lol. i just noticed it IS reversed. I looked at the pics several times too. better get that fixed quickly
Dyslexic System...
hehehhe oh no!
Just got her setup - Still need to do cable management. Thinking of getting another PA160.1 in the bottom (Maybe something else...suggestions) to feed the GPU's and maybe a Chipset block to bring noise down. Do you guys think the Lang D5 will do all this or will i be in need of an upgrade......????
http://img.photobucket.com/albums/v6...g/IMG_0016.jpg
http://img.photobucket.com/albums/v6...g/IMG_0002.jpg
http://img.photobucket.com/albums/v6...g/IMG_0005.jpg
http://img.photobucket.com/albums/v6...g/IMG_0001.jpg
http://img.photobucket.com/albums/v6...g/IMG_0007.jpg
Enjoy
Topboy
A 50Z will give better temps with a PA160, because of its much lower heat dump.
If you must cool the NB, get the MCW30 or an Eddy_EK, everything else ive seen is much too restrictive. Not like a NB needs much cooling anyway.
Either pump should do Storm + 2x Maze 4 + MCW30 ok... you can upgrade to 2x 50Z or an iwaki if you want, but if youre that much after performance then i have to question why you want to harm your loop's performance with a NB block in the 1st place.
If silence matters that much to you, just slap another PA160 and the MCWW30 and be done with it, dropping in a bigger pump to counteract the nb block restriction is a bit like saving your breath to cool your soup ;)
for a silent pump go with a Laing DDC- and get a plexi top-
Looking good, but dude, cable management!
LOL...Yeah tell me about it and thats what i do as part of my job...HP Server rack building.Quote:
Originally Posted by Mankz_91
I allways throw things in.....then tweak after....Cable Man is allways last to get done.
OK so NB cooler is out....but i do want to throw another Rad in so i can cool the second GPU down.
Been watching the temps and when in this series... RAD -> Pump -> CPU -> GPU1 -> GPU2 -> RES....I am getting a difference under idle and load of 4 to 6C higher on GPU2.
So my idea is to feed the GPU2 with its own RAD.
How will this affect flow with the D5 in or should i uprate pump. Need to be able to buy in the UK.
Topboy
nice rig topboy......what camera are u using to make those beautiful pics?
My other new toy....Canon EOS 30D SLR with EFS 17-85 Lens :DQuote:
Originally Posted by danstar25
Review here :
http://www.dpreview.com/reviews/canoneos30d/
Topboy
My first WC.
Pump: Laing DDC 1T
CPU: PowerX rev.2
GPU: Abadon PRO
Radiator: BIX2
Innovatek, Camozzi, and reservoir.
http://img439.imageshack.us/img439/4471/16ys.jpg
http://img328.imageshack.us/img328/3200/23dn.jpg
http://img328.imageshack.us/img328/7018/16kb.jpg
http://img328.imageshack.us/img328/3255/32at1.jpg
@itor Vga and DM-11 cpu block
@itor custom radiator
http://img148.imageshack.us/img148/1...nano0091re.jpg
http://img148.imageshack.us/img148/4...7small25zy.jpg
http://img487.imageshack.us/img487/8...14small6fu.jpg
Se ve muy bien mi amigo! :D
That looks great my friend! :D
:cool: Here are a few pics of my daily driver...
davidian, u got a link to that cpu waterblock of yours? i think it looks sexay :banana:
LOL, how are you friend!Quote:
Originally Posted by OCme
Nice rig you have there, I love the pc70 in black, my little pc65 is, well, too little :(
PowerX is a limited series waterblock from Poland.Quote:
Originally Posted by sTaBZz
It is currently unavailable.
But, look at maker's page:
click
Bien,bien amigo y tu???... me gusta tu caja. Mi caja pasada fui un Lian-li PC65 tambien...Quote:
Originally Posted by Ssilencer
I'm doing well my friend, and you???... I like your case. My last case was a Lian-li PC65 also...
Veo que estas usando una 50z a 13,8v que tanto mejora? no acorta la vida util?
Abandonaste el phase change?
I see you are using a 50z@13.8v, is that not risky for the pump?
Missed you from the vapor forum
13.8v is fine for it... gives it the best performance. though it probably wont last as long as it will @ 12v, but *shrug*. It'll give you nearly the same temps as an MD-20 like that...
IIRC I saw sometime ago a graph comparing the pump at 12 and at 13.8v, can anyone post that graph?
Originally Posted by MaxxxRacer
DOH.....will have that fixed this weekend...also changing a couple parts as well...got a thermocill PA120.2 coming as well as some 1/2" tygon tubing
those are sexy rigs!
http://img107.imageshack.us/img107/7...00097bv.th.jpg
- Above the normal look on my Guitar And PC sanctuary
http://img106.imageshack.us/img106/9...00123xs.th.jpg
- "Must Have" nightly mode
http://img140.imageshack.us/img140/1...00102mu.th.jpg
- Extra Radiator and reserator with 120mm Fan,
