Q6600 G0 VID: 1.2750 unlapped w/ MX-2
Thermalright Ultra 120 Extreme unlapped
Maximus Formula NON-SE
HIS HD3870 in Xfire
Corsair HX620
Alright I started overclocking today and tried to use similar settings that I've seen thus far. I started with a 3.2GHz overclock. Didn't mess with the memory settings yet at all until I figure out my CPU clock. Here are the settings I used if I recall:
Extreme Tweaker
Ai Overclock Tuner : Manual
OC From CPU Level Up : AUTO
CPU Ratio Control : Manual
- Ratio CMOS Setting : 9
FSB Frequency : 355
FSB Strap to North Bridge : AUTO
PCI-E Frequency: 100
DRAM Frequency: DDR2- AUTO
DRAM Command Rate : AUTO
DRAM Timing Control: AUTO
CAS# Latency : AUTO
RAS# to CAS# Delay : AUTO
RAS# Precharge : AUTO
RAS# ActivateTime : AUTO
RAS# to RAS# Delay : AUTO
Row Refresh Cycle Time : AUTO
Write Recovery Time : AUTO
Read to Precharge Time : AUTO
Read to Write Delay (S/D) : AUTO
Write to Read Delay (S) : AUTO
Write to Read Delay (D) : AUTO
Read to Read Delay (S) : AUTO
Read to Read Delay (D) : AUTO
Write to Write Delay (S) : AUTO
Write to Write Delay (D) : AUTO
DRAM Static Read Control: AUTO
Ai Clock Twister : AUTO
Transaction Booster : AUTO
CPU Voltage : 1.35 / CPU-Z 1.328
CPU PLL Voltage : AUTO
North Bridge Voltage : 1.39 / EVEREST 1.41
DRAM Voltage : 2.00 / EVEREST 2.08
FSB Termination Voltage : Forget exactly what I used. EVEREST 1.34
South Bridge Voltage : 1.05
Loadline Calibration : ENABLED
CPU GTL Reference : 0.63
North Bridge GTL Reference : 0.67
DDR2 Controller REF Voltage : AUTO
SB 1.5V Voltage : 1.5
NB LED Selection : NB Volt
SB LED Selection : SB Volt
CPU LED Selection : CPU VOlt
Voltiminder LED :
Advanced CPU Configuration
C1E Suppport : Disabled
CPU TM Function : Disabled
Vanderpool Technology : Disabled
Execute Disable Bit : Disabled
Max CPUID Value Limit : Disabled
USB Configuration
USB Functions: Enabled
Legacy USB Support : Enabled
Now I'm not sure if there is an exact way to test stability, so the first thing I ran was OCCT 30 Min and it passed just fine. Attached to this post is a picture of the full load temps which I think are a little high, especially on the first 2 cores, but thats probably due to the concavity of the TRUE 120? NB temp seems high as well. Should I start dropping voltages on some things or maintain those voltages and start upping the CPU clock. Idle temps for the CPU are 42, 39, 32, 35 respectively, and 56 for the NB.
[IMG]http://img210.imageshack.us/img210/6351/occtit8.th.jpg[/IMG]
