added 1104 bios to front page.. Good job guys on letting asus know about our issues. any word as if they will include this in all there updated bios's from now on?
thanks asus for the bios :D
http://pics.mwirths.de/pics/thumb/06_28858.JPG
I have a problem with booting.. since i have installed a second gtx295 only after a few resets my screen kicks in.. anyone know how i can solve this ?
I had to run 2 instances of LinX each 20 loops to get to 79-80C but all seems fine, no bsod here :up:
Tested with my DMM and this is what i've got, LLC auto.
@ Idle:
-Bios set: 1,425v
-Bios read: 1,422v
-CPU-Z read: 1,416v
-DMM read: 1,425v
@Load:
-CPU-Z read: 1,416v
-DMM read: 1,462v :eek:
Same thing I saw...a 0.05 negative loadline.
1.352 bios
1.352 windows
1.394 DMM when loaded. [LinX]
the loadline thing
is the same for all asus 16phase
i had the same thing for m2f and re
only diff the increment was slightly around 0.0125v or so .
hey busta i am doing a test atm in and out of the casing and different kinds of load on the pwm and also the qpi/dram voltage card
inital result shows that in the casing.. theres definately a need to have active cooling on them
the qpi/dram card was freaking hot on linx and especially memtest hci .
now the koolance full coverage looks appealing with them adding the qpi/dram voltage card block as well
t_flight intead of posting here y not u guys just pm between
cause nobody really cares about that corsair issue
but i would really like u to give a feedback for the bios
did the function have a negative impact for the 965xe
that would be the first positive thing uve said so far other than all the negative post including about asus engineers etc.
we can feedback more things to them
since this the tdp has some initial result
ive started asking them about the cold boot and psu correlation.
my intial impression it has to do with the phases on the pwm and the qpi/dram voltage card.. just a gut feeling
Thats an interesting finding cstkl1, my set up is on a benchtable, no case... I might pull off the heatpipe assembly and re apply tim to everything.
Though with the 775 version REX, this was an issue, maybe same applies here. Have you got a link to that block please?
The loadline thing doesnt concern me tbh, its good to know. awareness is half of the battle.
Where is this on the board? the qpi/dram voltage card? im assuming its the chip under the ram just above sb sink?
Now, back on topic...
I do not know why everyone is getting worked up over the slight overvolting the board does. For me this is no more than 0.03V so I just conciously compensate for that. No need to get your panties in a bunch :p:
My part number though is different than most (or rest) on this board and is posted somewhere early in this thread. Maybe that is why my overvolting is lower? If my memory serves me well my part number is 90-MIB6L0-G0EAY10Z compared to everyone else's 90-MIB6L0-G0EAY00Z. In any case, voltages under idle and load are some of the first things that I checked when I got the board and it is good practice for everyone to do that, so to those that did not do this they should really make this a habit. How else would you even know that your board is running within desired specs otherwise?
In terms of the cold boot issue I have started to experience lately again, I am doing some testing on memory timings at the moment (not the basic four timings, but other timings) and so far I seem to have eliminated my cold boot issue.
We'll see what happens when I tighten things further. Right now I set my default timings for 1804MHz as 8-9-7-19-1T and the rest of advanced timings according to what gets set when I use the X.M.P. profile and the cold boot went away.
I am still convinced that at least in my case the cold boot is DRAM related.
ive reapplied the tm and now blasting my 2hp aircond towards the bench rig in the room to lower the temp and see whether theres a difference after a few hours.
the qpi/dram card is under the rog logo.
advice ppl please use some finesse when u try to remove this card.
the koolance block is on their webby
for the qpi dram its a addon
but the bits power seems to be one piece block but with a hefty price tag.
This is the only board that I haven't stripped the NB/SB sinks off and re done the TM, I really cant see it dropping temps that much, if any?
nb cooling on stock doesnt much of a difference
unless
this is what happened to me
uncore 4000 vtt 1.48 heck did a 5 hours memtest on it nb temp 57C
put into the casing bsod when the temps reached 60C
placed a 40mm fan on it bsod after 1300% but nb temp now 57C
i was like wtf
took out rog logo open the side panel casing
placed a coolermaster crossflow fan ( the one that they used for the 830) yup its a big long fan.
uncore 4000 vtt 1.48 passed memtest hci 5 hours.
just want to share on my config.
which is y i think the ek block for the nb/sb is stupid
the bits power and the new koolance might proove something
the cons of my assumptions
i didnt take in consideration it could have been the pwm's as it heats up pretty much and the heatpipe is just running along to the passive cooled heatsinks under the qpi/dram card.
If this assumtion is correct then it would explain a lot. nb and sb are ok on my board the temps are good even under load they are not bumping up too much.
im just gonna take that rog logo thing off and have a fan blowing on the qpi/mem voltage card and see how it goes.
