small improvement with memory on LN2.
BBSE did not seem to scale with voltage like I thought it would, oh well:rolleyes:
http://i.imgur.com/XqUud.png
U still have cw problem dude, look your available memory. Try 7_10 under ln2 ans 7 tcwl
ha I must have forgotten to set maxmem on that run, I was testing 600+
7_10 at TCWL 7 was not working constantly failing by sometimes by loop 4 sometimes loop 23 at full pot.
http://i.imgur.com/k1yac.jpg
there's a Triple Point pot hidden somewhere under there:D
http://i.imgur.com/9cf6c.jpg
I tried voltage from 1.87 to 2.0v but stopped there as I was not seeing scaling, I will give PSC a try this Tuesday when I refill.
What's the humidity in your area?! :shocked:
PS: Looks like your MAXMEM was set to 600MB for that run, but your available real memory is too low.
I see. It looks pretty "cool" though... :D
Were you using ERAM for this run? And which CW size were you using? Instead of using ERAM you could try using two HDDs.
nice improvement man, time to put pitweaker to rest. I get better results just single copy paste of 1.8GB file, give it a shot man. Keep pushing
Ssd make a diffrence regarding wazza versus classic hdd ;)
Thanks Splave:)
Manual waza is definitely on the top of the list as my waza is not very efficient.
I have everything ready minus the LN2 hopefully they are not closed today and I will be shooting for 17's if I can fill back up tonight. Not sure if I should give PSC a spin cold or keep trying with BBSE.
Regardless this thread is awesome sauce and I will keep pushing:D
No,you can get a faster wazza with classic hdd,ssd is not the best for wazza.
Finaly today i run mems on ln2. cpu is on air.
you have to spent quite along time for test in order to get a decent run.
i have to improve it next time.
http://img708.imageshack.us/img708/2290/capture4ju.jpg
Uploaded with ImageShack.us
ASROCK OC Formula sets 49x102.1 as 5001.54
maximus v formula sets 49x102.1 as 5004.29:confused::mad:
http://img35.imageshack.us/img35/5039/capture7dh.jpg
Amazing work with the 2800 CL11's & Cold Kintaro :up:
Kintaro i tried my good 2800 kit but best i did was 2666 c9 ss-20 with everything else tight, u got CRAZY hynix there they can do cl8 with those timings man.
I know dumo has some nice hynix to, hope he find time to try them under cold.
Got 296xx with PSC but i want fight with hynix and sammy lately.
Is that Hynix for real?
Hynix no have CB (AMD) but on IB a lot of times u get 55 code on boot when temp is lower than -100
should be some CFR
at -80000 no hynix can do like kintaro did with his kit, his kit should be very very special, i rememeber we tried at computex some nice hynix but CL8 with tight timing were IMPOSSIBLE
His kit is BFR not CFR.Too bad we can't find those good BFR anymore :(
Possibly the first batch
http://img22.imageshack.us/img22/548...enshot093o.png
Neweeg's first retail batch (only 2X4GB)
http://img846.imageshack.us/img846/1...enshot092k.png
