Damn conman, thats nice and clean
Its a Yeong-Yang Minicube :toast:Quote:
Originally Posted by jrw
What are you using to Block your TLine Samuel?
who?? me?? LOL i am Manuel ihih
well i am using a acessorie that i have found on a garden-bricolage/shop.
i do not now how to say the correct name in english:slapass:
ok first of! dont laugh!
its a cheap, too small, and :banana::banana::banana::banana:ty q-tec... and a cheap old watercooling witch im
changing over time. it is a original waterchill! but i have changed the fan and radiator to a yate an procore heatercore.
i only have 2 fans. the yate and the 120mm in the fsp power.
i have a new power on the way btw. (mist 500w, dead silent)
so... i think my next change will be a new cpu block!
and im planning on building a case of wood. it will be alot bigger!
http://www.xtremesystems.org/forums/...4&d=1143826809
http://www.xtremesystems.org/forums/...5&d=1143826809
and i need aplause or something for getting a 8mm id\11mm od on a 1\2 fittings:clap:
http://www.xtremesystems.org/forums/...6&d=1143826809
here is my system. disregard the wiring, no one can see it because my case technically shouldnt even have a window in it but i cut two custom ones.
http://i58.photobucket.com/albums/g2...terpicture.jpg
http://i58.photobucket.com/albums/g2...Picture001.jpg
http://i58.photobucket.com/albums/g2...Picture002.jpg
http://i58.photobucket.com/albums/g2...r651/tower.jpg
yes, i realize that the cuts are crappy... i used a cutting wheel and didnt have a lot of time to fix everything up. but i really dont care. function > form
viper650- you should go to mcmaster.com and order some Push-on Edge Trim to make those cuts look better. either that or electrical tape, which ive used and actually doesnt look half bad
only take a metal-file and 1 hour and every cut seems perfect, the easiest way:p:Quote:
Originally Posted by johnanderson
my one :banana:
http://img380.imageshack.us/img380/7...01069fq.th.jpg
ooo. now thats a fancy nightclub of a box you got there bullit :D. I like it. you should ahve the uv lights sound sensitive.
ive thought about the electrical tape, but im honestly just too lazy to do it. i will soon enough and thanks for the link. ive been wondering where to get the trimQuote:
Not as purdy as some of the others.
Originally Posted by REDKEN
You did an extremely nice job of routing your tubing. You took your time and it shows.
Hello everybody. This looks like a great forum with a lot of info. Here is my current rig. I have started purchasing components to upgrade to PCI-E. I will post new photos when that is complete.
Looks nice! :up:Quote:
Originally Posted by Hansfragger
EDIT* pics dont work ON MY MAC AT WORK
saw it at home and yea good god man, switch the ports around on the block...
work fine.
thought so maybe his settings are different or perhaps try a different browser? :toast:
sorry to go off topic but does anyone have a pic of that water block that was on a forklift truck and weighed like half a Ton ?
I can't find it anywhere
Grinch for the love of god you ahve the inlet and outlet on the Storm confused.. I even put a special note in several of my guides about that for the storm.. sheehs.. when will ppl start reading..its also in the directions for the storm!
hahaha :clap:
:rotf:
very nice one bullit :D
it iis a very funny case, and i think it is just perfect ou entao boa cmo marisco:D
