Durzel, I think you are wrong here.Quote:
Originally Posted by Durzel
This doesn't work on my retail x6800.
It isn't about the x6800's being truly unlocked (they are), but its about how the P5W handles the multipliers. But I think I was wrong by talking about "POST", as the x6800 never even makes it to that point--it doesn't even initialize.
336x11 (3700) POSTS just fine @ 1.52v on my p5wdh and loads windows (requires more than 1.6v on air for stability and temps go through the roof so forget it), however,
370*10 *does NOT* POST at all at 1.52v.
I have to raise the vcore to 1.575v for it to POST.
So the chip is initializing at 4070 mhz first, with the 11 multiplier, before the BIOS is able to take over and set it to 370*10. You see? How can the multiplier be lowered if the chip can't even powerup enough to allow the BIOS code to run?
Note, after failure to POST (at 1.52v), if I hold down the power button to power off and then power on again, I get the expected "overclock failed" and the system is reset to 2266*11 powerup.
I am not the only X6800 user who has seen this. Check in the Intel support forum. This problem has been discussed there too.
In order for your method to have worked, the last requested multiplier would have to have been saved on the CPU somehow internally. I remember some years ago there was a forum post explaining exactly what happens on power on, before BIOS code can take over.
So very low multipliers (like 6 or 7) with high fsb's will never work unless the cpu could power on with its default multiplier at that FSB and mhz.
I shouldn't have said 'the chip is detected as...", rather "the chip powers on at the multiplier it is designed for", and therefore, the BIOS never has a chance to load, because it is the BIOS that has to change the multiplier. If I'm wrong about this, tell me. The CPU does not have "flash memory", so the new multi can't be "flashed" to it (to be retrieved at cold PWR good/on). It can be requested, but to get to that point requires, at power up, that the chip at least be able to power up and execute enough basic code so the BIOS can load.
