did you get this from someone who signed an nda???
if so can you share with us on its legitimacy ????
Just remember that the multiplier on retail versions is likely to be lower, as the program only calculates OC % based on frequency inclease, not multiplier changes (so don't expect 3.7 GHz 8 core retail versions - not at launch at any rate). So the screenshot really only just shows that you can have a lot of fun overclocking BD. :)
I think youre simplyfing it.As it all depends, in general all extremes are not healthy for a cpu.
For instance i had a A64 with only 1.2v passively cooled which was pretty much always at 60-70C, and its kickin to this day.However if you put 1.6v into a phenom II, even good watercooling wont stop it from deteriorating (if you keep it at this voltage constans and put a strain on it).
On the intel side its even worse, i OC`ed my friends core2duo xeon (65nm), it had big ass cooler which kept it at 50C max, however increased voltage deteriorated it in just a year, it was running 3.3ghz, now it barely does 2.3.
The key relation for me is median, between voltage and temperature, if i need extreme measures to cool a cpu, that means voltage is too high for 24/7 operation.Of course benching is another matter, as its just shorts periods of time of higher voltage/temperature.Anyhow, not one of my personal cpus broke or deteriorated keeping it all in some balance.
However getting back to BD, of course whats healthy and whats not, relation between temperature frequency and voltage it all will be determined later.
However if lets say retail BD is able to hit 5ghz stable 24/7 and Sandy is the same at this moment.Its ok, but not as good as i hoped.Its pretty much certain IPC of sandy is higher, so BD needs more clock.
I was under impression SB`s arent really hitting 5ghz fully stable, all i saw was cpuz screens, or 3dmark runs (thats on air).But you prolly know better.I didnt had the opportunity to build SB system yet.
Flank3r hinted that he knew it for fact so... It's starting to look better for AMD (if even OBR thinks it's anywhere near decent...). I'm eagerly waiting for performance numbers since I want BD to be my new build when I get back from Down under after Xmas.
XRL8: right...example, my workstation with x6 1090T, I found maximum stable clocks. It is 4300 MHz aircooled, 1.478V, more voltage doesnt helepd me, but temps are under 60 C. Its OK, I believe it. But If Im not benchmarking, I have saving profile 3975 MHz, 280x MHz NB with 1.31V at CPU and 1.26V at CPU/NB. And still is more performance, than I ussually need :-). Or at second main PC I have utility Phenom mrTweaker, one state is 1.275V and 3 GHz and second state 1.475V and 4 GHz at x4 970 BE (with newest version man can make think 3 or 4 P-sates).
I might take it wrong but are you hoping to hit 5GHz on 8 cores stable for them to sit idle and run single threaded workloads to allow SB outperform it?
I agree SB ST performance most likely will be higher at the same clock than BD's, but BD strength should be MT. AMD focus for BD is on MT and scalability.
I see it like this:
if BD really can hit 4.8-5.x GHz on AIR stable for all 8 cores under load then it's great and will have amazing performance in MT. Scaling 8 cores to that speed is harder than 4. Just look at Intels SB vs Gulf. 6 core monster scales up to 4.4-4.6GHz on AIR.
When ST performance is your goal I bet you can squeeze extra few hundred MHz out of BD max MT clock.
Youre comparing it as if 8 BD cores were fully comparable to 4 intel cores with HT.They are not, its different approach.
Gulftown is based on older tech than SB, and less (probably much less) mature process, so again i dont see it as viable comparison.
AMD positions 8 core BD`s to 4 core SB`s , so thats where comparisons have to be made.Its more like 4 modules vs 4 cores.Or 8 cores vs 8 threads.
One AMD core is much smaller than one SB core.So its pretty much destined to have lower ipc.Thus it would be expected of them to reach higher clocks.
And its been known for some time that BD is architectured as high speed cpu.So its not unreasonable to expect it reach higher clocks.
I hope for fully customizable turbo.If i can set 8 cores to 5ghz, then maybe 5.5ghz in single/dual threaded work.That should help.But its yet to be known how turbo v2.0 works.
Why should i have a problem comparing mature 32nm of intel vs unknown 32nm of GF ? Its about whats available in the market for comparable price.
What i read 4 module BD is ~250mm2 ,Sb is 216mm2 , so thats not a huge difference.But getting back to the point.Its irrelevant how big it is for a consumer/enthusiast/oems.Price, and power consumption.Thats what matters.
Price/performance/power consumption.And im just hoping BD is comparable.And secretly i hope BD is going to be better than SB.
Zambezi 8C should be closer to 290mm^2 than 250mm^2.
Sorry, but this doesn't wash at all.
AMD will position itself against a comparable Intel chip. The amount of cores/modules is irrelevant compared to the results that it gives.
That statement is actually quite incorrect. SB cores are larger because of the overhead of HT, while BD can be relatively smaller due to the sharing of resources wihin a single module. IPC in this respect has nothing to do with core size.
This is down to the pipeline really, not the size of the core.
True, the BD cores are known to be higher in speed, due to the longer pipeline. However, this is a brand new chip and is an unknown with regards to speeds reached. I highly doubt you'll be seeing 5ghz in ST, let along MT.
I think you're taking the BD chip as some sort of messiah for AMD. What it is is a very capable MT chip. If its IPC is anywhere close to Intel, and the speed of the chip can exceed intels offering, then they'll have a good solid chip for the next 4/5 years to work with. I am not holding my breath on this, as I still see AMD as a low-med type of company (GPUs of course a separate issue). I do think it's MT performance will be quite spectacular due to the amount of cores it can have. Desktop wise, I still feel Intel will have the upper hand (something that a lot of fanboys will find quite distasteful to hear).
Uhm, thats what i said.AMD isnt positioning this above SB ,its not aiming at SBE,AMD positions this against 2600K (the highest AMD FX).
And while amount of cores/modules is irrelevant/The results are.They can however differ very greatly (one app a win for amd ,another for intel etc.)
While Core size isnt some defining metric, its logical to assume amd wont pull any miracles, if core is smaller than SB (and it is) than its safe to assume it will be weaker.
HT and sharing resources is another thing, and more relevant to the MT tasks.Thats why we cant expect stunning superpi performance ;-).
Ergo, i dont agree that core size has nothing to do with performance that can be extracted from it :P.
As for the speed, yes pipeline is longer thus its a high frequency design, however the smaller the chip the easier it is (its smaller than thuban thats for sure)
Well, im already seeing 4.8ghz from three sources.So i dont think that 5ghz from retails isnt possible.Its not even a stretch,and thats MT.Quote:
No im not.If that was the case, BD would have 8 comparable to SB cores with greater overclockability, and i dont think thats even possible.Quote:
However it can be "smart" enough chip to be comparable in ST, and have upper hand in most MT.
Desktop wise, theres really small amount of apps, that need ultra strong x87 FPU performance.From top of my head i can only think of superpi and pcsx2.
In the rest differences, while may be there, are just academic.In games, we are pretty much always GPU limited after certain threshold.
And now games are moving to MT.Everything is slowly moving to MT.Sysmarks and similar software are pointless benchmarks for 99% of population.
And so on.Only MT performance still matters much.Multitasking, compression, encryption, video encoding, seti and similar software.
@Informal
Last i read, there were estimates of ~250mm2.Maybe im wrong tho, could you point me to a source of this 300m2 estimate ?
@Informal
Hans Devries arrived at a 300 mm^2 estimate from comparing common elements between the photoshopped die shot and that of Llano whose die size was known.
More recently, at the 2011 ISSCC conference AMD published 3 papers on BD. One was specifically about the module and it quoted 30.9 mm^2 for a single module. Another paper had a complete unadulterated and non-photoshopped die shot, from that one would estimate 285 mm^2 or 297 mm^2 depending on whether AMD considers the VSS gating block as a count in the total module area. Regardless, Hans was pretty close.
~30mm^2 more than Deneb, thats great for 4 more "cores" regardless of IPC.
2 module BD's should be around ~160mm^2 then, they really did manage to shave off a lot of die with the new shared design.
LOL @ all the assumptions
¨Need some software for benchmarking and support AVX instruction (bench x264 4.0 has it?)
I remember seeing somewhere some benches of SB in Linpack with and without avx.
here, found this: http://www.numberworld.org/y-crunche...n_history.html it supports avx on non intel cpus
Edit
http://www.numberworld.org/y-cruncher/#Download
for downloads ;)
Googlish:
http://translate.google.com/translat...-sonuclari.htm
BD 8C@3.2 GHz
http://www.abload.de/thumb/bulldozer...a_dh_fwv3u.jpg http://www.abload.de/thumb/bulldozer..._dh_fxm49k.jpg http://www.abload.de/thumb/bulldozer..._dh_fx45nz.jpg
http://www.abload.de/thumb/bulldozer..._dh_fxwvg5.jpg http://www.abload.de/thumb/bulldozer...a_dh_fj16j.jpg http://www.abload.de/thumb/bulldozer...a_dh_fo52u.jpg
http://www.abload.de/thumb/bulldozer...a_dh_fj30p.jpg http://www.abload.de/thumb/bulldozer..._dh_fxm2wj.jpg http://www.abload.de/thumb/bulldozer..._dh_fxocqe.jpg
power consumption
idle ~2600K 97W
load -10W than 990X
Turbo
4C up to 4.20 GHz
8C up to 3.60 GHz
Memory subsystem is all over the place. Look at the latency of L2. double of that of my thuban.
And superpi again :shakes:
At least it is kicking my thuban @3.9ghz by 3k points in cinebench 10
and loosing in PC mark to my 3.9ghz thuban by 100points
and about the same as 4ghz thuban at chess benchmark
and wins by 2fps in physics score on 3dmark11
Is that QR Code on the CPU?
If so, any1 here have QR Code Reader Software on their mobile so we can decode it?
