Where are these BIOS revisions coming from? The latest I can see on the Asus sites is 0711?Quote:
My batchnumber is= L626A425
What does it mean? Which week is it ? 26?
I just returned a faulty P5W DH to overclockers and have been told to wait 28 days for replacement... yeah sure, as if i wont buy another in the meantime
I returned a PSU to scan last week and was given a new one straight away.
works on bothQuote:
Originally Posted by mascaras
Anyone know the changelog for 0804?
Another FSB Barrier here... 415 FSB ok even with auto on nb/fsb voltages, but 420 is a no go. Upping nb/fsb voltages doesn't seem to help :(
Any ideas ? Tried Bios 614, 711 and 801 till now. CPU is E6400, testing with 6x multi. Ram is Cellshock 1000 so it should run fine at 420. Hope anyone can help cause 3200 on an E6400 is not exactly what i expected :)
Originally Posted by [HTO]Hunter
if using a lower multi than default windows still calculates at default multi for chip, eg., default 500x9=4.5ghz, if in reality using 500x8=4.0ghz windows will show 500x9 because it recognizes default multi.
my corsair pc8500 should have been fine until 530ish fsb 1:1 but one stick called it quits around 415ish FSB 1:1 while the other one happily marched onQuote:
Originally Posted by ic3m4n2005
If I was you I would lower the multi and test the ram with memtest86+ 1.65 and see if you are getting mem errors
ok, so 801 bios works with p5b dlx without wifi, does the 804 bios work with deluxe without wifi as well?
also, whats a good free rar. file extractor?
thank you
have you tried cas 5: 5-5-12 or 15?
Originally Posted by china
yes!Quote:
Originally Posted by Kakulukia
Yes, even 6-6-6-18 and still no go. It must have something to do with the board. I expected to get around 3GHz for daily use (which I got), so I'm quite happy but this still bugs me... :rolleyes:Quote:
Originally Posted by Ace-a-Rue
which CD2 are you using?
Originally Posted by swiftex
all p5b deluxe bios' work on wifi and non wifi./
@Levish: Tested the Rams in windows with 4:5 div @ 500 Mhz..no probs
any of you guy`s know if the iP965 chipset is the same as the "C2" P965 ? I keep seeing those iP965 boards :)
Originally Posted by Revv23
Thanks Revv23,
what about free rar. extractor, anyone?
I'm not speaking for Intel, just as an enthusiast.
There is only one 965P chipset. There are two steppings of it out there. C1 and C2.
C2 fixes a couple bugs that were in C1. But they aren't terribly critical bugs. They are both on a very mature process, so I doubt that there are any process differences between them.
Thanks for all of the replies ... I wish i was able to get my 8 multi at 9 with a 524fsb :slobber:
You guys are the bomb :toast:
just do a web search...you will find a "rar" extractor...they might want you to buy after "x" days but it continues to work after the trial period...you just have to put up with the message.
So, again where are the 0801 and 0804 Bios' coming from?
asus ftp.
Good grief, just Google 7zip. Supports pretty much everything, and it's free.Quote:
http://www.7-zip.org/
:D
Cheers, got a link?Quote:
ftp://ftp.asus.com/pub/ASUS/mb/socke...uxe%20Wifi-AP/ seems to indicate the latest revision is 0711, don't see any 08xx revisions for any of the P5B series mobos.
7-zip is a good free rar extractor, i couldnt find a newwer than 711 bios eitherQuote:
Originally Posted by scoobysix
