Originally Posted by ben805
I can't help but LMAO whenever I look at post like these! :rolleyes: I have 3800 and 4200 sitting infront of me and the 4400 with IHS off is running under a single stage phase change at the moment.......clock for clock this Toledo can't even touch the cheapest 3800, it's running much hotter than either one of my Manchester, show me some fact to back up your statement '4400 has been spanking it since release' :stick: If you're refering to the Extra Heat, Overpriced, Overrated, Inferior mem controller then yea I couldn't agree more, the 4400 indeed win hands down in all those regards.
Until those people own both Toledo and Manchester to compare and see for themselves, otherwise 'hype' is all they really get out of those 4400 and 4800. After all the X2 cpu that I've been through(two 3800, 1 4200, and 1 4400), 3800 no doubt is by far the best bang for the buck dual core out there, with decent cooling you still can get atleast 400 Mhz out of it, under single stage phase change or WC most of these 3800 will do 2.8~2.9. As far as the 4600 goes....it's about 150 bucks more than the 4400 but if HIGHEST possible overclock is your goal, then 4600 IS the ticket. If you're tight on budget then 4200 is even cheaper than 4400. Plus, the memory controller on these Manchester are superior to the Toledo so getting the 4400 or 4800 is a lose lose situation, not many people realized the 1MB L2 cache is way overrated, that is all. :stick:
