Just been sent a BIOS from ABit that supposedly addresses issues with 4870x2 and 45nm CPUs (including E0s).
Unfortunately, its too big to attach.
Will be testing it this evening. Perhaps support hasn't been completely severed after all :)
BIOS failed to initialise the display again, seems like they are just trying to fob me off :(
I have emailed them back but hold out very little hope now. The fact that they could/should have easily tested the BIOS before sending it, tells me all I need to know. :down:
That sucks.....
Hello,
been a while since I posted in here, had a few questions.
How does this board get on with the E8400 E0 and Auzentech X-Fi Prelude 7.1 Ch Soundcard PCI.
Also, has anyone bought an E8400 from scan.co.uk? Did you get the E0 stepping?
I emailed them and they said they have a high turn around for that chip so the likelihood I get the latest version is high but not guaranteed.
D.
ok, maybe driver related. how are the drivers btw, better than creative?
Bios 12 works fine with the 4870x2. It's bios 13 and 14 that seem to have the no display issue. I am using the 4870x2 on this board in the first pcie slot and all is well.
Has anyone had issues with Vmware and VT technology when running BIOS rev14?
I installed rev 14 a while back and even with VT enabled in the BIOS VMWare will not detect that it is enabled. I'm running a Q6700 and I know it has worked in the past.
In bios you must ENABLE: Virtualization Technolgy... Why dont send a mail to ABIT..??
The bios 14 runs solid... without any issues
With bios14 after oc my cpu, C1E and EIST are automaticaly off. Can someone check this on beta16 coz i want this options enabled. Now im on bios12 and its work good with my E2160@3ghz.
How much fuctions C1E & EIST can lower temp and energy consumption in idle ?
BTW even on bios14 ram timng are still not correct for example tWTR in bios set on 15 and under windows memset shows 20.
Any life here?:confused: any new beta bios?
Can someone tell me how to boot from sata dvd when i have raid0 ?
And why in raid0 with 2 samusng 320g F1 i hv so low copy speed 70-80mb/s on big files 4gb+ or maybe its normal its my 1st raid.
Hi there
Got a bug to report on my one. I just installed mine and the board doesn't get it that EIST or Thermal Controll is on. I already overclocked it with my QX6700 and it worked so far for a while. Now it seems to stay @ 10x Multi + 1.35V :/ any suggestionst?
You guys must be the last to hear the news ? Universal Abit to close down on December 31st :shrug:
Quick question. Does anyone know if this motherboard will work with a E8400 that is an E0 stepping. I have seen people with E8400 and E8500 but I am unsure if this board will support E0 versions. Thanks for the help guys.
(Yes I know I am resurrecting this thread.)
Hi, someone can help me, i have a Club3D HD4870 x2, but dont work in my Abit IX38,, what bios solve this problem,, Abit say me:
Dear Customer,
In the attachment i have attached a new biosupdate for the motherboard wich should support the Ati Graphic card on your motherboard. Please update to this version.
But send me a bios for Abit IX48 GT3 instead of Abit IX38 Quad-GT, the bios is:
IX48 GT3(M703D)
I heard that some people can upgrade Asus x38 to x48 flashing your bios...??
regards..
ABIT send me today the CORRECT BIOS for the ABIT IX38 Quad-GT, the bios is:
m704b_15.bin
I can't attach it because is BIG than allowed, but if, someone are interested i can send by email..
I will try this bios today...
I have had this board since release, and it has been my first experience at OC'ing at first I maxed out my p4 in no time and left it alone until recently I got a Q9550 and a better hard drive. I have it OC'ed to 3.7 at stock voltage. The problems I am having is even with active cooling the pmw's are getting too hot and can not get any higher volt. Second It will not read the CPU correctly it says it is cooking at 103c but with realtemp I am seeing idle temp for each cores near 40c. I have Bios version 14, I was thinking of trying 13 to see if temp would get back to normal.
Lastly I can not figure out for the life of me on how to get Raid set up, I have the drivers but It says JMB36x Raid device not found. I want to mirror my old drive then run the new as primary but I am totally lost. Any help given would be greatly appreciated.
Can't install SP2 on vista 64 I get a multiprocessor_config_not_supported error. On vista 32 it works fine, I tried Bios 13 and 14, the 2 that should support my cpu (Q9550) I guess I just have to find another mobo since this one lost support.
I send you the bios, mate..
lucky with this bios
, for me solved the issues with HD4870 x2 graphic card.. and works solid with O.C with my Q6600 G0.
Hi is it possible to get the bios too:) thanks
Hi again, i have problems with this mobo, i have the code 26 on Abit post codes, i read that is related with graphics issues:
http://www.abit.com.tw/faq/code.html
Is posible that my HD4870 x2 was DEAD..??
Any way to check the 2 gpus of the card..??
Thanks in advance...
@winters: Can you send me the bios Abit sent you, please? Just upload it to Rapidshare or Megaupload and give me/us the link.
Cheers.
