Basic timings are the first 4 you mention.
All the rest is not so important to mess around, unless you are a hard OCer and want to optimise your ram to maximum.
@RASTAVIPER
Thanks for this, I'll try it as soon I go back to home as I'm in the work now ( only 13 minutes to finish )
New bios! 0703 is now available from:
ftp://ftp.asus.com.tw/pub/ASUS/mb/so...3A79-T_Deluxe/
Haven't tried it yet.
I wasn't able to find release notes for this BIOS. Has anyone seen any?
From the ASUS forums:
[ 0703 ]
01. Support ACC with AM2+ 45nm CPU.
02. Improve the system performance when use certain CPU.
03. Fixed System may show Boot fail message if ACC enabled.
04. Fix the problem that AM2 CPU Vcore voltage may be incorrect if change CPU voltage in AI Suite.
05. Fix the problem that AI_NAP may not work after resuming from S1 or S3.
06. Set the value of "Processor Frequency Multiplier" option in bios up to 35 for certain CPU.
07. Support new CPUs. Please refer to our website at: http://support.asus.com/cpusupport/cpusupport.aspx
(ACC is a overclock technique which can adjust the voltage and frequency for AMD CPU directly under OS)
So far so good:
http://img9.imageshack.us/img9/6605/0703cpuzjg4.jpg
If you don't mind can anyone post some pictures using aftermarket heatsink and this board trying to see how close it comes to ram slots, looking to grab corsair 1066 ddr2 with fan to see if fan will be able to fit without hitting heatsinik :) thanks
come someone also take a pic of stock phenom II 940 BE heatsink, im trying to find out if it has heatpipes
Yep it does :)
"yes" it does... at least better than on 0602 and 0701..
i can post with acc on auto or +2% on all cores (havenīt tried much more).
but booting windows with acc enabled does not work that well.
i could get into windows with acc on auto, but coretemp canīt read the cpu temp then. and when i opened aod to check temps i got a bsod.
I have ACC enabled in BIOS ACC set on all cores with +6......
http://img17.imageshack.us/img17/1690/17047243vi1.png
And I got my usual 25 degrees "bonus" temperature on my CPU readings (both in AOD and SpeedFan) when I enable ACC. Maybe it is some kind of strange offset/error reading, and the CPU has normal temperature?! But it ain't fun beginning :( to overclock with a idle temperature at stock frequence hovering around 73+ :eek: degrees...
I give up on ACC! I have tested every bios available (including a couple of betas), and ACC simply doesn't work! :down:
But, other than that, 703 seems to be a stable bios, perhaps with one or two degrees hotter temps than previous!?
Yeah it sure is. I can hit 4GHz now with my 940BE where I couldnīt even touch it. But I donīt c any temp dff.
they shouldn't put ACC supported for am+ 45nm if it's not going to work right ever >_>
I've tested my chip with 1.70 volts it throttle at 72C it will kick down the multiplier to 4 so it will be 800mhz for a few seconds. Did you turn off cpu tweak ? my 9850 hated cpu tweak like 6-9C hotter with it enabled.
Since the new PII have them built in, I wonder by doing it this way through the bios over rides what is already built into these new chips? :shrug:
I could never cold boot right up from bios with these settings before. I was able to reach them through AOD in windows
And I got 72C everything default :shrug: with ACC enabled... (Yes, CPU tweak enabled, but thats only a couple degrees which I presume give a good performance boost)
I wonder if this MB can handle a PII 940, which I eventually plan to get, or if something is wrong with my M3A79? On the other hand, it overclocks fairly well without ACC, and is rock stable... :rolleyes:
What temperature readings are other people getting with ACC enabled compared to it disabled. Does anyone get the same temperature deltas (+25C) as I do?????
ACC Works exactly the same as the Beta701 for B3.
It may even be more stable.
Allows same High overclocks as preveouse 701.
Even the Supi 1m is the same speed as 701.
ATm i have not tried for 300HTT. All previose bioses are bugged with my 9950chip and will show 3800ghz after 293htt:confused:
0703 installed on first try and all voltages appear to be the same.
0701Beta
http://i168.photobucket.com/albums/u...biosM3A79T.jpg
0703 Official
http://i168.photobucket.com/albums/u...79Tpirun1m.jpg
AOD 0703 ACC +4/ CPU TWEAK/ Idle 35c /Bios reads 34c @ 1.74vcpu/1.66vNb@2630
People with PHII should notice (stability and possiable higher Overclocks) when using higher NB/Ram settings.
This does perform better than the 0701Beta with B3 . I dont have a 940/945 yet:mad:. Do not expect a huge Oc increase with 0703 over the 0701 Beta if that what you had before,, its more or so tweaked for stability with PHII ACC SHOULD NOW WORK. If it dosnt at first try lower voltages with ACC(not Higher) :yepp:
