some nice new scores here, hopefully this thread will stay alive in 2013, too. :cool:
16 GB run, but need to optimize my waza. 0.4-0.5s better would be possible so I'm shooting for 6.17.xxx
EDIT: Forgot CPUZ mem tab - the memory clock is 1388 MHz
ASRock Z77 OC Formula
16 Gb Corsair DOminator Platinum 2666C10 @ 1.85V - air cooled
Intel i7 3770K @ aircooled - 1.25V
http://img541.imageshack.us/img541/3465/618390.jpg
Alex
improved a bit with waza....but 3 seconds of boost seems to be impossible here :(
http://imageshack.us/a/img689/6537/618235.jpg
Guys, I tried all combination form 600 to 700 Mb of maxmem and form 1.4 to 3.6 Gb waza- single file and 1 mb each file...in the best cases i cut 2.4 or 2.5 seconds. Any tips?????
Thanks in advance!
Alex
Just realized i haven't uploaded an old score from October .
Ram was a pair of GTX3 . Again cascade cooled (-110C) . No matter what , it couldn't bench at 1300Mhz . I'll have to find some time to test my other kits ...
Anyway ...
Stelios - 6:18:109 - 47x106.4 - 1276MHz - 7-9-7-28-78-1 - Asus Maximus V Formula - Corsair GTX3 2X2GB PSC - 1.9v if im correct -CPU air - RAM cascade cooled
http://www.hwbox.gr/images/imagehost...9ef466f7a9.jpg
Keep trying guys some nice scores here.
Stelios why trcd at 9 ? U dont need that go 11 to have much stable setup but play with others.
Finally!! 7 binned memorykits, lot of time while testing, lot of fails.. did i forgot something? Well, here is my result with aircooled 4x2GB Trident BBSE's. :)
http://www.sf3d.fi/forum/download/file.php?id=212
Here binned mems:
1x Corsair XMS3 7-8-7-20 1600 (CMX4GX3M2A1600C7) (PSC)
1x Corsair Dominator GT 8-9-8-24 2000 (CMT4GX32A2000C8) (PSC)
2x G.Skill Ripjaws X 6-8-6-24 1600 (F3-12800CL6D-4GBXH) (PSC)
1x G.Skill Ripjaws 7-8-7-24 1600 (F3-12800CL7D-4GBRM) (PSC)
2x G.Skill Trident 9-9-9-27 2000 (F3-16000CL9-4GBTDD) (PSC)
1x G.Skill Trident 9-9-9-24 2000 (F3-16000CL9-6GBTD) (BBSE)
1x G.Skill Trident 9-9-9-27 2133 (F3-17066CL9-4GBTDS) (BBSE)
http://www.sf3d.fi/forum/download/file.php?id=213
Good man!! Which score u have with no waza??
Gettin' there..
Dumo - 6:20:454 - 49x102 - 1428MHz - 10-13-12-28-107-1T - MVE - Corsair 2800C11 - 1.83v - air
http://img690.imageshack.us/img690/5778/zzzcorsair1.png
Uploaded with ImageShack.us
@Dumo no waza? your time i think must be sub 6:20
my result with corsair 2133c11 vengeance ver5.12, 2,05v air, played before AOOC2012
http://i.imgur.com/QP8DT.png
Hi all,my first time on the 5 Ghz efficiency.I stuffed wazza up on this run and had a few efficiently problems, didn't get time to run again,will run again later.
Bullant - 6:17:969 - 49x102 - 1326MHz - 7-10-7-26-90-1T - Gigabtye UP5 - G Skill 2000C6 - 2.15v - LN2-CPU -30 Single Stage
[http://s7.postimage.org/ikb95slrv/bbbbbb.png
^awesome run man, don't think your efficiency is off, just need to tighten some secondaries and tertiaries and you should be set!
nice one :cool:
Also try to use 100:133 dividers ;) Trrsr at 4 if possible,and tighten up those secondaries,trrd 4,trfc 70,twr 8-10,trtp 4-5,tfaw 16-20,twtr 4-5,you will get a nice boost.I know you guys have problems on gigabyte mobo's,so maybe try asus,asrock oc formula plays very nice with psc ;)
Thanks Alex,just did a quick try with those settings and they really good,I was having a problem when i tighten things up too tight i was loosing efficiency but it seem it may have been to much V core,dropped V core back abit and seems ok now.Thanks for the kind words and help guys and the nice settings Alex
When i work out how to thank you alex i will ahah
No problem mate ;)
Little improvement Bullant - 6:17:594 - 49x102 - 1326MHz - 7-11-7-26-90-1T http://s1.postimage.org/cxvrusghb/00...0000000000.png
l0ud_sil3nc3 - 6:18:703 - 108.7x46 - 1303.5MHz - 7-11-7-28-98-1 - Asrock Z77 OC Formula - G.Skill RipjawsZ 2400c8/PSC - 1.94v - cpu LN2 / memory LN2
http://i.imgur.com/YHHQy.png
not sure why so weak for 4X2GB?
http://i.imgur.com/Gyc6p.jpg
[QUOTE=l0ud_sil3nc3;5164406]l0ud_sil3nc3 - 6:18:703 - 108.7x46 - 1303.5MHz - 7-11-7-28-98-1 - Asrock Z77 OC Formula - G.Skill RipjawsZ 2400c8/PSC - 1.94v - cpu LN2 / memory LN2
http://i.imgur.com/Gyc6p.jpg[/QUOTE
How much boost did u have between 2 and 4 sticks?
