These builds are awesome. Excellent work knet! More black and white builds!
http://i228.photobucket.com/albums/e...29_871x580.jpg
My latest liquid cooled built on i7...
Lights out. LED's on. :D
http://img129.imageshack.us/img129/9718/004xa.jpg
My first watercooling system.. ;)
http://i297.photobucket.com/albums/m...9/IMG_4927.jpg
http://i297.photobucket.com/albums/m...9/IMG_4930.jpg
something like this?
http://img1.abload.de/img/1-2x5w0.jpg
illidan i Love it :slobber: :)
http://www.abload.de/img/img_0496w9gh.jpg
yeah, pretty beautiful :)
not my shot btw :)
Doesn't really compare to most of what is posted here...this IS XS after all. Just do the best with what I've got and try to improve it every time. Took some photos tonight after cleaning it up and adding shrouds, figured I'd post them.
System Components:
- EVGA P55 FTW
- i7 860
- 2x2G G.Skill Trident, DDR3-2000 (9-9-9-24)
- EVGA 8800GTX
- Corsair TX650
- Coolermaster RC690
Loop:
- MCP-355 w/ XSPC Res Top ->
- Swiftech MCR-320 (with 3x Ultra High Speed Panaflo fans & 38mm shrouds) ->
- D-Tek Fuzion v.2 ->
- Swiftech MCW-60
We'll start off with the whole system and then move around it as usual. Hopefully the wires are a bit cleaner since you saw it last. :)
http://www.myalbumbank.com/albums/us...00wholesys.jpg
http://www.myalbumbank.com/albums/us...romrt10-19.jpg
http://www.myalbumbank.com/albums/us...ommid10-19.jpg
http://www.myalbumbank.com/albums/us...adows10-16.jpg
EDIT - To head off the inevitable question about the radiator: It is mounted both externally and with that long tubing so that it can be dunked in a cooler full of ice water for high-Vcore benching sessions.
well, its been a while since i posted here, so i figures id throw up a couple updates since i removed the case side this morning.... the re-build was last week, when i received my new MCP-655-B pump, the EHIEM i had in it ran for 10+ years, before it started getting real LOUD!! hahahahaa.... so since i ordered a new pump, i figured id do the tubing, and a new case with 1 TB drives......
anyways the pics are of an E6600 on an ASUS P5B-Plus with old danger-den blocks, thats ive run through many builds already, ive had them in a pc since they came out 10+ years ago... and they still work great! the E6600 is running at 3.6 24/7 and my temps are always around 36-37 degrees C under normal load, and never, ever hit 60 C..... highest ive seen is 56C. ive found no need to change the blocks, the video card is on air (8800 GTS 320mb), and im running a MAtrox tripple head 2 go, with 3 19" dells as my main screen and a cheap KDS 19" as the fourth screen off to the side. I also have a 32" HD LCD for viewing U-Tube stuff and Internet TV (Readon TV).....
well, thats it for my long winded update. ;-) Hope ya like ...... (not bad for a 40 Y.O married guy... eh,? ;-)
Nice copters up there, rigs not bad either ; )
Nice T-Rex.
looks like that is the bigger hobby
Yep.... thats a couple of them, i got a 500 Hoss X5r (trex all belt drive mod) with sk360 flybarless setup, it was in the garage at photo time... all in all 8 or 9 birds.... the 32" LCD is awesome for Sim flying in the winter months!!
4- 450's (3 hoss x4e's, 1 trex 450)
1- blackhawk 500 se pro
1- trex 500 cf
1- hoss x5r 500 FBL
1- trex 500 (silver FG frame)
1- trex 600e
its a whole different hobby/ forum.....MUCH harder than flying planes.:up:
That Nic 5870 Block is the prettiest block I've seem so far...
Here are some pics of the CM Sniper Side Window Panel on my HAF922. It is a great buy for $10 to have an extra side panel along with being a full window.
http://img197.imageshack.us/img197/5365/dsc01649v.jpg
http://img197.imageshack.us/img197/2420/011od.jpg
Chad
:wave:
My 1st liquid cooling rig.:D
http://i474.photobucket.com/albums/r...j/IMG_6336.jpg
http://i474.photobucket.com/albums/r...j/IMG_6355.jpg
very nice rig, i love tj07. :p
System 2 in my A17B:
http://www.abload.de/img/img_2300xqa9.jpg
Schlingel your rig looks very sexy with those White Led fans. Soon will finish mine system with same fans :P
Excellent work there Schlingel, great wiring and tubage. :up:
