I received about 1 week ago a retail 165 0534 MPMW...
I ran it 290x9=2610 (just cant recall the ram speed , pretty sure was 133 divider) on DFI SLI-DR bios 623-2, SI120w/nexus fan for 13hrs small fft Dual Prime 95 , temp max was 46-48c underload..vcore was 1.46 in bios..:D
Anyway I tried to get 2650, 2700 using 1.52-1.54 v in bios vcore..no go either crashed prime 95 or temps got around 53-54C..so I stopped..I was running my ram higher at 237 with 5/6 divider(ram worked with my venice up to 250)
ram was tested at 237 (with prior setup at 250 mhz) in memtest86 for 10 passes or 6hrs when I stopped it with no errors
anyway..I went ahead and installed CAt5.13 driver which works better with DC cpus and net 1.1 framework....and turned up the ram and reran prime95..cpu0 crashed at 10hrs....then suspect attempts at runs of Prime 95 crashed sooner
have you guys seen a chip dual Prime 95 small fft 13 hrs..I stopped and then after tweaking and trying to up the oc...going back and finding it can no longer run Prime 95 at lower OC..:confused:
thanks
Neal
BTW:
components
OCZ 520W Powerstream
opteron 165@2610??
DFI SLI-DR 623-2
2x 1gb crucial valuram???
Seagate 7200.8 sata
X800XL artic silencer 435/540
audigy2
benq 1640
4 120mm case fans..3 YL loon and 1 coolermaster
my old overclock was Venice3200@2750 with ram at 250 3-3-3-7-1t
