Originally Posted by
mean6
I am experiencing the exact same issue. I thought it was from running my ram at the rated speed of 2133. People on the forum suggested to downclock the memory to 1600. I tried it, and I was able to run @ 4.8, ran IBT, no issues, played games no problem. I thought I had the problem solved. Turned off the computer, turned it on the next morning, and got the blinking cursor. I went out and got another board, and cpu (which happened to have the same batch number as the one I was currently using), and tried to narrow it down, but whatever combination I used, it did the same thing. Also, like you, the 43 multi is the only stable setting I can get. Anything over 43 requires PLL Enabled, just to get into windows. None of the preset overclocks will work past 4.2. From my experimenting, I think that it's just a bad batch of cpu's from intel. Not saying they are faulty cuz they work fine at stock, just not very good overclockers. What batch number is your processor?
