s7e9h3n, since you don't appear to be a Linux guy, what about installing OpenSSL for Windows (light version: only 1 MB) ? Get it from [1]. Then assuming you install it in the default location (C:\OpenSSL), open a command prompt and run this (if you get an error "MSVCR71.DLL could not be found", install Microsoft .NET Framework 1.1 [2] and copy C:\winnt\microsoft.net\framework\v1.1.4322\msvcr71 .dll to C:\openssl\bin\):
Code:
C:\> cd openssl\bin
C:\> openssl speed
"openssl speed" should take about 10 min to complete (single threaded by default, the Linux version can be run in multi-threaded mode), it benchmarks:
md2, md4, md5, hmac(md5), sha1, sha256, sha512, rmd160, rc4, des, triple des, aes-128, aes-192, aes-256, idea, rc2, blowfish, cast, 512-bit rsa, 1024-bit rsa, 2048-bit rsa, 4096-bit rsa, 512-bit dsa, 1024-bit dsa, 2048-bit dsa.
All these algorithms are 100% ALU code (except on Linux, where sha512 uses SSE2), some are coded in C, others are in assembly. They all scale pretty much linearly with the clock frequency. They should all easily fit in the Barcelona L2 cache so they should not be influenced by the memory subsystem at all. The only downside of the Windows version is that it is compiled as a 32-bit executable. Some algorithms would see a significant gain by running in 64-bit mode: RSA and DSA would be about 3 times faster, RC4 30% faster, MD5 15% faster, etc. Anyway see below for a table of results I obtain on a old Pentium M 1.2 GHz: the fastest hash algorithm is MD4 (240 MB/s) and the fastest symmetric cryptographic algorithm is RC4 (173 MB/s).
Others should run this benchmark on Intel Core-based CPUs so we can compare against Barcelona...
[1]
http://www.slproweb.com/download/Win...ght-0_9_8e.exe
[2]
http://www.microsoft.com/downloads/d...7-034D1E7CF3A3
Code:
--- openssl speed results for Pentium M 1.2 GHz on 32-bit Windows ---
OpenSSL 0.9.8e 23 Feb 2007
built on: Wed Feb 28 01:35:20 2007
options:bn(64,32) md2(int) rc4(idx,int) des(idx,cisc,4,long) aes(partial) idea(int) blowfish(idx)
compiler: cl /MD /Ox /O2 /Ob2 /W3 /WX /Gs0 /GF /Gy /nologo -DOPENSSL_SYSNAME_WIN32 -DWIN32_LEAN_AND_MEAN -DL_ENDIAN -DDSO_WIN32 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -DBN_ASM -DMD5_ASM -DSHA1_ASM -DRMD160_ASM -DOPENSSL_USE_APPLINK -I. /Fdout32dll -DOPENSSL_NO_CAMELLIA -DOPENSSL_NO_RC5 -DOPENSSL_NO_MDC2 -DOPENSSL_NO_KRB5 -DOPENSSL_NO_DYNAMIC_ENGINE
available timing options: TIMEB HZ=1000
timing function used: ftime
The 'numbers' are in 1000s of bytes per second processed.
type 16 bytes 64 bytes 256 bytes 1024 bytes 8192 bytes
md2 858.35k 1797.09k 2502.85k 2744.40k 2863.25k
mdc2 0.00 0.00 0.00 0.00 0.00
md4 9161.87k 31980.97k 92768.68k 175310.51k 240031.58k
md5 8152.99k 28237.34k 79240.60k 145100.25k 190056.26k
hmac(md5) 10780.19k 35380.04k 91967.75k 145100.25k 190056.26k
sha1 7774.79k 24811.94k 60322.57k 94813.31k 113321.28k
rmd160 6563.34k 19407.97k 42649.42k 61353.87k 70065.63k
rc4 139810.13k 164676.25k 171511.10k 173175.23k 172640.63k
des cbc 24185.12k 24973.53k 25206.15k 25934.79k 25747.72k
des ede3 9060.93k 9176.90k 9272.75k 9249.70k 9224.45k
idea cbc 17098.67k 18045.84k 18291.77k 18448.67k 18418.29k
rc2 cbc 8794.01k 9978.72k 10044.43k 10053.46k 10053.46k
rc5-32/12 cbc 0.00 0.00 0.00 0.00 0.00
blowfish cbc 40223.49k 42441.73k 43118.01k 43656.56k 43464.29k
cast cbc 38347.92k 40672.04k 41455.93k 41620.48k 41775.94k
aes-128 cbc 35091.44k 36897.33k 36033.54k 37282.70k 37282.70k
aes-192 cbc 31034.44k 31956.60k 32634.15k 32640.50k 32634.15k
aes-256 cbc 27535.23k 28787.26k 28941.20k 28941.20k 29021.30k
camellia-128 cbc 0.00 0.00 0.00 0.00 0.00
camellia-192 cbc 0.00 0.00 0.00 0.00 0.00
camellia-256 cbc 0.00 0.00 0.00 0.00 0.00
sha256 5540.33k 13459.46k 24542.45k 31236.67k 33872.84k
sha512 1843.35k 7146.39k 11545.61k 16405.63k 18504.62k
sign verify sign/s verify/s
rsa 512 bits 0.001189s 0.000100s 840.7 9986.3
rsa 1024 bits 0.005844s 0.000300s 171.1 3329.8
rsa 2048 bits 0.035111s 0.001049s 28.5 953.4
rsa 4096 bits 0.234300s 0.003362s 4.3 297.5
dsa 512 bits 0.000940s 0.001159s 1063.5 862.5
dsa 1024 bits 0.002772s 0.003363s 360.7 297.3
dsa 2048 bits 0.009327s 0.010798s 107.2 92.6
--- end ---
- Z
