Is there a difference if one 16x pci in 5870, 5870, in the second PCIe 8x or both in 5870 PCIe 16x slot
For 2x 16 use slot 1 and 3 on E760
Problem is that I can not get more CrossFire bridge extending from 1 to 3 slot
Question: Does anyone know how the PCIe slots are configured (i.e. x16/x16/x8/x8)?
On E760 the first pci slot is 16x the 2nd is 8x the 3rd is 16x and the 4th is 8x :)
I have the following set up
Classified 760 with EK full water block
BIOS 61J
CPU cooled by TEC chilled water
ATI 5870
3 x 2 GB Perfect Storm CAS 8 2000 MHz
I can get to 21x 218 without too much trouble, see link below for voltages etc:
[IMG]http://img22.imageshack.us/img22/8414/4566hz20xlinx.jpg http://img22.imageshack.us/img22/456...jpg/1/w973.png[/IMG]
However, I cannot get BCLK 219 to work - Eleet will just freeze if I set that value using the above voltages, or the board will not post if I set 219 in the BIOS. Upping IOH to 1.35 volts will allow 219, but 220 is no-no even at IOH 1.500 (!!). Upping QPI PLL makes no difference. PCIe frequency doesn't seem to make any difference either.
The very same CPU easily got to BCLK 224 with minimal voltage changes and PCIe 101 on the vanilla EVGA X58 board (a 758, which sadly died after a few days although I did get a full refund). So its not the CPU.
Anyone have any ideas?
CPU impedance = less, IOH and QPI PLL to keep synchronously, decrease cpu and ioh pll to 1.5V, increase vtt...
/edit.
QPI Signal Compensation = less
Has put a voltage only on CPU + VTT, the NB and the memory, all the rest in the minimum values.
Mother easily takes 254х21.
http://img690.imageshack.us/img690/745/screen085.th.jpg
24/7
That did it + PCIe at 105 !! Many thanks to you and the other guys for the help :clap:
I can set BCLK 233 using Eleet without issues!! Settings
PCIe 105
QPI less
CPU less
ICH 1.200
QPI PLL 1.300
IOH PLL 1.500
CPU PLL 1.800
IOH 1.300
VTT 1.300
RAM 1.55
VCore 1.4625
Now to see the maximum LinX stable speed I can get....
Great! G'luck.^^ :up:
How do you think the score tale 5870CF and wound on the 4.5Ghz CPU
http://img200.imageshack.us/img200/8...ark06cf.th.jpg
Is it possible to use my 5870 on slot 3 and my 8800GT on slot 1 for PhysX with the 5870 being my primary display?
Idle -48 load Crysis-36
So I play
http://img32.imageshack.us/img32/7252/screen088q.th.jpg
280@810/1620/1300 on a photo of frequency from other profile.
what is the best bios for E760 and the W3565?
I'd guess the latest one. ;)
I see many of you are running the classified with the intel G2 ssd. Anyone of you have/had any issues running the ssd in AHCI mode? I tried installing win 7 x64 a couple of times, all of them whenever i turned off the pc next reboot i had disk boot failure. I could see the drive in bios but i couldnt boot OS. I tried IDE and it works perfect, but since i saw some performance decrease i would like to know if there is a solution to this.
79.99. It's in stock now:
http://www.evga.com/articles/00521/
Hello.
Would need a helping hand:)
Cant Get my system past 233Bclk on any multy
233 is reachable with 2 cores 4 cores even 4coresHT
my dominator cant be the problem(runs 2:8 930Mhz 7-8-7-27-1T)
mabe ia have a bad cpu?
http://www.upload.ee/thumb/304296/untitled.JPG
PCIe 123 :)
QPI less
CPU less
Vcore 1.5-1.6v
IOH/ICH I/O Voltage 1.5v
ICH VCore 1.05v
QPI PLL VCore 1.4v
IOH PLL 1.8v
CPU PLL 1.8v
IOH VCore 1.45v
CPU VTT Voltage 1.55v
DRAM Voltage 1.65v
