I knew there was something not correct here... thx for the info sir...
Hi.
Did any of you who have tried 0901... experienced a huge CPU temp drop??
I had 0704 and 1,44 vcore with 35º @ iddle,... now I have about 15º less !!!
I haven't upgraded my H2O cooling and these temps are confirmed by Everest, Coretemp and RealTemp. Room ambient temps are just 2ºC less, around 26ºC.
I don't know what to say ... :shocked:
Regards
Hi everybody, My first post here :)
Got my P5Q deluxe yesterday and found the bios a bit of a step up from my AW9D-Max to be honest.Googled this thread and have found it a godsend, some great advice, thank you :up:
Got a couple of questions
Heres my settings and results so far, how do they look?
Are my temps ok?
Would i be better with some PC2-8500 ram?
Any advice would be great :D
umperFree Configuration Settings
AI Overclock tuner: MANUAL
CPU Ratio Setting: 9X
FSB Strap to North Bridge: AUTO
FSB Frequency: 450
PCI-E Frequency: 101
DRAM Frequency: 901
DRAM CLK Skew on Channel A1: AUTO
DRAM CLK Skew on Channel A2: AUTO
DRAM CLK Skew on Channel B1: AUTO
DRAM CLK Skew on Channel B2: AUTO
DRAM Timing Control: AUTO
1st Information :
CAS# Latency: 5
DRAM RAS# to CAS# Delay: 5
DRAM RAS# Precharge: 5
DRAM RAS# Activate to Precharge: 18
RAS# to RAS# Delay : AUTO
Row Refresh Cycle Time: 55
Write Recovery Time: AUTO
Read to Precharge Time: AUTO
DRAM Read Training: AUTO
MEM. OC Charger: AUTO
AI Clock Twister: AUTO
AI Transaction Booster: Manual
Common Performance level 10
CPU Voltage: 1.23
CPU GTL Voltage Reference (0/2): AUTO
CPU GTL Voltage Reference (1/3): AUTO
CPU PLL Voltage: 1.6
FSB Termination Voltage: 1.32
DRAM Voltage: 2.1
NB Voltage: 1.26
NB GTL Reference: AUTO
SBridge Voltage: AUTO
PCIE SATA Voltage: AUTO
Load Line Calibration: Auto
CPU Spread Spectrum: Disabled
CPU Clock Skew : AUTO
NB Clock Skew : AUTO
Advance CPU Settings
CPU Ratio Setting: Manual
C1E Suppport: Disabled
Max CPUID Value Limit: Disabled
Intel® Virtualization Tech: Disabled
Vanderpool Technology: Disabled
CPU TM Function: Disabled
Execute Disable Bit: Disabled
[IMG]http://img131.imageshack.us/img131/4373/16947791pm1.jpg[/IMG]
Looks great Sativa, good CPU too mate, nice clocks at low volts... small question you are running 1:1 yet in ya template you set 1081... second question you mention LLC disabled yet Vcore is 1.23 and real Vcore under load also 1.23... sure LLC is not on AUTO or ENABLED ? I need to set about 1.3 to have 1.24 without LLC...
Only thing you can improve here is to play a bit with the PL levels... since you are running 1;1 and Transaction Booster at AUTO PL level is set at 13... you can lower it to 10-11 and get a good increase in bandwith and a drop in RAM Latency...second thing you could do is to play with the clock tiwster... try moderate instead of AUTO and test again...
Good Job mate !!
Thanks mate :)
Edited my above post was a copy and paste job from a previous post missed a few.
My DRAM frequency should of read 901 and my LCC was on auto.
Also my Common performance level was set to 10.
Will have a play about with clock twister thanks.
One thing though,Bit of a noob question, Vista now takes a long time to load, about 20 sweeps with the green bar , do you think thats down to the overclock?
I have a friend with the P5Q Pro and is having the same problems as this person is, gets errors using both EZFlash and AFUDOS, used various tags with AFUDOS. Has there been any response to this, I did a little browsing and didn't find an answer to this, sorry if there is one. Thanks.
EDIT: He just told me that he tried both methods with 0703 (official from asus) and also to the 0901 (the one he want to install) and nothing worked ...
Ok I just got 2 640GB WD Caviars and put them in the EZ Backup setting (RAID 1) and tried to install Vista. I got to like 56% and then I got an I/O error 0x8007045D so I researched and thought it was my CD drive. Took me forever and 2 trips to best buy to get a Sata drive, but it still doesn't work. I'm on the verge of a break down, I can't take this. I am very depressed.
Hey all,
EDIT: Nevermind. I'm an idiot. :)
Using some settings I copied off some templates here I just got this.
:up: I know I can go to 4Ghz.
http://i193.photobucket.com/albums/z...ecordforme.jpg
Here is 8x 490 3.925Ghz
http://i193.photobucket.com/albums/z...r1/damnair.jpg
Bios 0901 here ... all ok till now. Didn't noticed any performance diference from 0803.
Have it like this for now :
http://img161.imageshack.us/img161/5...18800piqv2.jpg
Notes:
- a little bit more of vNB as reported by Leeghoofd ( must do some DMM readings )
- still no PL=7
- still 1200MHz was a no go here with 450fsb:
@ 1203MHz (strap 400) = no boot at all
@ 1199MHZ (strap 333) = crash entering windows
@ 1128MHz (strap 266) = OK using only 1,9vDIMM ! ;)
:up:
I had this board, but i have some problems: i can't reach 600fsb.
my 8400 on a commando reached 610x7, but with this board it stops at 580x7...
what is the better bios in max fsb? now i had the 702, i tried also the 704...
i have an other question: how does the clock skew operate? how can i know what is the component that is in delay respect the others?
sorry for my bad english!:rolleyes:
Guys, the values of overvoltage of this mobo, that the jVIDIA posted a few days ago, is occurring in the same way in these new bios?
You check bios 0803, jVIDIA?
thanks!
No I didn't measure yet 0803 or 0901.
I don't know I don't have a voltmeter. I just bumped everything a little from stock sos not to have that happen. The highest clock on air for me seems to be the 8x 490 I reached last night. I can run my 24/7 3.8Ghz like I wanted to now though :up:
as a few of ya guys here may know im kinda new to the OCing world, and i see a few other new members (not saying they are noobs) could some one clear up some terms for me?
PL=
LLC=
and anything else?
PL = performance level : it's a setting that influences the rambandwith, latency, it's value is dependant on the ram you use, type , amount, FSB selected : in fact the lower the better : Expect with this board around 9-10 with 1:1 divider, 7-9 with a divider (eg 3:4,...)... try to get the lowest value for best RAM performance
LLC = Load Line Calibration : eliminates Vdroop/drop so setting in bios corresponds with the voltage value given to the CPU under idle/load. To clarify an example :
In bios set 1.4, without LLC it will be around eg 1.37 in Windows at idle, around 1.34 under load... With LLC enabled you set 1.4 and it should give 1.4 under load and idle... I said should as this board slightly tends to overvolt under load with LLC enabled...
Hope it's is somewhat clear, I don't use magical technical terms as I don't understand them and mostly neither of you...
What are the pullins?
Hi all:) my first post on this forum
I overclocked E6600 to 3.2Ghz with bios memory settings on auto and i have high latency in everest test. Can anybody help me to tweak it to get a lower latency, please.
AI Overclock tuner: manual
CPU Ratio Setting: 8
FSB Strap to North Bridge: 333
FSB Frequency: 400
PCI-E Frequency: 100
DRAM Frequency: 801
5-5-5-18-3-52-6-3
8-3-5-4-6-4-6
14-5-1-6-6
DRAM Static Read Control: AUTO
AI Transaction Booster: AUTO
PL 13
CPU Voltage: 1.28
CPU GTL Voltage Reference (0/2): 0.63
CPU GTL Voltage Reference (1/3): .67
CPU PLL Voltage: 1.52
DRAM Voltage: 1.82
NB Voltage: AUTO
NB GTL Reference: .63
PCIE SATA Voltage: 1.5
Load Line Calibration: enabled
CPU Clock Skew : auto
NB Clock Skew : auto
CPU Ratio Setting: auto
C1E Suppport: enabled
Intel® Virtualization Tech: enabled
Execute Disable Bit: enabled
Alot of it is the PL setting youre using I think.
DRAM Static Read Control: DISABLED
AI Transaction Booster: MANUAL
PL 10 - 9
CPU Voltage: 1.28
DRAM Voltage: 1.82
NB Voltage: AUTO --> Overvolts set 1.26
If these settings are stable (try PL 10 first, test thoroughly, then try 9 : 9 could be a no boot) : play some with the AI CLock Twister ; try eg moderate and see if it has any effect on latency and or stability
