Hi guys,
short question. is it better to use the yellow or the red RAM-Slots ? Whats the difference ? i stuck currently at fsb 540 ;)
i´ve the Giga P35 DQ6 - Rev. 1.0
many thx
R.
Hi guys,
many thx
R.
Wy not test it..
Hi BTK - not sure if anyone has responded to your post, so here goes -
I am using a GA P35-DS3 (F4 bios) with an E6750 at 3.2gig @ 1.37 volts - with stock intel cooler it idles at 28-32 deg and loaded (Orthos) 48-52 deg.
So in answer to your question, 3.2 stable, I say yes, in fact you could probably go to 3.4 - 3.6 or higher with the cooler you have ordered. I am very impressed with the stability and performance of my system.
BTW for 3.2gig - set the FSB to 400 and mem to 1:1 (2.0 in bios) which runs your PC6400 (800mhz) RAM at rated speed - with micron chips your RAM could probably run much higher.
I am using Corsair PC6400 5,5,5,18 - pretty cheap, but I can overclock to over 500mhz (DDR1000) with Vdimm @ 2.1 volts.
Not much else to add - its a straight forward setup - whci should give you good results.
Good luck with your new rig
ok My cpu was stable at 3930mhz on my 680i dfi board. I know my cpu is not the problem. My problem is that I do not know the voltage requirements for the NB or FSB for 434-440 x9 FSB.
Also once I run orthos the systems reboots itself and on the health status sub menu from top to bottom the DDR18V is showing Fail. My voltage is +35 for vdimm. what could be a good starting point for NB and FSB volts for my desire speeds. I'm running my pc8500 micron chips under their stocks speeds (860-880mhz).
thanks
hlo
Anyone tried these new F6 and F7 bioses for P35-DS4?
this was easy
http://valid.x86-secret.com/show_oc.php?id=242827
stock vcore
and it must be cool in here 35c load
but my 8800gts is being weird
im getting like 25 fps in games no vsync stock drivers
Maybe its the turbo standard ram options? That stuff is pretty screwy IMO. You tried different ram slots?
I currently have E6850 on DQ6 at 3.9 (9x434). Using bios F4 I was orthos stable >12 hrs with normal settings on FSB and GMCH voltages. I just updated to F6 and currently testing orthos, but so far stable with no increase to FSB or GMCH, others had said did not need to touch those til over 450 FSB. But boards may differ.
After updating to F6, I did have to set pcie to 105 and pcie voltage to +0.05 to keep my pcie from going to 1x (instead of 16x), or crashing my oc.
The fail on vdimm voltage is typical, just ignore it. Mine said same on +.4 setting (corsair dominator 2.2) when I run my memory at stock 533. Reads OK now since I am "underclocking" to 434 and decreased volts to +.3.
I'm getting the PCI-E x1 instead of x16 problem too, but I'm using F4 BIOS. I changed all kinds of settings in BIOS, changed vFSB, vMCH, vPCI-E, and PCI-E mhz. Set FSB to 398mhz to see if it was 400FSB that triggered it, but that didn't help.
I just put my GTS in the second slot. That one still runs at x4.
actually i reformatted and problem solved
but i got one question
im running this stable
http://valid.x86-secret.com/show_oc.php?id=243444
and the ddr2 voltage is @ "standard"
what is that?
1.8v or 2.v?
F6 BIOS
Hi everyone....just wondering what the min and max vcore settings are for the ga-p35-ds3? I was also wondering what differances between the ga-p35-ds3 and ga-p35-s3?
strapping nightmare! I have a P35c-ds3r using crucial (pc8500) have flashed to f4g-f4i-f4 and now back to f4g. Always starts out with a 1066 strapping, as soon as system hangs due to lack of voltage or whatever im trying it goes to 800 strapping. Of course I have to make alot more changes then. after 5-7 reboots, hangs etc. reverts back to 1066, where it is suppose to be. I also when loading OS, sometimes get a small error window saying Not for this chipset! Can not get past 3800 ( E6850) Is this about the max on air?? Thats at 1.5 v on core, speedfan reporting about 44c temp same as coretemp.95(thats load temp running prime), though have heard you need to +15 to temps on speedfan.
Is this jumping back and forth with 800-1066 strapping just a gigabyte bug?? I also have to run +5-+6 on vdimm isnt that like 2.4v?
sorry bout the unorginized post, just venting! main question is locking down the 1066 strapping , most time im tweaking this board its 800 and I thought with the 1066 ram it should stay 1066. Im beggining to think that this pc8500 is the exact same as the pc6400, just higher SPD dump. I originally thought it was tighter binned.
Guys...spotted a new version of Easy Tune 5 over at the GB website.
i went back to f4 bios f4i suks
How could I see the temps of my NB, SB on the DQ6.
Also have anyone tryed the yellow memory slots ?
Please advice
Hello !
I completed my first new build last night and it went well, I do need pointers on a couple of things though, I hope you can help.
At first the CPU fan wouldn't spin, checked all the cables but nothing, I then moved the fan header from CPU to SysFan1 and it worked, I checked the temp in bios and it looks fine, anyone else had this problem, is it safe to use this long term ?
Anyone using a Zalman CNPS7500 (120mm superflower) on this board ?
I couldn't get one of the lugs to snap down over the bracket, a small square black power capasitor is in the way which ever way I try it. I gave up in the end and fitted the stock fan.
Thanks !
P35-DS3P
C2D E6750
2GB Geil 6400
HIS X1950pro
Anted True power 650W
