Well after I fried my first pair of TCCD sticks I finally got some new ones and have been able to really see what my system can do. Here is a screen shot of a little testing I did lastnight.
got my 3200 winnie CBBID 0504 DPGW to 2500mhz 1.55v prime95 stable :toast: ... But i kind of killed my Abit AV8, so i'll be getting a K8N Neo2 in due time :banana:
IHS removed and polished with sand paper . Then reinstalled back . Original thermal grease under the IHS replaced with Arctic Silver 5 .Results = +150MHz overclock so far . 2800MHz Benchmarks stable, some will bench at 2870MHz. 2735MHz MAx. on unmodded CPU before the modification was done. Will continue to polish IHS later .
http://img59.exs.cx/img59/6757/0014hm.th.jpghttp://img59.exs.cx/img59/7383/0109pb.th.jpghttp://img59.exs.cx/img59/9554/0138ja.th.jpghttp://img59.exs.cx/img59/6340/0223ei.th.jpghttp://img38.exs.cx/img38/673/picture36ti.th.jpghttp://img38.exs.cx/img38/4831/picture49ox.th.jpg
http://img46.exs.cx/img46/2373/pcmar...9x90185.th.gif
MMMMM, Sanded IHS + Hyper 6 = :slobber:
:D Thats what happens when u dont have money for a Vapochill :rotf:
3200 cbbid 0507 at 2.75 fully benchable @ 1.65 volts........kinda crazy, it wasnt hard at all, benched on a cold night @ 2.8 but max screen:http://valid.x86-secret.com/show_oc?id=8108. that was with 1.76 volts........wouldnt do anything @ 3ghz, could clockgen it but then it just rebooted as soon as i switched app, wasnt temps or mem, and im pretty sure my vcore was enough.........ill try again on the next cold one.
Clockgen has never worked for me. Whenever I've used it to change the speed in windows, the system just freezes. If I make the changes in bios, it's perfectly stable.
btw...does "burning in" a winnie help any at all? I juiced mine up to 1.64v and put it on the prime torture test. Max temp I've reached is 44c w/XP-90 and ceramique. How long should I burn it in for? I was planning on just running the prime torture on it for a few 12 hour periods (with short breaks to check email and junk)...should I go for a week?
Ppl can anyone tell me the max voltage for a 3200+ Winnie cooled by r404a Prommy? Like 1.8v 24/7 and 1.85v for benching, too much or I can give more? Opinions please =)
Need some help from people that have subzero working Winchesters.
Mine did 2600Mhzs stock cooled 1.65v, now r404a cooled it does 2800Mhzs @ 1.76v, but even @ 1.85v i cant get more than 2800Mhzs, anyone with the same problem? It's not HTT limited neither memory limited.
(sry for double post)
lets put it this way, i know a guy that ran -35c load phase-change and 1.9v 24/7 killed his chip in a few days...Quote:
Originally Posted by diogojcr
soo i wouldnt go much above 1.8 24/7 unless you want an excuse for a new venice or san diego :rehab:
very nice work Gorod! Id try that out myself it my mobo wasnt the limiting factor! Great pics to!
Here is a little update with some EVEREST scores. Pushed it to 301 with the same vcore. Any higher vcore and I think I'm running into heat problems. From my experiance most winchesters loose stability around 56 degrees. The reason I think it's heat is because the higher I got with my vcore the faster my PC would freeze during 3DMark05. Maybe a little while down the road I'll invest in a XP-90. I would do it now but I just got ripped off on ebay/paypal for one of my A64 3000+ chips. :mad: Anyways here are the EVEREST screen shots!
woah sick HTT and RAM speeds!!
wow 300mhz ram with those timings and 2.7v :slobber:Quote:
Originally Posted by TheMeatFrog
I picked up another 3000+ from a bud of mine, CBBHD0450TPFW. Its not as good of an overclocker as my 0450UPBW but its not bad at all. It will do 2.4ghz @ Default vcore, 2.5ghz @ 1.5v and 2.7ghz with 1.65v(1.525+8%) The temps @2.7 have been around 32c idle and after 9hrs of cpu-burnin and around 4hrs of nonstop benching the temps never went above 52c. Now that my DFI is here it and my Neo2 will go into 24/7 duty in my everyday rig giving my Epox/1700+ a much deserved rest.
http://members.cox.net/vladz1rtc/cbb...20shot%202.JPG
These two pic's show 2.4ghz@Default & 2.5 @ 1.5v. :D
didnt know why mine so bad. test it with many setting already still the highest is 2.4.
guess cbbid 0503EPJW really suck.
That seems where CBBID's mostly Sh** the bed. :(
Hi all....newbe in this forum:D
But i can write my o/c:
MSI NEO2 K8N Platinum bios 1.36mod
3000+@2700mhz 1.65v CBBHD 0449GPGW
GSKILL pc4400 (440)@ 2.5-3-3-7 6:5(166) 1T 2.75v
But something i cant understand why i cant get higher with my memorys.
When i start too o/c so it will start too be unstabel at 255HTT with memorys @ 1:1 1T
So too hit 300HTT with my cpu so have i to clock down my memorys too 6:5(166)
I have tryed with 2 difrents cpu and its stop at same place both times(255htt) and both cpu did hav difrents steppnings.
And when i try memtest i get over 6000 error @ 275x7-9 2.5-3-3-7 1:1 1T
//kTa(swedish)
:welcome: kta. Our rigs are very sim, My GSkill is 431 chips and i can run 1:1 up around 322htt but not @ 2.5-3-3-7 I run 2.5-4-3-7. Try going really loose then tighten them a little at a time. Good luck. :)
might getting some old proc production winnie in few days and i'll update u guys.
wanna throw my cbbid if this old proc i'm getting is better than my cbbid.
vlad:
I have tryed everything to fix it but did not fix it:(
I have been msg with a guy from gskill to and i have dine all what i can found in gsforum and in here and all o/c im in.
But i think what can be bad here now...when i get 310htt do i lose my sound and with bad sound...so it can be my mainboard who not let me mit high that 300x9 2.5-3-3-7 6:5 (166) 1T....but i can hit 300x9 2.5-3-3-7 1:1 at 2T.
why so low at 1T?
Need to get more power of my cpu and memory so i can get higher on ORB list on 3dmark01 and 03 im on 8 place on 3dmarks if i remeber right now:)
EDIT:
Forget to say that i hit 2.5-4-3-7 1:1 1T @ 300x9 in singel channel with both memorys(1 at the time in mainboard)
Here is my crappy chip :(
Its a:
AMD Athlon 64 ADA3200DIK4BI
CBBHD 0449GPHW
1169847L40077
although this is a old result (with my old Zalman CNPS 7000B-cu), at the moment i have a CoolerMaster Hyper48, + I replaced my chieftec 360 watt psu with a 550 watt lc power (wich is much more stable), and next week i will remove my heatspreader. So after all this i might oc much better.
This is the max my processor can run (Max voltages mobo can hadle with bios 1,3 - no voltmods ((Original.)
http://members.lycos.nl/hugnix/2900.JPG
Not a bad chip!
Pretty sweet clocks but a sick vcore voltage! :banana:
Congrats tho on 2.9GHz :toast:
Alec
:shock: WOW! That is SICK voltage. How stable is it at that speed? I can boot at 2871mhz(Bench stable) then use clockgen to hit 2911mhz but its not even bench stable but thats with 1.7v (Max 1.4 Bios). Maybe with the heatspreader off youll hit 3ghz:slobber: Good luck with it.
got new proc already but still not satisfied with the stepping.
its a CBBID again damn. should find a better one later. anyone
got the same as my new proc 3000+ CBBID 0451MPM? still priming at 2.0
stock vdimm(corecell detect 1.36v).
