Dudes, anyone using this board with 20x200MHz and HT on?
It seems to be real hard to get it stable with HT.
Real hard task here too. But it varies for me from day to day, depending on different variables. Sometimes the system can not boot. Sometimes I can test with Linx a while :shrug:Quote:
Yeah, its a real hard task. Some people calim to have it stable, but i question that.
EDIT: 20x200/x36/x12/x6 is very easy. The real problem is for me 20x200/x36/x16/x8. Increasing the Vcore is what helps me
I wonder if the 20x200 issue some are having is i920 related or just certain cpus. My i940 has no problems whatsoever with 20x200 or 20x205 or my 24/7 of 21x200. 20x200 prime 9 hrs stable with uncore 17x, dram 1.64, qpi 1.33, vcore 1.35bios, qpi pll, ioh, and cpu pll all +1 notch over stock.
Though I dont have problems with 20 multi, I do have issues with 22x multi, the stock of my i920. Using it I need about 5-6 notches higher vcore for same Mhz over 21 or 23(turbo) multi.
Can someone please post links for the following UD5 BIOSes:
F4J
F4M
I've looked everywhere, and all I can find are these for the Extreme. I need them for the UD5.
Thanks!!!
http://www.station-drivers.com/
usually has a lot of bios files.
Still pushing it, now that I have a non-RAID XP SP3 install to pound into the dirt. Second and third shots not really any faster clockwise, but fairly decent benches none-the-less :)
so who has 20x200 with HT on 64bit stable?
One last try - need to re-load this up tonight...
Anyone have F4j or F4m for the UD5? Post or send me a PM if you have it, and I can link it here, etc. I'd be happy to host these (since they are considered the best to use), as well.
looking sexy rev
@Safan80, takes 1.425 vcore to hit 4ghz HT on seems like an A stepping thing to me extra voltage with HT.
any ideas and breaking through 215bclk
Vcore 1.5*v 1.6** vqpi/vtt 1.7*vdimm (not giving exact because I dont want you to try and ruing your chip ;) )
Maybe upp the pll a bit? was at 1.8v
http://img525.imageshack.us/img525/7...iwetzo9.th.jpg
try 1.9 pll
here's some settings you can try if you are having trouble.. you should be able to use lower voltages though
http://www.xtremesystems.org/forums/...&postcount=815
There is my allmost stable 20x200MHz settings:
CPU is 965EE ES(C0) and board is UD5 with lowsy F5a bios, memory is 3x2GB PC12600 CL8 Corsair Dominators.
http://bulldogpo.wippiespace.com/Tri_way_i7.jpg
http://bulldogpo.wippiespace.com/GA-...00MHz_HT_1.jpg
http://bulldogpo.wippiespace.com/GA-...00MHz_HT_2.jpg
http://bulldogpo.wippiespace.com/GA-...00MHz_HT_3.jpg
http://bulldogpo.wippiespace.com/GA-...00MHz_HT_4.jpg
Thanks for those settings they didn't help.I think my 920 hates qpi/vtt higher than 1.180 .Now i am unsure if i need to try another 920 or another x58 board.I have pretty much given in and settled with 21x170 (3570mhz) seems to work fine ,i suppose thats not bad but i was hoping for much higher.I might wait to see if a better bios comes along but i don't think that will help,i guess some 920's have better yield unicore clocks than others.
tried F5a for the UD5 today.....gained ~40mhz on the cpu with much lower Vcore...
also better Qpi - uncore clocks....
allaround seems better than the F4f i was using till now..
Both UD5 - Extreme....
http://forums.tweaktown.com/f69/giga...st-bios-28441/
just use Q-flash yes..
