Note 1: Core Temp is an excellent utility, however, it has a fundamental flaw in terminology, which creates confusion in the CPU temperature community, by obscuring the distinction between temperature and specification. Core Temp shows Tjunction 85c (or 100c), which is an incorrect term. The proper expression is Tjunction Max 85c (or 100c), which is the term defined by Intel as shown above in the Specifications section, and as represented below:
Tjunction = Core temperature
Tjunction Max = Shutdown
Also:
Note 3: SpeedFan is very flexible and is the temperature monitoring utility of choice. SpeedFan detects and labels thermal sensors according to various motherboard, chipset and super I/O chip configurations, so the Tcase label can be CPU, Temp 1, Temp 2, or Temp 3. Even if Tcase is labeled as CPU, it is still necessary to confirm the identity of Tcase prior to conducting Calibrations. Run Prime95 and note which SpeedFan temperature scales with an Idle to Load Delta similar to the Cores. This will identify the label corresponding to Tcase. Labels can later be renamed using the Configure button, (see Section 11). If a temperature shows a flame icon, this indicates alarm limits which require adjustment. Use the Configure button to set CPU and Core temp alarms to Safe Scale. If a temperature shows Aux 127, this is simply an unassigned input which can be disabled using the Configure button. CPU`s with Steppings which are Tjunction Max 100c typically require +15c Core Offsets. See Section 11.
Is this all true? If so then it would seem to suggest that Speed Fan temps are the true temps to monitor.
