my maximus runs with tracers pc8500 1200mhz 5-5-5-12 @ 2.00v actual ( 1.94v bioset, board overvolts lol) np.. I tried 0802/ 0903/ 0907 all works, ofc each kit differs... u might have a bad stick
in Biostar TP35 my Ballistix can run 1200++ 4-4-4-4 2.5v:D http://valid.x86-secret.com/show_oc.php?id=283533
bad maximus (unlucky got), memory issues or memory setting not match? but in maximus my ballistix "only" stable run 1100 5-5-4-9 1.9v(bios) when up to 1200 .....my system freeze
now i will try with Team Xtreem 8500 but same condition.....
I can run my 4GB of Ballistix Tracers at 1200Mhz 5,5,5,15 using the 907 Bios!
i don t know if somebody understand what i mean,but i have on MB 2x4pins connectors...do i have to use both?...i ve got asus maximus formula...i m using just one 4pin...
Woldfale 8400 + Crucial Value 800 MHz
24/7 orthos stable
Extreme Tweaker
Ai Overclock Tuner : Manual
OC From CPU Level Up : AUTO
CPU Ratio Control : Manual
- Ratio CMOS Setting : 9
FSB Frequency : 450
FSB Strap to North Bridge : 400
PCI-E Frequency: 100
DRAM Frequency: DDR2- 1200
DRAM Command Rate : 2T
DRAM Timing Control: Manual
CAS# Latency : 5
RAS# to CAS# Delay : 5
RAS# Precharge : 5
RAS# ActivateTime : 4
RAS# to RAS# Delay : 2
Row Refresh Cycle Time : 25
Write Recovery Time : 2
Read to Precharge Time : 3
Read to Write Delay (S/D) : Auto
Write to Read Delay (S) : Auto
Write to Read Delay (D) : Auto
Read to Read Delay (S) : Auto
Read to Read Delay (D) : Auto
Write to Write Delay (S) : Auto
Write to Write Delay (D) : Auto
DRAM Static Read Control: Enabled
Ai Clock Twister : Moderate
Transaction Booster : Enabled
Boost Level :0
CPU Voltage : 1.32500
CPU PLL Voltage : 1.50
North Bridge Voltage : 1.55
DRAM Voltage : 2.12
FSB Termination Voltage : 1.2
South Bridge Voltage : 1.05
CPU GTL Reference : 0.63x
North Bridge GTL Reference : 0.67x
DDR2 Channel A REF Voltage : Auto
DDR2 Channel B REF Voltage : Auto
DDR2 Controller REF Voltage : DDR2_REF
SB 1.5V Voltage : 1.5
NB LED Selection : NB Volt
SB LED Selection : SB Volt
CPU LED Selection : CPU Volt
Voltiminder LED : Enabled
Advanced CPU Configuration
C1E Suppport : Disabled
CPU TM Function : Disabled
Vanderpool Technology : Enabled
Execute Disable Bit : Enabled
Max CPUID Value Limit : Disabled
The northbridge, X38.
Set it to 1.55V or so and try again. I have 4x 1GB sticks in mine and works fine at 1200 but you must disable Transaction Booster/AI Booster unless you're doing 8x450. Using 9x400 it won't work if you have them enabled to Strong/Enabled = 0.
CELLSHOCK 9200 works fine with this board. :D
There is only one problem...... i cant boot at 1200 cl4. i tried 2.7V and it doesn't help. i don't know what is the reason that caused this problem.
Maybe the next bios will be better.
2.38V - bios :bounce:
550, cl4 full stable.
In that case the BIOS will report DRAM as 1199MHz and you can have strong AI booster and transaction booster enabled = 0 configured.
It works here with the only difference that I have tested it at 9x450 and 8x450.
Do what I said with the MCH voltage and set the timings manually, i.e. 5-5-5-12.
On mine 1200MHz will work at down to 2.06V set in the BIOS though I run it at 2.10V at 1133MHz due to my Q66090 overclock.
thanks mate...i m gonna try...i ll let zou know tommorow
Can anyone get your PC8500 ram to either:
- 4-4-4-12
-higher then 1066MHz without having to OC to get it?
If so what do you need to do exactly? I cannot get 4-4-4-12 at 2.10V in bios at 400 FSB (E8400). I haven't tried a higher frequency because it's a pain to have to take out the ram, use PC6400 to boot back up then reinstall the pC8500 ram when something goes wrong. This bios 907 is the pits when it comes to ram adjustments with my PC8500!
Have you tried slots 2 & 4?
Seemed to fix the bug when Overclocks fail and default values are loaded, which lowers the vdimm to 1.9v which is too low for 1066 rated sticks. 667/800 1.9v for me 1066 2.35v:eek: .
Try:
-Slots 2 & 4
-DDR2 Controller REF Voltage : DDR2
-What is your FSB Term in Bios Set to? I noticed mine went from overvolt to undervolt from e6750 to e8400???
Here we go, stable for over 4 hours in Everest stability.
http://aycu06.webshots.com/image/443...4585016_rs.jpg
how can help me please...?..i can t get from my ram maximum...:mad:
i ve got that kingston hyperX 1200mhz..and is runnig at 920mhz and it is not stale...:(
http://img85.imageshack.us/my.php?image=suckbt7.jpg
This is the dram vtt. Should be half of the vdimm in most cases.
It helps stabilizing the vdimm. Leave it at DDR2_REF and use also
the white slots. These seems well so as not to have ripple on vdimm when
stressing memory
Code:Extreme Tweaker
FSB Frequency : 450
DRAM Frequency: DDR2- 1080 (5:6)
CAS# Latency : 5
RAS# Precharge : 5
RAS# ActivateTime : 15
DRAM Static Read Control: DISABLED
Ai Clock Twister : STRONG
Transaction Booster : DISABLED
BOOST: 0
CPU Voltage : 1.28125 ~ 1.264v
CPU PLL Voltage : Auto ~ 1.648v
North Bridge Voltage : 1.61~1.65v
DRAM Voltage : 2.24~2.352v
FSB Termination Voltage : 1.4~1.344v
South Bridge Voltage : 1.1~1.136v
Loadline Calibration : ENABLED
CPU GTL Reference : AUTO
North Bridge GTL Reference : .67
DDR2 Channel A REF Voltage : AUTO ~ 1.184v
DDR2 Channel B REF Voltage : AUTO ~ 1.184v
SB 1.5V Voltage : 1.6V ~ 1.664v
Voltiminder LED :
USB Configuration
USB Functions: Enabled
USB 2.0 = DISABLED
Legacy USB Support : Disabled
BUGCODE_USB_DRIVER
Caused by: Nostromo N52 Speed pad
-Happens after windows has loaded to desktop and loads drivers
-Does not happen if device is not plugged in, will happen after boot if you plug in regardless.
-Will happen in the absence of PS/2 Keyboard.
-Installed Latest Intel inf Drivers and Nostromo Drivers
This occurred in the past, but usually could be solved by a 3rd or 4th restart. However, as I clock higher it becomes more prevalent around 440-450
-Tried SBv 1.2
-Tried SB 1.5v = 1.6~
-SBv 1.1 & SB1.5v= 1.6 Success. Restarts are Good, Bug Gone...right?
This occurred in the past, but usually could be solved by a 3rd or 4th restart. 333 is the latest strap I'm trying since it only pushes to DDR2-1080 on 5:6. Restarts were great, it was like it was solved by 1.6v SB.
-Lowered SB 1.6v to 1.55v and it was back
-Switched back to my saved profile for 400 Strap 435*9 known stable.
-Restart it happens again. SB was at 1.5 in that saved 400 Strap Profile.
-Restarted again, only this time start opening folders and just kind of going psycho to try to "fool" it into missing my little bug. Imagine a burglar hiding from the police...
And its gone... Anyone have a Nostromo N52 they can verify this with?
***UPDATE***
-Tried 333 Strap Profile and Restarted - Didn't Touch any Keys on Nostromo or on Mx518 Mouse.
-Got Bugcode BSOD again.
-Restarted
-Tried Mashing Buttons upon XP desktop bootup
-Open files with Mouse, pressed keys on Nostromo (More like Mashing)
-It Works!
one question...
does our boards require more voltage to OC the cpu than others?
it seems like others are reaching 3.5 on around 1.3volts while we need 1.3volts to reach 3.0...or is that just my board....
help please!
Brisk, it depends. On my QX6700, I need less vCore than on a P5N32-E. But on my E8400, I need a lot more than most people are reporting (1.45v @ 4.23).
Do you have a B3 or a G0 Q6600?
I ordered a new E8400 to see if I can rule-out the chip.
