Who said the Tjmax was 100C?
Realtemp is reading the MSR containing tjmax value on core i7's, so no more guessing tjmax since the value is software readable, tjmax on that one is 100C, distance to tjmax plus temp in C. 100 on all ones I have seen so far.
On another note, Intel white paper quote on running your cpu up to TCC max temp:
"With a properly designed and characterized thermal solution, it is anticipated that the TCC would only be activated for very short periods of time when running the most power intensive applications.... An under-designed thermal solution that is not able to prevent excessive activation of the TCC in the anticipated ambient environment may cause a noticeable performance loss, and in some cases may result in a TC that exceeds the specified maximum temperature and may affect the long-term reliability of the processor."
Here's my OC so far. I'm on air. I can't stay stable in Prime at 195FSB so I'm trying to figure out where to go from here to get the last 200MHz so I can hit 4GHz.
http://members.cox.net/kompulsive/oc.jpg
Personally I'd not want to run in the 90's for long, mine just bsod near a 100C on the stock cooler. But permanent damage if you stay under the TCC, throttling is not even active yet?
http://download.intel.com/design/pro...hts/320834.pdf
Originally Posted by Intel
Never looked at his temps...couldn't care. I'm asking you a simple question; where are you getting the info on ANY temperature related degradation for Intel i7's? Intel didn't tell you, so who did? Is it an educated guess? If you tell someone that their 93C is causing degradation then you must know when it happens. How do you know it's not 97C?
The bios shut off limit has not a bloody thing to do with degradation :clap: Every hear of the term "buffer"?
I finally found my 24/7 configuration. Thirteen hours of Prime95 is good enough for me to determine stability. Now to try to see how far this thing can actually go. However, it doesn't like the 20x multiplier and the QPI threshold is holding it back. Come on Asus, let me drop that darn QPI multiplier already!
http://i210.photobucket.com/albums/b.../Testthurs.jpg
I totally agree, I don't think we should panic so much about temps. I think staying around 80 after hours on Prime95 is just plain safe. What's bad about it is, the cpu is consuming tons of energy. But come on, it's 20 below the Tjmax. Above 90 is bad, of course, but I don't think it's degrading, at least not for short periods of time.
Great. And it's great Tjmax is read via software now, didnt know it! Thanks!
You're on water, right?
http://blue.ap.teacup.com/kazukun/img/1229638228.jpg
i7 965 3837B209 WaterCooled
Core Speed:4200Mhz
BCLK:200MHz
Multiplier:21
QPI:3600MHz
QPIV:BIOS1.65V
Vcore:BIOS1.55V
LLC:ON
MEM:KHX16000D3T1K3/3GX
Vdimm:BIOS1.65V
Uncore:4000MHz
DRAMFrequency:2000MHz
DRAMTiming:9-9-9-27 1T
HT:ON
The value that RealTemp reads from Core i7 processors is called IA32_TEMPERATURE_TARGET and here's how Intel defines that:
Temperature Target.
the minimum temperature at which PROCHOT# will be asserted. The value is degree C.
Intel has said that TJMax is not a fixed value. It varies a little from one CPU to the next but they haven't confirmed how much variation is in that number. It's a number they aim for when calibrating but the actual TJMax may be higher.
My personal theory is that it can also vary from one core to the next in a CPU. That's very obvious in the 45nm Core 2 series but I think it's also true in Core i7. There's a reason why in the vast majority of Core i7 screen shots, core0 is the hottest and core3 is the coolest. If TJMax = 100C for core0 then it's likely to be closer to 105C for the average core3. If this was all just random chance then you wouldn't see the exact same pattern with almost everyone's reported temperatures.
Thermal shut down of Core 2 doesn't happen until about 125C and it's likely that Core i7 is the same. I can't imagine that Intel would set such high numbers for TJMax and thermal shut down if they thought people were going to destroy their processors. They wouldn't offer a 3 year warranty and they'd obviously lower these values if they didn't believe in the high temperature durability of their CPUs.
Well said... I think these things are a lot more durable than some people give them credit for, i'm sure when penryn launched Anandtech had at least a full page detailing how much more resilient chips are becoming to death (that's even in light of their high VTT warning which is what gave a few people quite a scare, i wish they'd think twice before publishing stuff like that)
With the temps being reported by most people as acceptable and so much higher than any penryns were run at, i'd say i7 is even stronger.
Of course, in a few months if we're all shelling out for new chips i'll need a hand wiping all this egg off me face.
Im happy sub mid 80's 24/7, depending on the voltage I will need to get me there
Yep. I'm a bit lazy and bought a Koolance Exos-2 LX but I did pair it up with a new Apogee GTZ water block. Considering that my CPU is the only thing in the loop, it's working pretty well so far.
I'll post back when I get off of work.Quote:
Lemme get the BIOS settings! Pleaseeeeee?
god Ci7 is a boinc monster... :D
I can do ~33% more seti client WUs at the same clock then my QX9650 and still have 4 threads to spare for WCG. :eek:
I just love that thing. :)
Hmm yeah, alot of Q9450 / Q9550 would go as high as most QX9650 without extreme cooling, this is nothing new.
Damnit, i think i've toasted my raid 0 array :mad::mad::mad:
I have a balloon popup from intel matrix storage console 'a drive in a RAID 0 volume is failing. Try to backup data immediately'.
I've never had this before, is the disk actually unusable now or can i format and remake the volume from scratch and it'll be like new??
What made it happen was running 165bclk with 24x QPI and 24x uncore (i was trying to find max stable of both) which were 3960mhz each. This is pretty ridiculous as from what i know they're supposed to top out at 4ghz, but i never expected them to just fry one of my disks like that.
lol you have not fried your disk... you just killed your raid0, happens quite often when you oc.
Thats why i usually use either raid 10 or 5.
If you use suicide raid (aka raid 0) be prepared to have a backup ready. :yepp:
Yeah well, I guess maybe it was karma for giving up on AMD after 12 years with them :p: All in all, I was too cheap to pay for bragging rights of a 965 XE and I stupidly assumed that same thing which applies in AMD world applied in Intel world so I figured the 920 would be low-binned and a 940 would be high-binned (boy did this backfire). This is a lesson for all times, at least when using Intel. Either go low, or go top of the line just for the bragging rights. It's all the same thing anyway, just packaged differently.
That and I broke one of my cardinal rules...never adopt a new tech in the beginning...but I just could not resist the i7...
Yeah i do, this is a gaming pc so i only have music, media, etc. But it's all backed up on a storage disk, along with the installation files for all my programs, so restorations are never hard.
Isn't it weird to happen just from testing 4ghz QPI though? Maybe it was the uncore... This blows because i wanted to start at 4ghz and work my way down until i found my max stable clocks there (based on high multi and lower bclk), i guess i can't do that :shrug:
I'm on the stock intel raid 0 option anyway, i reckon i'll try to figure out how to use the included hardware raid, J micron i think it is.
I'd still be on my blackops if it wasn't for the disaster that was ATI Catalyst :rolleyes:
:edit: well the deed is done, up and running on the hardware raid, quite a bit simpler actually than the software option. Oh, and it cuts out that 10-15 second period during post when it's detecting stuff / waking up... Jumps straight from splash screen to DMI table now, sweet!
Going to run HDtune i think just to compare.
Ok looks like I've finally cracked it for a stable (15mins prime) setup & good temps ..
Here are the settings:
Multi: 200x20
SpeedStep/Turbo = OFF
DRAM = 1600Mhz 8-8-8-24
Uncore = 3208Mhz
QPI = 7218MT/s
CPU Volts = 1.4V
LLC = Enabled
C-State = On/Auto
Rest is ASUS Default
4Ghz 1600Mhz Prime 8K HT On
http://i206.photobucket.com/albums/b...Refitprime.jpg
4Ghz 1600Mhz Prime 1024K HT On
http://i206.photobucket.com/albums/b...itprime102.jpg
4Ghz 1600Mhz Cinebench HT On
http://i206.photobucket.com/albums/b...tCinebench.jpg
4Ghz 1600Mhz Prime HT Off
I refitted the Noctua today with horizontal mount (fans blowing up out top of case) + smooth cover of paste over whole CPU + thin invisible layer rubbed into HSF side ... brought my temps down 10-15C at load and sub-30's at Idle as you can see ..
Finally happy with the build !!
Trying to get 4ghz prime stable with HT off, with lowest vcore and with qpi, cpu pll and dram v all within intel max spec -
Nice job...have you tried lowering the multi with higher Bclk for same mhz to see if requires less cpu vcore, just curious as it seems to work with i920 and i940 but have not seen any i965's owners state such yet. My excel sheet of my OC's, big difference at 4.1ghz stock multi of 22 versus dropping the multi to 21 at same mhz, or enabling turbo with 23 multi which is another way to lower vcore. All in bold are 12+hrs prime stable (most had linpack run at same time as prime for first 1-2 hrs to try and crash OC early vs late if unstable)...did not record all failures, just ones lasted few hrs. All are 36 (18) QPI, 18 UC for lower bclk runs, 17 UC for higher bclk runs, 1.28-1.33 QPI/Vtt, and 8 mem divider...but I am using 3x1gb so dont need as high qpi/vtt as those with more mem.
