.com/7a/45/f55ca10d...33631a47ct.jpg
http://pix.nofrag.com/bb/73/e81daad0...2db793e81t.jpg
http://pix.nofrag.com/f3/dd/cde4b57c...9d2a59fe7t.jpg
http://pix.nofrag.com/6e/ec/441b19b6...7bef88bd3t.jpg
http://pix.nofrag.com/72/cc/056b279c...c07236ab5t.jpg
-Waterblock CPU 1A-SL3 AMD Socket 754 / 939 / 940 1A-Cooling
-WaterBlock VGA NexXxoS GP2X-N GeForce Alphacool
-Radiateur NexXxos Pro III Alphacool
-Tuyau PVC souple transparent 8mm interne, 10mm externe (Au mètre)
-Embout Métal Droit 1/4" pour tuyau 8mm
-Colorant Réactif aux UV Bleu
-Ultra Quiet Amber Fan 120*120mm AK-183-L2B 18dB, 45 CFM, connect. 3 pins carte mère + Adapt 4 pins + Vis Akasa
-Relais de démarrage pour pompe Eheim
Config :
CPU : A64 3000+ @ 2.7ghz (1.68v)
Mobo : DFI Lan Party Ultra-D
Memory : 512 Xms Xpert XL @ 300mhz (3-4-4-8) change by 2*512 OCZ Platinum Edition PC3500 @ 243mhz : 2.5-3-2-5 1T
CG : 6600GT TDH Leadtek
Temperatures :
Cpu : IDLE : 29° // FULL : 43° by prime95 and UT2004
Gpu : IDLE : 45° :/ // Full : ?
So, that you do think of it?
Awesome setups guys! :up:
El Rolio, your setup looks very cool but i hate the res hanging all loose.
Alex, very nice setup as well but can't you push the tube a bit further on that T- piece?
yes. the MAIN weakness. i have taken the camera home from work every way this week thinkin i would take another pic if i fix wiring more or i fix the res situation, but i havent yet. so by monday night there will be a fix goddmanit. even if i have to go buy velco strips to do it! (wasnt some to come with it?) i tried using hte intake fan holes but it wasnt worth it hmmmzQuote:
Originally Posted by Zeus
Mika123, what's up with that blue fan sitting on the harddrive? doesn't look like it's doing much other then providing light :stick:
http://pix.nofrag.com/7a/45/f55ca10d...33631a47c.html
Originally Posted by james111
Extra HDD cooling maybe?
But I mean, how can it be cooling anything if it's flat against the harddrive :confused:Quote:
Originally Posted by Atomicpineapple
Sweet fek all, especially as the top of the hard drive is very thin, and heat in a drive travels through the base, then the sides, and finally the top...
Yes it is a fan, but I do not still have him(it) to heightenQuote:
the blue leds kinda clashes with the ram led.
If I honestly felt like completely obliterating my hands after having trouble getting it over the fittings for the blocks, I would have gladly done so. But putting it on that far was a nice walk in the park, so I chose that route. I will probably push it on a bit more shortly. :slap:Quote:
I kept getting aweful contact with my GPU so I went ahead and re-did my loop and so far its much much better (8C drop in GPU temps)
http://img.photobucket.com/albums/v1...l/DSC00161.jpg
Sentential
those 90 degree bends are bad. temps should improve more if you got rid of them.
Thought I would add my system to the thread. You guys have great systems. My components are in my sig. Spacing was a bit tight and I had to modify my old school Antec case a bit like moving the power supply down in front. The front bezel does fit nicely since I cut a hole for the power cord run, but the PSU overheats with it on. The airflow for the case has been completely reversed as well with air coming in from the rear and exhust through the front and top.
http://img76.imageshack.us/img76/873...01474lv.th.jpg
http://img221.imageshack.us/img221/5...01488yx.th.jpg
http://img76.imageshack.us/img76/128...01508vp.th.jpg
Elbows are killing the flow of your loop. get rip of them
Nice system!Quote:
Originally Posted by JoeBar
How are your temps?
/Thomas
I'm getting 33'C idle 43'C load with 24'C room temp. 940 @ 4.52ghz with 1.45v.Quote:
Originally Posted by Thomas FJ
7900GTX's temp is 34'C idle, 41'C load but still on stock, hadn't time to oc it. ;)
