First all, thanks for this thead, a ton of info here - anything and everything you need to know about the Q9450 is in here. So cheers! :up:
I was hoping that someone could take a look at my settings and suggest any possible improvements.
I’m currently running at 3.4 Ghz stable (linpack 10x, and Prime95 12hrs+)
Here are my settings:
Code:
Ai Overclock Tuner [Manual]
CPU Ration Setting [8.00]
FSB Frequency [425]
PCIE Frequency [100]
FSB Strap to North Bridge [266 MHz]
DRAM Frequency [DDR2-1066MHz]
DRAM CLK Skew on Channel A1 [Auto]
DRAM CLK Skew on Channel A2 [Auto]
DRAM CLK Skew on Channel B1 [Auto]
DRAM CLK Skew on Channel B2 [Auto]
DRAM Timing Control [Manual]
1st Information: 5-5-5-15-3-52-63
CAS# Latency [5 DRAM Clocks]
DRAM RAS# to CAS# Delay [5 DRAM Clocks]
DRAM RAS# Precharge [5 DRAM Clocks]
DRAM RAS# Activate to Prechar [15 DRAM Clocks]
RAS# to RAS# Delay [Auto]
Row Refresh Cycle Time [Auto]
Write Recovery Time [Auto]
Read to Precharge Time [Auto]
2nd Information: 7-3-5-4-5-4-6
READ to WRITE Delay(S/D) [Auto]
Write to Read Delay(S) [Auto]
WRITE to READ Delay(D) [Auto]
READ to READ Delay(S) [Auto]
READ to READ Delay(D) [Auto]
WRITE to WRITE Delay(S) [Auto]
WRITE to WRITE Delay(D) [Auto]
3rd Information: 14-5-1-6-6
WRITE to PRE Delay [Auto]
READ to PRE Delay [Auto]
PRE to READ Delay [Auto]
ALL PRE to ACT Delay [Auto]
All PRE to REF Delay [Auto]
DRAM Static Read Control [Disabled]
DRAM Read Training [Auto]
MEM. OC Charger [Auto]
Ai Clock Twister [Auto]
Ai Transaction Booster [Auto]
C/P: A1 A2 A3 A4 | B1 B2 B3 B4
LVL: 10 10 10 10 | 10 10 10 10
******** Please key in numbers directly! ********
CPU Voltage [1.21875]
CPU GTL Voltage Reference(0/2) [0.370]
CPU GTL Voltage Reference(1/3) [0.750]
CPU PLL Voltage [1.50]
FSB Termination Voltage [1.26]
DRAM Voltage [2.10]
NB Voltage [1.40]
NB GTL Reference [0.370]
SB Voltage [1.10]
PCIE SATA Voltage [1.50]
Load-Line Calibration [Enabled]
CPU Spread Spectrum [Auto]
PCIE Spread Spectrum [Auto]
CPU Clock Skew [Auto]
NB Clock Skew [Auto]
http://img182.imageshack.us/img182/9...4949hd8.th.jpg http://img229.imageshack.us/img229/9...4950fs4.th.jpg http://img182.imageshack.us/img182/2...4951ki0.th.jpg http://img229.imageshack.us/img229/6...4952bp9.th.jpg
I started at a vcore of 1.33750 and have slowly dropped it down to 1.21875 doing linpack 10x every time I drop the vcore.
