This sometimes dont work for all
Use latest BIOS
Use lastest Beta drivers
enable Plug & play in BIOS
change the slot of the sound card
Thanks for the reply slim. Ive just installed the latest BETA drivers from creative - makes no difference. Plug & Play is enabled (i made sure of that - think i read it in one of your previous posts) and I cant change the slot for the sound card due to the 2nd GTX getting in the way. Im gonna update the bios in a bit, so will see if that works.
Well, just flashed to 0804, and it solved the problem! So far so good... will start some overclocking soon :)
They are some pretty good results there, those temps are pretty good. Im hoping to get mine up to 500 FSB also, im just waiting for some watercooling.
Im still trying to decide whether to use the standard water cooling for northbridge or buy an aftermarket cooler.
2 Main problems that may help.
Nvidia nforce_winvista64_15.17_international drivers cause frezzing under COD4.
Nvidia nforce_winvista64_9.64_english_whql drivers work 100% For My Setup.
BFG 9800GX2 174.74 Video drivers work 100%
BFG 9800GX2 17x.XX Video drivers cause frezzing or driver has stopped working & has recovered.
Hope this helps maybe a few people....
sorry i didnt really post much information about those screenies, im using bios 0704 and i had my voltages set to
Vcore - 1.50000
LLC - enabled
Ram - 1.86 (overvolts to 1.90)
NB - 1.70
SB - 1.65
PLL - Auto
(All GTLREF Settings are set to AUTO)
the settings werent 100% stable but i never did any tweaking on the gtlrefs or the pll so im hoping that it might be possible to bring some of those voltages down and get it stable too but i think it might need to much voltage for that kind of constant fsb.
i have my cpu, nb and mosfets under watercooling on seperate loops. cpu is on EK Supreme and 120.3 thermochill rad and the motherboard is on EK blocks and a 120.3 both have push/pull fans and shrouds. i have an HR05 SLI on the SB
whats a good program to find the NB temps? can only see the MCP in everest but at 3.8ghz idle its at 39c which aint bad really.
Theres an issue with X-Fi and 4GB memory, as far as i see, you have 2 GB so I don't think thats the case.
Altough you could download and try the latest driver from Creative wich has this issue solved.
Another thing to try is to swap the X-Fi to the other PCI slot.
edit: OOPS didn't see the last page :D
Can someone provide a working link to a safe 0804 download?
I shipped my S2E back today for a replacement, the only thing I can think of is that maybe the 0804 that I had downloaded was corrupted or something to begin with because I had used EZflash twice before with no problems.
Went from stock to 0704 with no problems and then to 0801 with no problems either.
Finally got my system stable (20 hours)
thought SLI issues were fixed with videos (hills have eyes played with no problems)
Played X-men 3 (1080p matroska) and after 1 hour, everything was fine while I was surfing the net and then
BSoD
Machine_Check_Exception :bsod::bsod::bsod::bsod:
:brick::slapass:
So, I am happy to see that all the EK waterblocks needed for the S2E are the same as the Rampage. I spent alot of time watercooling the Rampage, and now I am thinking of moving those blocks over to the S2E.
However, I was curious if anyone knew what Thermalright mosfet coolers work on the S2E. I tried the HR-09U-TYPE2 on the Rampage, but discovered that they don't completely cover all the mosfets. Half of one mosfet, and 1/4 of another were exposed to air.
If not Thermalright for the mosfet cooling, then what would everyone recommend? I don't want to watercool both of my boxes. I want to aircool one and watercool the other.
Also, does the EK-NB/SB ASUS 1 (southbridge block) interfere with the installation of 2 GTX280s?
ok guys, looking for some pointers again. I cant get this board to clock my CPU at all. Ive had this CPU in both a rampage formula and DFI P35 UT T2R and it does 4ghz @ 1.31v in both - 12hrs prime stable. This board wont even boot into windows @ 1.375v. I got the ram linked + synced @ 1600mhz (CPU is 10x400). NB ive had up to 1.6v, SB 1.55v. Ive seriously loosened all memory timings. LOL!
Any ideas?
Well lately, I ran prime95 again, the Small FPU tests ran fine, But if I use Blend, The system falls flat on its face and whines like a baby, But OCCT passes fine too. So I don't get it. Is there something wrong with my memory or motherboard?
Okay, I'm going to ask the dreaded question. . .
Do the reference 790i boards have the "SLi game freeze" issue? Cuz I'm running out of my 30-day exchange window. . . and I'm starting to lose hope that this will be resolved within that time-frame. The fact that others have resolved it but I have not been able to do so given nearly identical hardware and the same BIOS, drivers, and settings leads me to believe that I might need to start considering other alternatives.
So, basically, is the "SLi Game Freeze" issue isolated to the Striker II Extreme or am I just as likely to experience it on other 790 Ultra boards?
I really want to like this board. But at this point, I'm about ready to return/sell my motherboard, CPU, and RAM, and just go back to the ones in my sig.
Tyke... would be good to see some pics of that if you can post any?
As to my CPU overclock problem... I have something to run past you guys. Are the vcore sensors accurate on this board? Only I know exactly what this CPU takes to do 4ghz on 2 or 3 other boards (around the same). Anyway in in a fit of frustration I pumped 1.38v through the CPU. Bam... much more stable.
Just by chance I happened to load CPU-Z up at that point, and it reported the voltage at 1.296v (not the 1.38v everest/bios was reporting). This seemed a little bit of a co-incidence as it was very near my old stable voltage, and the CPU was much better behaved. Anyhow, being a bit skeptical I installed speedfan... and guess wot... it reported 1.30v! LOL! Anyway, i upped the voltage so that both speedfan & CPUZ report 1.32v, and guess wot... its looking pretty stable!
To me this indicates bios is reading the voltage massively inaccurately as is everest. If I hadnt used this CPU on other motherboards I probably wouldnt have even questioned it. Here is a screen grab to show u guys:
http://img374.imageshack.us/img374/6581/voltagenp8.jpg
Does seem very strange, and im wondering if anyone else has come accross it. I dont have access to a DMM right now so i cant confirm it that way just yet.
Anyone know if the ASUS 4 works on the S2E's SB? I have the ASUS 4 for my Rampage, and didn't want to have to buy the ASUS 1 unless absolutely necessary.
For all your EK block questions...
EK Compatibility List
