Yea they are.....am wonderin if I shud give the APFW a go. If I could I would get both to whack :p:Quote:
I would go the PAW :)
Mr.President
On what cooling?!
Is that any rule for a good venice stepping?
3000+ LBBLE 0516CPBW
3000+ LBBLE 0519EPBW
3000+ LBBLE 0522CPEW
like de first 5 leters ou de last 4 , the numers just refer to the week right?
Just forget the first.
I had a 3000+ LBBLE 0516CPBW that needed 1.5v for 2.4GHz :mad:
Almost all of them have problems to overclock.
[]'s
hi firends, I have a question that I want to learn
My cpu is venice 3200+ 0515 FPBW and good cpu, and ram is ocz platinum rev2 ddr 400 (tccd). its up to 2700 mhz with def. voltage and goes to 3000 mhz. But when I tried to run 1:1, example : (10x270,9x280 etc...) its not stable prime 95 and spi32mb what can I do? please some advice :( :confused:
The problem is the memory or the memory controller.
You need other memory (with known overclockability) to test.
There are very good TCCD/TCC5 and very bad ones. It's all about luck.
But the ocz is stable. In memtest86 290mhz (2,5-4-7-3) stable 6 hours :rolleyes:Quote:
Originally Posted by higherøx
My G.Skills were stable at memtest86 and crashed in the first loop of SuperPI 32Mb.
You need something to test. Other CPU, other mem...
memtest means nothing re stability in windowsQuote:
Originally Posted by kosmonova
every board/CPU/ram is different, if your is not stable at 1"1 then just use a divider, use 180 instead of 200, as it make practically no difference for performance with A64 :)
My cpu is very stable, when I'm using divider 166-180... so what is the problem ?? memory control or ram problem? how can I understand ?
Yea, my 4400C25 was memtest stabel all night at 300, but not in prime. A loose heatspreader caused the chip`s to overheat, so i ripped them of to get 300 HTT 1:1 stabel.Quote:
Maybe by trying another devider?Quote:
just got my new venice!!E6 core 3000+ WEEK 0525 APMW below is result heheh happy[IMG]http://i16.photobucket.com/albums/b17/EAGE1981/1.jpg[/IMG]
i can do 1.26V but prime95 only 5 hour stable :mad:
nice result, but i dont think its really stable with small fftQuote:
Originally Posted by eage
download Prime 24.13 here:
http://mersenne.org/gimps/p95v2413.zip
an do some Torture Test, Large fft ;)
nice...Quote:
now who would go out and buy a 3800+ E3 :p:
nice work.....that's a 3Giga for sure
can you post the a photo of the CPU heatsink pls for full code
3000+ 0520 CPMW under testing...
Results Soon.
SMALL FFTS tests nothing.............Quote:
go test LARGE FFTS!!
hiya,
I thought that the cpu's after week 20 were not so good?
xyus
Where are you guys getting your 3000+s from?
no time for large again i need use my computer every day i am doing biz on ebay,3G seem is easy on this chip, i will going to china 2 days after good luck guys,full code is 0525 APMW
Batch code is 1203 good lucky!
LOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOLQuote:
Originally Posted by Doom5
GOOD ONE.. We've just chosen pur cpu's carefullhy.. and offcourse... PRAYING A LOT! xD
Originally Posted by orig3n
dude, would you mine to share with us, the temps you are getting with your aquagate mini 120??
right now i own a thermalright 120 with a delta sensflow like 150 cfm...
do you think i will get better results with an aquagate mini than with any air cooler..
thanx bro hope you dont mind sharing this hehe :toast:
Not to Be annyoing or so.
but are the changes big if I buy a venice that It'll be crap ?
(sry to ask again :slap: )
xyus
