Originally Posted by
GNU
Thank you,
Yes, it's hard to believe but it's maybe a sensor problem.
Maybe it's the sun (My PC is near the window and the day is hot (35°C in the sun). The water was a little bit heated by the sun :/
Vdimm = Bios 2,22 set /get 2,18 something. Sorry about the pic. I will reupload a new pic. It's not blotched out, it's a mistake with paint :p
Do you mean the system is okay with this temp for 24/7 with max 60°C under load?
OCCT gives me an error (temp error = CPU is overheated) and I don't know, shall I drop the FSB or whatever to get lower temps?
I will wait until a earlier night to retest the system with OCCT (only a 30 min test to see, what happens).
Edit: I had restart the system (start temp was 45°C after 15min now 50°C @idle). Pic was uploaded. Watertemp 31°C and no Sun is cooking the water but a hot air (30°C) :shakes:
Edit2: After a 3DMark05 Bench with 11425 Points SG shows CPU 52°C NB 48 and Sys 40.
Edit3: After a long idle modus: CPU 56°C , NB 50, Sys 41 and water = 34
