Damn nice piece you got there man, mine does 150 MHz less with stock cooler and 1,55V. :( There isn't any danger running it at 55-60°C. :)Quote:
Originally Posted by Malachia
So is there some way I can change my multi to run 200mhz+?
Use the iron to melt the plastic?Quote:
Originally Posted by Kamerat
Just pull it off. It's not attached any way except fitting snugly on the pinns unless Im mistaken. I ripped the Plastic floppy molex connectors off dozens of 9700/9800 cards.
Originally Posted by Lithan
with fsb400 no...you need a 533 to go above 200 fsb...
Damn. A 730 would have been perfect too. 12 is just the multi I need. Wish I had done more research before I bought. My 1.5 is pretty good (Priming at 2.5ghz 1.39vcore now), but I know I could hit 2.7ghz+ if it wasn't for this 170-200 problem.
Wriggle a knife blade in.Quote:
Originally Posted by Gautam
Mine were hardly attached.
Got my P4P800-SE yesterday.
Just need a 730 now.
Oh and the new bios to come in the mail!
Where can you buy a 730 cheapest in the US?
Ok, thank you folks.
I got my 730 for $165 off of ebay.
Sounds like a good deal.Quote:
MWave looks like a good source in the US.
Anyone here in Canada? If so, where did you get your Dothan! :D
I'm sick of paying duty on stuff from the states. It doubles the price sometimes.
Hey Guys,
I set up my Dothan Rig:
P-M 730 U-Wire Mod => 1,55V
Asus P4C800-E + CT479
512MB Twinmos BH5
I cannot go anything above 2350MHz stable with it, can this be?
I can't imagine that 2350 is all, a dothan can do?!
bro easy to know, try at lower v-core, if you can reach same frequency isn't the cpu :)
Try booting at above 200MHz.Quote:
Originally Posted by Firefoxx
So, with 1.25V-1.3V I can go @ 2250MHz stable..I'm really frustrated...Does anybody know something?
Booting with >200MHz doesn't work :(
Anyone tried 4 sticks of UTT in a P4C800-E and a Dothan by any chance without any problems ?
Your mobo vdimm modded?
Do you mean me?Quote:
Mine's not modded, do you think the kyosen mod is necessary?
It will be one way or another... voltage wouldnt be an issue. I was asking do Dothans on a P4C800-E DLX like 4 sticks of mem.Quote:
I'll assume you are scaling the FSB via Windows. I've found I can go higher with Clockgen if I don't jump the FSB all at once, creep up the clocks in 2 or 3 steps. If I go 2000-to-2700 in one step, freeze. But if I go 2000-2400-2700 it usually works.
Yep I observed the same with my A64, uclajd.
Re the vdimm mod, I was talking to Firefoxx. 512meg modules of BH5 tend to be touchy, especially when you don't volt them right.
Has anybody found out how to get different CPU voltages on the p4C800E?
Right now it's either 1.356V (unmodded) or 1.55V (u-wire mode). This sucks! :cussing:
Vcore mod it I guess...its what I'm doing.
Well, I burnt my finger and broke a pin on the adapter tonight. There is a place you can get pins fixed, but the site is being worked on and I can't get their contact information.Quote:
Just another day away from getting my rig set up, boo hoo
I hope you had better luck than I did Gautam
you all don't need to REMOVE those pins, just cut them flush to the pcb then solder the wires on, lol...
C
Yep, just some wire cutters or pliers and just snip/rip it off, how hard is that :)Quote:
Originally Posted by charlie
